Doesn’t sound right. There are figures for latency on the site and they are certainly considerably less than that. I’ve built them with hifiberry cards both amps and audio out and audio injector cards and they all are very playable instruments.
I did it 2 years ago and as far as i can remember, it worked perfectly OK with no audible latency.
A friend of mine have one of the 2 units i mounted with the “DAC+ light”. I’ve contacted with him to ask if there is some latency problem in his zynthian…
Anyway, could you be a little bit more specific? Are you having the latency with all the engines? What is your audio setup? Are you using some kind of digital device in the middle (from the zynthian output to the speakers)? Are you using the MIDI-IN or MIDI-USB? What keyboard are you using? Have you tried with a different one? etc.
This is not only about latency. The sound is crappy (jitter) when playing more then 3-5 keys. I have now an idea, that is high CPU usage. Sounds like. I will check at home using htop.
Midi controller is good - latency is the smaller problem now
The same in all engines.
PS: I cannot found exact chip specification (ESS xxxx) of HiFIBerry DAC+ Light (Google)
I thing, the sound card is good. Everything works fine, except Zynthian when is playing more tones.
On the soundcard´s board is nothing more then one ESS chip and oscilator. Do you know chip number on HiFiberry DAC+ Light? I am not abble to found it on the internet (mayby top secret)
There is not much things to make it badly.
I will testing with Stetch and realtime kertnel etc.
I can confirm that my zynthian (RBPi3 B+ & HifiBerry DAC+) works perfectly with the default settings. I can play 10 notes (and more) with Pianoteq Steinberg D or any other intruments. Same applies to most of engines/presets, except some really heavy presets for ZynAddSubFX (Angel Piano, for instance, XRUNs with only a few notes).
Yes. Soud files is ok, and some less-cpu usage engine sound is ok (with no many keys pressing)
Problem is Pianoteq, Synthetizer etc.
I was testing everything you wrote. Last time my Yamaha keyboard. No Mouse, No monitor, 2 independent power source, changing CPU clock, Jackd priority …
