Xrun mod ui
I am using Edgar’s gorgon image in rp3, when I use it in the ui mode suddenly the xrum varies with oscillating with several number is the rp3 is muted the screen hangs how to solve this?
Use HDMI, USB audio
Excuse the ignorance someone please can you help me because Xruns is like this in the image?
What does this mean? Is it a special image or the original one?
USB audio is IMHO not deeply tested. Maybe that’s your problem.
Also you are using a plugin named “akai_steinway”. Perhaps trouble with this plugin?
It is very difficult to help if you have a “non-standard” setup and you give only some small sentences describing your system. And using non-standard components in combination with less system information makes it nearly impossible to help.
Regards, Holger
o prugin aki_steimway and a 24.5-megabyte piano use the audio usb of that cockroach
comtac .images
the image I use and “Gorgona Edge”.
