I had issues with rtpMIDI and the root cause seems to be that Z allocates two ip addresses via eth0.
ifconfig doesn’t reveal it:
(venv) root@zynthian:~# ifconfig
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.20.152 netmask 255.255.255.0 broadcast 192.168.20.255
inet6 xxxx::xxx:xxxx:xxx:xxxx prefixlen 64 scopeid 0x20<link>
ether xx:xx:xx:xx:xx:xx txqueuelen 1000 (Ethernet)
RX packets 7614 bytes 720816 (703.9 KiB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 708 bytes 88157 (86.0 KiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
device interrupt 104
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10<host>
loop txqueuelen 1000 (Local Loopback)
RX packets 25 bytes 5060 (4.9 KiB)
TX packets 25 bytes 5060 (4.9 KiB)
But ip a shows the second one
(venv) root@zynthian:~# ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host noprefixroute
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
link/ether xx:xx:xx:xx:xx:xx brd ff:ff:ff:ff:ff:ff
inet 192.168.20.152/24 brd 192.168.20.255 scope global dynamic noprefixroute eth0
valid_lft 5964sec preferred_lft 5964sec
inet 192.168.20.100/24 brd 192.168.20.255 scope global secondary dynamic noprefixroute eth0
valid_lft 5969sec preferred_lft 5075sec
inet6 xxxx::xxx:xxxx:xxx:xxxx/64 scope link noprefixroute
3: wlan0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
The issue is that rtpMIDI announces itself via both IPs, the x.152 being the primary, but rtpMIDI only accepts connection on secondary IP x.100
Is there a reason for having two different IP addresses and can rtpMIDI be fixed to listen for incoming connections on both?
