After reading the RTFM post, and reading the formidable manuals, which I have diligently done, I’m still stuck so I will ask for your gentle and kind help.
I have updated my old pre-summer oram version in my V4 zynthian to the latest and bravest staging commit. I can move to the different chains with the encoder and make sure that chains work as expected. But my ZS3 are not recalled properly. I can see the Program Change in the midi log but I don’t see any changes in the mixer view. Presets are not restored (i.e. loading a different soundfont in sfizz), active chains are not changed either, so it looks like it does not work.
The same happens if I go to the zs3 menu and load them from the zynthian UI, they don’t behave as expected (by me). I explain this because I have ruled out that it has something to do with the “MIDI-USB mapped by port” which in my case I’ve made sure it’s also disabled.
I have checked the active/multitimbral config, I have set the USB input device not to be multitmbral, I also don’t need different chaiins with the same midi channel, so the global Active midi channel is also disabled.
The only thing I need is that when I recall a ZS3 using a Program Change, presets are loaded and active chain is properly selected.
Any hints on what could be wrong?
Thank you
Pau
