ZS3, presets, and AIDA-X
Something is not working properly with ZS3, presets, and AIDA-X. I would report an issue but I can’t seem to figure out what the specific problem is. Basically, when I have different saved presets recalled by ZS3, the model and IR files aren’t always loaded. Sometimes they are, sometimes they aren’t. Loading the presets manually seems to work more often but still not every time. Loading presets using the GUI over VNC always works.
As a workaround, I had two instances of AIDA-X in parallel and used the amp/cab bypass switches to select one or the other via ZS3 but the amp selector switch is gone in the latest vangelis update.
I attached my snapshot. Can anybody try to replicate this? Maybe we can get more clarity on what is going on.
Joe
021-guitar w midi.zss (128.4 KB)
