The magical number 16…
Let’s remember where we already have seen it…
16… is it not 8 banks of 8 presets, or snapshots, which can be called rapidly from the front panel ?
Is it not 16 steps of a drum machine pattern ? @riban 's step sequencer in sight…
16 I/O switches, does that mean 16 in and 16 outs ? In that case each push button could be equiped with a LED ?
Or does that mean 16 I/O and, for each of them, you have to decide if it’s an in or an out ?
16 input/output total. But currently only input is implemented in zyncoder library, what allows to use it as customizable switches that can be assigned to:
MIDI messages => CC switches, Note-On, Program Change, etc.
CUIA (Callable UI Actions)
We could develop a similar mechanism for output, a kind of AUIF (Assignable UI Flags) …
Of course, it’s fully compatible with v3 kits. Everybody having a zynaptik circuit can benefit from the new Zynaptik Extensions by simply soldering the extension submodules on the zynaptik module:
Yes, v3 cases doesn’t have this cutout, but it’s an easy task. I’m pretty sure that people that doesn’t fear of soldering the submodules won’t be afraid of cutting out the case with a “dremmel”
I think that on a small screen, a large number of small characters is evil, if you mean that you plan to place additional characters on the screen.
It seems to me that a page in the web interface will be enough to indicate and visuality which button is assigned to which function.
But what I would really like to see is a physical implementation of button highlighting, and the function name can be printed on self-adhesive paper and pasted next to the button.
Would be good to dedicates some screen real estate at the bottom (similar to the top bar) to have some text showing what the current quick button functions are define for a particular page. Probably should have some sort of shift function with one of the knobs and then you have 8 quick access functions.
