I have just finished building kit 4.4, and just doing final check regarding ribbons and connecting 1st pins to the red side of the ribbon. I followed the instructions as per wiki, but that doesn’t explain too much regarding the ribbon connecting to ZynAuCon v1.2 which came with the kit.
As you can see on the pic, the ribbon red side doesn’t line up with the 1st pin on the ZunAuCon v1.2.
The installation instructions for kit v4.3 say just put ribbon in 90 degree twist.
Do I need to follow that instruction, which makes sense as the ribbon it too short to do anything else with it… Or do I follow the instruction that red side of ribbon connects to 1st pin? Which would involve buying a longer ribbon and twisting it in a weird way
