ZynScreen and Rpi 5 - white LCD
I bought a rpi 5 and got the idea that I could revive my old project. So I combined three things that I have:
  • ZynScreen 3.5 (v1)
  • Raspberry pi 5
  • Behringer 404 HD
In webconf, I got everything working as expected.
HARDWARE
Raspberry Pi 5 Model B Rev 1.1
Audio: Behringer UMC404HD
Display: ZynScreen 3.5 (v1)
Wiring: MCP23017_ZynScreen
I2C: MCP23017@0x20
Profile: v4_studio
SYSTEM
Build Date: 2024-09-11
Memory: 32% (1306M/4045M)
SD Card: 13% (14G/115G)
Temperature: 54.9ºC
Overclock: None
MIDI & UI
Tuning: 440 Hz
Master Channel: Off
Preload Presets: On
ZS3 (SubSnapShots): On
Power Save: 10 minutes
Audio Levels on Snapshots: On
SOFTWARE
zyncoder: oram-2409 (71de6d2)
zynthian-ui: oram-2409.001 (df2facc)
zynthian-sys: oram-2409.002 (4c4ce51)
zynthian-data: oram-2409 (ddfa009)
zynthian-webconf: oram-2409.001 (88fc358)
LIBRARY
Snapshots: 15
User Presets: 1
User Soundfonts: 0
Audio Captures: 0
MIDI Captures: 3
NETWORK
Hostname: zynthian
Wifi: ON
IP: 192.168.88.136
VNC: On
MIDI Services:
The only problem is, ZynScreen is white and nothing is visible on it. When accessing via VNC everything works. I can load selected snapshots, play midi, all without problems. Only white on the LCD panel…
I turned on UI log and this is what I found:
Dec 18 16:56:17 zynthian systemd[1]: Started zynthian_debug.service - Zynthian User Interface (DEBUG).
Dec 18 16:56:17 zynthian startx[1773]: X.Org X Server 1.21.1.7
Dec 18 16:56:17 zynthian startx[1773]: X Protocol Version 11, Revision 0
Dec 18 16:56:17 zynthian startx[1773]: Current Operating System: Linux zynthian 6.6.47-v8-16k+ #1794 SMP PREEMPT Thu Aug 29 16:30:28 BST 2024 aarch64
Dec 18 16:56:17 zynthian startx[1773]: Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe bcm2708_fb.fbwidth=640 bcm2708_fb.fbheight=480 bcm2708_fb.fbdepth=16 bcm2708_fb.fbswap=1 smsc95xx.macaddr=2C:CF:67:A6:70:73 vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000 root=PARTUUID=e249d476-02 rootfstype=ext4 fsck.repair=yes rootwait console=tty1 logo.nologo modules-load=dwc2,libcomposite
Dec 18 16:56:17 zynthian startx[1773]: xorg-server 2:21.1.7-3+rpt3+deb12u7 (https://www.debian.org/support)
Dec 18 16:56:17 zynthian startx[1773]: Current version of pixman: 0.42.2
Dec 18 16:56:17 zynthian startx[1773]: Before reporting problems, check http://wiki.x.org
Dec 18 16:56:17 zynthian startx[1773]: to make sure that you have the latest version.
Dec 18 16:56:17 zynthian startx[1773]: Markers: (--) probed, (**) from config file, (==) default setting,
Dec 18 16:56:17 zynthian startx[1773]: (++) from command line, (!!) notice, (II) informational,
Dec 18 16:56:17 zynthian startx[1773]: (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
Dec 18 16:56:17 zynthian startx[1773]: (==) Log file: "/var/log/Xorg.0.log", Time: Wed Dec 18 16:56:17 2024
Dec 18 16:56:17 zynthian startx[1773]: (==) Using config directory: "/etc/X11/xorg.conf.d"
Dec 18 16:56:17 zynthian startx[1773]: (==) Using system config directory "/usr/share/X11/xorg.conf.d"
Dec 18 16:56:18 zynthian startx[1779]: ----------------------------------------------
Dec 18 16:56:18 zynthian startx[1779]: Linux Version: bookworm
Dec 18 16:56:18 zynthian startx[1779]: Kernel Version: 6.6.47-v8-16k+
Dec 18 16:56:18 zynthian startx[1779]: ZynthianOS Version: 2409
Dec 18 16:56:18 zynthian startx[1779]: Virtualization: none
Dec 18 16:56:18 zynthian startx[1779]: Hardware Architecture: aarch64
Dec 18 16:56:18 zynthian startx[1779]: Hardware Model: Raspberry Pi 5 Model B Rev 1.1
Dec 18 16:56:18 zynthian startx[1808]: /zynthian/config/img/fb_zynthian_boot.jpg is a 480x320 JPEG image, color space Grayscale, 1 comp, Huffman coding.
Dec 18 16:56:18 zynthian startx[1808]: Zooming image by 100%...done
Dec 18 16:56:18 zynthian startx[1808]: Merging...didn't find evidence of prior run.
Dec 18 16:56:18 zynthian startx[1808]: done
Dec 18 16:56:18 zynthian startx[1808]: Building XImage...done
Dec 18 16:56:18 zynthian startx[1810]: INFO:zynthian_gui_config.<module>: ZYNTHIAN-UI CONFIG ...
Dec 18 16:56:18 zynthian startx[1810]: INFO:zynthian_gui_config.<module>: Wiring Layout MCP23017_ZynScreen
Dec 18 16:56:18 zynthian startx[1810]: ZynCore: Configured 8 x Logical Zynswitches...
Dec 18 16:56:18 zynthian startx[1810]: ZynCore: Setting-up 8 x Physical Zynswitches...
Dec 18 16:56:18 zynthian startx[1810]: ZynCore: Setting-up 4 x Zynpots (zyncoders)...
Dec 18 16:56:18 zynthian startx[1810]: ZynCore->gpiod_start_callbacks: Callback thread created successfully
Dec 18 16:56:18 zynthian startx[1810]: INFO:zynthian_gui_config.config_zynpot2switch: zynpot2switch => [0, 1, 2, 3]
Dec 18 16:56:18 zynthian startx[1810]: DEBUG:zynthian_gui_config.set_midi_config: MMC Bank Change CCNum: 0
Dec 18 16:56:18 zynthian startx[1810]: DEBUG:zynthian_gui_config.set_midi_config: MMC Bank Change UP: None
Dec 18 16:56:18 zynthian startx[1810]: DEBUG:zynthian_gui_config.set_midi_config: MMC Bank Change DOWN: None
Dec 18 16:56:18 zynthian startx[1810]: DEBUG:zynthian_gui_config.set_midi_config: MMC Program Change UP: None
Dec 18 16:56:18 zynthian startx[1810]: DEBUG:zynthian_gui_config.set_midi_config: MMC Program Change DOWN: None
Dec 18 16:56:18 zynthian startx[1810]: DEBUG:zynthian_lv2.load_engines: Loaded engine config with timestamp: 1734540069.566483
Dec 18 16:56:19 zynthian startx[1810]: Started libzynaudioplayer using libsndfile-1.2.0
Dec 18 16:56:19 zynthian startx[1810]: INFO:zynthian_engine_audioplayer.zynthian_engine_audioplayer: Supported Audio Codecs: ['aiff', 'aifc', 'au', 'caf', 'flac', 'mp3', 'vox', 'opus', 'ogg', 'wav']
Dec 18 16:56:19 zynthian startx[1810]: INFO:zynthian_main.<module>: STARTING ZYNTHIAN-UI ...
Dec 18 16:56:19 zynthian startx[1810]: INFO:zynthian_state_manager.__init__: Creating state manager
Dec 18 16:56:19 zynthian startx[1810]: Started libzynmixer
Dec 18 16:56:19 zynthian startx[1810]: INFO:zynthian_chain_manager.__init__: Creating chain manager
Dec 18 16:56:19 zynthian startx[1810]: DEBUG:zynthian_engine_alsa_mixer.get_controllers_dict: MIXER CTRL LIST: ['UMC404HD_192k_Output', 'Mic_0', 'Mic_1']
Dec 18 16:56:19 zynthian startx[1810]: DEBUG:zynthian_engine_alsa_mixer.get_mixer_zctrls: ADDING ZCTRL LEVEL: Mic 1 (Mic_0) => 100
Dec 18 16:56:19 zynthian startx[1810]: DEBUG:zynthian_engine_alsa_mixer.get_mixer_zctrls: ADDING ZCTRL LEVEL: Mic 2 (Mic_1) => 100
Dec 18 16:56:19 zynthian startx[1810]: DEBUG:zynthian_engine_alsa_mixer.get_mixer_zctrls: ADDING ZCTRL LEVEL: UMC404HD 192k Output (UMC404HD_192k_Output) => 100
Dec 18 16:56:19 zynthian startx[1810]: Started libzynseq
Dec 18 16:56:19 zynthian startx[1810]: DEBUG:zynthian_engine_alsa_mixer._send_controller_value: set 'UMC404HD 192k Output' 'Playback' 100% unmute
Dec 18 16:56:19 zynthian startx[1810]: Started libzynsmf
Dec 18 16:56:19 zynthian startx[1810]: DEBUG:zynthian_state_manager.start: Opened temperature sensor '/sys/class/hwmon/hwmon0/temp1_input'
Dec 18 16:56:19 zynthian startx[1810]: DEBUG:zynthian_state_manager.start: Opened undervoltage sensor '/sys/class/hwmon/hwmon2/in0_lcrit_alarm'
Dec 18 16:56:19 zynthian startx[1810]: INFO:zynthian_state_manager.start_vncserver: STARTING VNC-UI SERVICE
Dec 18 16:56:19 zynthian startx[1810]: DEBUG:zynthian_engine_alsa_mixer._send_controller_value: set 'Mic' 'Capture' 100%,100%,0%,0% unmute
Dec 18 16:56:23 zynthian startx[1810]: INFO:zynthian_autoconnect.init: Initializing 24 slots for MIDI devices
Dec 18 16:56:23 zynthian startx[1810]: INFO:zynthian_ctrldev_manager.update_available_drivers: Ctrldev driver 'zynthian_ctrldev_akai_apc_key25_mk2' for devices with ID 'APC Key 25 mk2 MIDI 2'
Dec 18 16:56:23 zynthian startx[1810]: INFO:zynthian_ctrldev_manager.update_available_drivers: Ctrldev driver 'zynthian_ctrldev_akai_apc_key25_mk2' for devices with ID 'APC Key 25 mk2 IN 2'
Dec 18 16:56:23 zynthian startx[1810]: INFO:zynthian_ctrldev_manager.update_available_drivers: Ctrldev driver 'zynthian_ctrldev_akai_midimix' for devices with ID 'MIDI Mix IN 1'
Dec 18 16:56:23 zynthian startx[1810]: INFO:zynthian_ctrldev_manager.update_available_drivers: Ctrldev driver 'zynthian_ctrldev_akai_mpk_mini_mk3' for devices with ID 'MPK mini 3 IN 1'
Dec 18 16:56:23 zynthian startx[1810]: INFO:zynthian_ctrldev_manager.update_available_drivers: Ctrldev driver 'zynthian_ctrldev_duopiano' for devices with ID 'GENERAL IN 1'
Dec 18 16:56:23 zynthian startx[1810]: INFO:zynthian_ctrldev_manager.update_available_drivers: Ctrldev driver 'zynthian_ctrldev_korg_nanokontrol2' for devices with ID 'nanoKONTROL2 IN 1'
Dec 18 16:56:23 zynthian startx[1810]: INFO:zynthian_ctrldev_manager.update_available_drivers: Ctrldev driver 'zynthian_ctrldev_launchkey_mini_mk3' for devices with ID 'Launchkey Mini MK3 IN 2'
Dec 18 16:56:23 zynthian startx[1810]: INFO:zynthian_ctrldev_manager.update_available_drivers: Ctrldev driver 'zynthian_ctrldev_launchpad_mini' for devices with ID 'Launchpad Mini IN 1'
Dec 18 16:56:23 zynthian startx[1810]: INFO:zynthian_ctrldev_manager.update_available_drivers: Ctrldev driver 'zynthian_ctrldev_launchpad_mini_mk3' for devices with ID 'Launchpad Mini MK3 IN 1'
Dec 18 16:56:23 zynthian startx[1810]: INFO:zynthian_ctrldev_manager.update_available_drivers: Ctrldev driver 'zynthian_ctrldev_launchpad_pro_mk2' for devices with ID 'Launchpad Pro IN 1'
Dec 18 16:56:23 zynthian startx[1810]: INFO:zynthian_ctrldev_manager.update_available_drivers: Ctrldev driver 'zynthian_ctrldev_launchpad_pro_mk3' for devices with ID 'Launchpad Pro MK3 IN 1'
Dec 18 16:56:23 zynthian startx[1810]: INFO:zynthian_ctrldev_manager.update_available_drivers: Ctrldev driver 'zynthian_ctrldev_launchpad_x' for devices with ID 'Launchpad X IN 1'
Dec 18 16:56:23 zynthian startx[1810]: INFO:zynthian_ctrldev_manager.update_available_drivers: Ctrldev driver 'zynthian_ctrldev_riband' for devices with ID 'riband Bluetooth'
Dec 18 16:56:23 zynthian startx[1810]: DEBUG:zynthian_autoconnect.midi_autoconnect: Connected MIDI-in device 0: system:midi_capture_1
Dec 18 16:56:23 zynthian startx[1810]: DEBUG:zynthian_autoconnect.midi_autoconnect: Connected MIDI-in device 1: ttymidi:MIDI_in
Dec 18 16:56:23 zynthian startx[1810]: DEBUG:zynthian_autoconnect.midi_autoconnect: Connected MIDI-in device 2: ZynMaster:midi_out
Dec 18 16:56:23 zynthian startx[1810]: DEBUG:zynthian_autoconnect.midi_autoconnect: Connected MIDI-out device 0: system:midi_playback_1
Dec 18 16:56:23 zynthian startx[1810]: DEBUG:zynthian_autoconnect.midi_autoconnect: Connected MIDI-out device 1: ttymidi:MIDI_out
Dec 18 16:56:23 zynthian startx[1810]: DEBUG:zynthian_autoconnect.midi_autoconnect: Connected MIDI-out device 2: ZynMaster:midi_in
Dec 18 16:56:23 zynthian startx[1810]: DEBUG:zynthian_autoconnect.midi_autoconnect: Connected MIDI-out device 3: ZynMidiRouter:seq_in
Dec 18 16:56:23 zynthian startx[1810]: DEBUG:zynthian_gui_config.set_midi_config: MMC Bank Change CCNum: 0
Dec 18 16:56:23 zynthian startx[1810]: DEBUG:zynthian_gui_config.set_midi_config: MMC Bank Change UP: None
Dec 18 16:56:23 zynthian startx[1810]: DEBUG:zynthian_gui_config.set_midi_config: MMC Bank Change DOWN: None
Dec 18 16:56:23 zynthian startx[1810]: DEBUG:zynthian_gui_config.set_midi_config: MMC Program Change UP: None
Dec 18 16:56:23 zynthian startx[1810]: DEBUG:zynthian_gui_config.set_midi_config: MMC Program Change DOWN: None
Dec 18 16:56:23 zynthian startx[1810]: DEBUG:zynthian_chain_manager.add_chain: ADDED CHAIN 0 => midi_chan=None, mixer_chan=16, zmop_index=None
Dec 18 16:56:23 zynthian startx[1810]: DEBUG:selector_events.__init__: Using selector: EpollSelector
Dec 18 16:56:23 zynthian startx[1810]: INFO:zynthian_gui_patterneditor.get_custom_keymap: MIDI channel 0 has not synth processors.
Dec 18 16:56:23 zynthian startx[1810]: DEBUG:zynthian_gui_brightness_config.get_backlight_sysctrl_fpath: Display brightness control file: /sys/class/backlight/soc:backlight/brightness
Dec 18 16:56:23 zynthian startx[1810]: WARNING:zynthian_gui_brightness_config.init_ctrls: Can't set display brightness!
Well, my observation matches the UI log, the brightness is the problem.
Please can someone advise me what to do with this?
