ZynSeq midi roll editing
is it possible to select all notes and move them? ill keep reading the manual, but i recording a sequence of chords i like, but i was late and just want it all to start on the downbeat. is this possible or is there a more zynthian way of handling moving notes around. or is it just one by one drag which idk how to do without wrecking non quantized steps?
In the pattern editor menu, there is an option, “Transpose pattern” which allows all notes in the pattern to be transposed (moved) up or down.
Hi @riban - Based on the reference to the downbeat I think @Barrett is looking for a way to insert or delete some time, not adjust-transpose the pitch of the notes. Sadly I don’t know of a way.
You can make parameter changes to individual or all notes. One parameter is offset, which moves the notes relative to the sequence step Bold press SELELECT to access the parameter editor. Bold press SELELECT again to toggle between single note / all notes operation.
excellent! thank you for letting me know and explaining how @riban
