If we are using zynthian somewhere without a router for connection, Zynthian would act as a Wi-Fi Hotspot, allowing connection via SSH or even access to MOD-UI or WebConfig.
I tried with my Raspi2 and external Edimax dongle to no avail.
Found some pages where they say, that I have to recompile the device driver.
Gave up and going to use my phone as hotspot.
Just made one a hotspot (latest Rpi3 B+) and it MOD thingies are nicely controlled from ipad. The idea works. It will be great for mobile performances (on the street for instance). Great idea !
Discovered an unpleasant detail with hotspot on - there is noise in the speakers with every system activity (like on a latpop sometimes, when the power is not grounded properly) Once I stop the WiFi - it is absolutely clear and silent. Have proper grounding at my space. Tried powering zynthian with power supply and power bank - same. Did anyone encountered same effect ?
Turned WiFi hotspot off until further investigation
I’m not a radio expert, but i would try a usb wifi-dongle, disabling the RBPi3 internal Wifi device. The internal wifi’s antenna is about 2-3 cm under the soundcard … not too good
When using a usb wifi dongle, a metal case should help too…
Thank you @jofemodo, that is exactly what I have suspected. By I have thought about moving the soundcard aside the main board (new connecting cable) in a new case I am making. Will try with the dongle and write back.
I just fixed this. Now, when changing the system password, the WIFI HotSpot password will be changed too. In the same way, when the hostname is changed, the hotspot SSID will change too.
