Tested: 2019-10-15-zynthianos-buster-lite-1.0.0
I’m having a problem with the newer Buster images, something that I’ve only seen before when I’d forget to remove my Beatstep Pro from the USB on first boot
Looks like the Jack server is unable to start - the screen flashes black each time Zynthian tries to start - and unlike the earlier releases the webconf interface isn’t starting so I can’t got to zynthian.local and select my custom settings for my unusual kit.
I can still SSH in.
My custom setup:
Pi 4 / Hifiberry Digi / Waveshare 4 / Mcp23017 Extra (custom INT pins)
Previously working on 2019-09-24-zynthianos-buster-lite-1.0.0-RC1
Log below:
X.Org X Server 1.20.4
Build Operating System: Linux 4.15.0-48-generic armv8l Raspbian
Current Operating System: Linux zynthian 4.19.75-v7l+ #1270 SMP Tue Sep 24 18:51:41 BST 2019 armv7l
Kernel command line: coherent_pool=1M 8250.nr_uarts=1 cma=64M bcm2708_fb.fbwidth=640 bcm2708_fb.fbheight=480 bcm2708_fb.fbswap=1 smsc95xx.macaddr=DC:A6:32:01:74:C9 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 dwc_otg.lpm_enable=0 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
Build Date: 05 June 2019 12:49:54PM
xorg-server 2:1.20.4-1+rpt1 (https://www.debian.org/support)
Current version of pixman: 0.36.0
Markers: (--) probed, (**) from config file, (==) default setting,
(==) Log file: "/var/log/Xorg.0.log", Time: Tue Oct 15 09:15:27 2019
(==) Using config directory: "/etc/X11/xorg.conf.d"
(==) Using system config directory "/usr/share/X11/xorg.conf.d"
INFO:root:ZYNTHIAN-UI CONFIG ...
INFO:root:Wiring Layout MCP23017_ZynScreen
DEBUG:root:ZYNCODER A: [102, 105, 110, 113]
DEBUG:root:ZYNCODER B: [101, 104, 109, 112]
DEBUG:root:SWITCHES layout: [100, 103, 108, 111, 106, 107, 114, 115]
DEBUG:root:DISABLED_MIDI_IN = ['']
DEBUG:root:ENABLED_MIDI_OUT = ['ttymidi:MIDI_out']
DEBUG:root:ENABLED_MIDI_FB = ['']
INFO:root:STARTING ZYNTHIAN-UI ...
Cannot connect to server socket err = No such file or directory
Cannot connect to server request channel
jack server is not running or cannot be started
JackShmReadWritePtr::~JackShmReadWritePtr - Init not done for -1, skipping unlock
libjackpeak failed to start jack client: 17
/zynthian/config/img/zynthian_logo_error_ip.png is 320x240 PNG image, color type RGB_ALPHA, 8 bit, file gamma 0.4546
PNG file: /zynthian/config/img/zynthian_logo_error_ip.png - Application must supply a known background gamma
Zooming image by 133%...done
Merging...done
didn't find evidence of prior run.
Building XImage...done
