gui working until i actually select the preset i want to play then i get the zynthian error screen. i am using raspberry pi 2 a hifiberry DAC light. i am using the gorgonilla image and have updated several times. any ideas?
login as: root
root@192.168.1.8’s password:
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Tue Aug 22 12:32:07 2017 from 192.168.1.5
root@zynthian:~# /zynthian/zynthian-sys/sbin/zynthian.sh
/zynthian/zynthian-sys/sbin/zynthian.sh: 3: /zynthian/zynthian-sys/sbin/zynthian .sh: source: not found
X.Org X Server 1.18.4
Release Date: 2016-07-19
Build Operating System: Linux 4.4.26-v7+ armv7l Raspbian
Current Operating System: Linux zynthian 4.4.38-v7+ #938 SMP Thu Dec 15 15:22:21 GMT 2016 armv7l
Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=1824 bcm2708_fb.fbhe ight=984 bcm2709.boardrev=0x2a01041 bcm2709.serial=0xe8625a9d smsc95xx.macaddr=B 8:27:EB:62:5A:9D bcm2708_fb.fbswap=1 bcm2709.uart_clock=2441000 bcm2709.disk_led gpio=47 bcm2709.disk_led_active_low=0 vc_mem.mem_base=0x3dc00000 vc_mem.mem_siz e=0x3f000000 dwc_otg.lpm_enable=0 console=tty1 root=/dev/mmcblk0p2 rootfstype=e xt4 elevator=deadline fsck.repair=yes rootwait
Build Date: 11 November 2016 11:59:59AM
xorg-server 2:1.18.4-2+rpi1 (https://www.debian.org/support)
Current version of pixman: 0.33.3
Markers: (–) probed, (**) from config file, (==) default setting,
(==) Log file: “/var/log/Xorg.0.log”, Time: Tue Aug 22 12:56:01 2017
(==) Using config directory: “/etc/X11/xorg.conf.d”
(==) Using system config directory “/usr/share/X11/xorg.conf.d”
./zynthian.sh: line 26: /etc/X11/zynthian: No such file or directory
INFO:root:Wiring Layout PROTOTYPE-3H
DEBUG:root:ZYNCODER A: [21, 27, 7, 3]
DEBUG:root:ZYNCODER B: [26, 25, 0, 4]
DEBUG:root:SWITCHES layout: [107, 23, 106, 2]
Zynswitches poll thread created successfully
MIDI tuning frequency: 440 Hz (8192)
INFO:root:SWITCHES INIT…
INFO:root:SETUP GPIO SWITCH 0 => 107
INFO:root:SETUP GPIO SWITCH 1 => 23
INFO:root:SETUP GPIO SWITCH 2 => 106
INFO:root:SETUP GPIO SWITCH 3 => 2
DEBUG:root:ZCTRL ‘Layer’: 0 (0 -> 2), None, None
ERROR:root:Can’t load snapshot ‘/zynthian/zynthian-ui/my-data/snapshots/default. zss’: [Errno 2] No such file or directory: ‘/zynthian/zynthian-ui/my-data/snapsh ots/default.zss’
DEBUG:root:ZCTRL ‘Snapshot’: 0 (0 -> 1), None, None
INFO:root:Short Switch 3
DEBUG:root:ZCTRL ‘Engine’: 0 (0 -> 5), None, None
INFO:root:NO REMOTE DISPLAY
INFO:root:Starting Engine ZynAddSubFX
INFO:root:OSC target in port 6693
INFO:root:OSC server running in port 13901
DEBUG:root:ZCTRL ‘Channel’: 0 (0 -> 16), None, None
DEBUG:root:FREE PARTS => [0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15]
DEBUG:root:ADD LAYER => PART 0
DEBUG:root:BANK LIST =>
[(’/zynthian/zynthian-ui/data/zynbanks/Arpeggios’, 0, ‘Arpeggios’, '’), (’/zynt hian/zynthian-ui/data/zynbanks/Bass’, 1, ‘Bass’, ‘’), (’/zynthian/zynthian-ui/d ata/zynbanks/Brass’, 2, ‘Brass’, '’), (’/zynthian/zynthian-ui/data/zynbanks/Cho ir and Voice’, 3, ‘Choir and Voice’, ‘’), (’/zynthian/zynthian-ui/data/zynbanks /Collection’, 4, ‘Collection’, '’), (’/zynthian/zynthian-ui/data/zynbanks/Compa nion’, 5, ‘Companion’, ‘’), (’/zynthian/zynthian-ui/data/zynbanks/Cormi_Noise’, 6, ‘Cormi Noise’, '’), (’/zynthian/zynthian-ui/data/zynbanks/Cormi_Sound’, 7, ‘Cormi Sound’, ‘’), (’/zynthian/zynthian-ui/data/zynbanks/Drums’, 8, ‘Drums’, ’ ‘), (’/zynthian/zynthian-ui/data/zynbanks/Dual’, 9, ‘Dual’, '’), (’/zynthian/z ynthian-ui/data/zynbanks/Fantasy’, 10, ‘Fantasy’, '’), (’/zynthian/zynthian-ui/ data/zynbanks/Guitar’, 11, ‘Guitar’, ‘’), (’/zynthian/zynthian-ui/data/zynbanks /Laba170bank’, 12, ‘Laba170bank’, '’), (’/zynthian/zynthian-ui/data/zynbanks/Mi sc’, 13, ‘Misc’, ‘’), (’/zynthian/zynthian-ui/data/zynbanks/Noises’, 14, ‘Noise s’, '’), (’/zynthian/zynthian-ui/data/zynbanks/Organ’, 15, ‘Organ’, ‘’), (’/zy nthian/zynthian-ui/data/zynbanks/Pads’, 16, ‘Pads’, '’), (’/zynthian/zynthian-u i/data/zynbanks/Plucked’, 17, ‘Plucked’, ‘’), (’/zynthian/zynthian-ui/data/zynb anks/Reed and Wind’, 18, ‘Reed and Wind’, '’), (’/zynthian/zynthian-ui/data/zyn banks/Rhodes’, 19, ‘Rhodes’, ‘’), (’/zynthian/zynthian-ui/data/zynbanks/Splitte d’, 20, ‘Splitted’, '’), (’/zynthian/zynthian-ui/data/zynbanks/Strings’, 21, ‘S trings’, ‘’), (’/zynthian/zynthian-ui/data/zynbanks/Synth’, 22, ‘Synth’, '’), (’/zynthian/zynthian-ui/data/zynbanks/SynthPiano’, 23, ‘SynthPiano’, ‘’), (’/zy nthian/zynthian-ui/data/zynbanks/net-wisdom’, 24, ‘net-wisdom’, '’), (’/zynthia n/zynthian-ui/data/zynbanks/olivers-100’, 25, ‘olivers-100’, ‘’), (’/zynthian/z ynthian-ui/data/zynbanks/olivers-other’, 26, ‘olivers-other’, '’), (’/zynthian/ zynthian-ui/data/zynbanks/the_mysterious_bank’, 27, ‘the mysterious bank’, ‘’), (’/zynthian/zynthian-ui/data/zynbanks/the_mysterious_bank_2’, 28, ‘the mysterio us bank 2’, '’), (’/zynthian/zynthian-ui/data/zynbanks/the_mysterious_bank_3’, 29, ‘the mysterious bank 3’, ‘’), (’/zynthian/zynthian-ui/data/zynbanks/the_mys terious_bank_4’, 30, ‘the mysterious bank 4’, '’)]
DEBUG:root:BANK INDEX => 0
[(’/zynthian/zynthian-ui/data/zynbanks/Arpeggios’, 0, ‘Arpeggios’, ‘’), (’/zynt hian/zynthian-ui/data/zynbanks/Bass’, 1, ‘Bass’, '’), (’/zynthian/zynthian-ui/d ata/zynbanks/Brass’, 2, ‘Brass’, ‘’), (’/zynthian/zynthian-ui/data/zynbanks/Cho ir and Voice’, 3, ‘Choir and Voice’, '’), (’/zynthian/zynthian-ui/data/zynbanks /Collection’, 4, ‘Collection’, ‘’), (’/zynthian/zynthian-ui/data/zynbanks/Compa nion’, 5, ‘Companion’, '’), (’/zynthian/zynthian-ui/data/zynbanks/Cormi_Noise’, 6, ‘Cormi Noise’, ‘’), (’/zynthian/zynthian-ui/data/zynbanks/Cormi_Sound’, 7, ‘Cormi Sound’, '’), (’/zynthian/zynthian-ui/data/zynbanks/Drums’, 8, ‘Drums’, ’ ‘), (’/zynthian/zynthian-ui/data/zynbanks/Dual’, 9, ‘Dual’, '’), (’/zynthian/z ynthian-ui/data/zynbanks/Fantasy’, 10, ‘Fantasy’, ‘’), (’/zynthian/zynthian-ui/ data/zynbanks/Guitar’, 11, ‘Guitar’, '’), (’/zynthian/zynthian-ui/data/zynbanks /Laba170bank’, 12, ‘Laba170bank’, ‘’), (’/zynthian/zynthian-ui/data/zynbanks/Mi sc’, 13, ‘Misc’, '’), (’/zynthian/zynthian-ui/data/zynbanks/Noises’, 14, ‘Noise s’, ‘’), (’/zynthian/zynthian-ui/data/zynbanks/Organ’, 15, ‘Organ’, '’), (’/zy nthian/zynthian-ui/data/zynbanks/Pads’, 16, ‘Pads’, ‘’), (’/zynthian/zynthian-u i/data/zynbanks/Plucked’, 17, ‘Plucked’, '’), (’/zynthian/zynthian-ui/data/zynb anks/Reed and Wind’, 18, ‘Reed and Wind’, ‘’), (’/zynthian/zynthian-ui/data/zyn banks/Rhodes’, 19, ‘Rhodes’, '’), (’/zynthian/zynthian-ui/data/zynbanks/Splitte d’, 20, ‘Splitted’, ‘’), (’/zynthian/zynthian-ui/data/zynbanks/Strings’, 21, ‘S trings’, '’), (’/zynthian/zynthian-ui/data/zynbanks/Synth’, 22, ‘Synth’, ‘’), (’/zynthian/zynthian-ui/data/zynbanks/SynthPiano’, 23, ‘SynthPiano’, '’), (’/zy nthian/zynthian-ui/data/zynbanks/net-wisdom’, 24, ‘net-wisdom’, ‘’), (’/zynthia n/zynthian-ui/data/zynbanks/olivers-100’, 25, ‘olivers-100’, '’), (’/zynthian/z ynthian-ui/data/zynbanks/olivers-other’, 26, ‘olivers-other’, ‘’), (’/zynthian/ zynthian-ui/data/zynbanks/the_mysterious_bank’, 27, ‘the mysterious bank’, '’), (’/zynthian/zynthian-ui/data/zynbanks/the_mysterious_bank_2’, 28, ‘the mysterio us bank 2’, ‘’), (’/zynthian/zynthian-ui/data/zynbanks/the_mysterious_bank_3’, 29, ‘the mysterious bank 3’, '’), (’/zynthian/zynthian-ui/data/zynbanks/the_mys terious_bank_4’, 30, ‘the mysterious bank 4’, ‘_’)]
DEBUG:root:ZCTRL ‘Bank’: 0 (0 -> 31), None, None
INFO:root:Bank Selected: Arpeggios (0)
DEBUG:root:Set MIDI CH 0, Bank MSB: 0
INFO:root:Getting Preset List for Arpeggios
DEBUG:root:PRESET LIST =>
[(’/zynthian/zynthian-ui/data/zynbanks/Arpeggios/0001-Arpeggio1.xiz’, [0, 0, 0], ‘Arpeggio1’), (’/zynthian/zynthian-ui/data/zynbanks/Arpeggios/0002-Arpeggio2.xi z’, [0, 0, 1], ‘Arpeggio2’), (’/zynthian/zynthian-ui/data/zynbanks/Arpeggios/000 3-Arpeggio3.xiz’, [0, 0, 2], ‘Arpeggio3’), (’/zynthian/zynthian-ui/data/zynbanks /Arpeggios/0004-Arpeggio4.xiz’, [0, 0, 3], ‘Arpeggio4’), (’/zynthian/zynthian-ui /data/zynbanks/Arpeggios/0005-Arpeggio5.xiz’, [0, 0, 4], ‘Arpeggio5’), (’/zynthi an/zynthian-ui/data/zynbanks/Arpeggios/0006-Aporggio6.xiz’, [0, 0, 5], ‘Aporggio 6’), (’/zynthian/zynthian-ui/data/zynbanks/Arpeggios/0007-Arpeggio7.xiz’, [0, 0, 6], ‘Arpeggio7’), (’/zynthian/zynthian-ui/data/zynbanks/Arpeggios/0008-Arpeggio 8.xiz’, [0, 0, 7], ‘Arpeggio8’), (’/zynthian/zynthian-ui/data/zynbanks/Arpeggios /0009-Arpeggio9.xiz’, [0, 0, 8], ‘Arpeggio9’), (’/zynthian/zynthian-ui/data/zynb anks/Arpeggios/0010-Arpeggio10.xiz’, [0, 0, 9], ‘Arpeggio10’), (’/zynthian/zynth ian-ui/data/zynbanks/Arpeggios/0011-Arpeggio11.xiz’, [0, 0, 10], ‘Arpeggio11’), (’/zynthian/zynthian-ui/data/zynbanks/Arpeggios/0033-Sequence1.xiz’, [0, 0, 32], ‘Sequence1’), (’/zynthian/zynthian-ui/data/zynbanks/Arpeggios/0034-Sequence2.xi z’, [0, 0, 33], ‘Sequence2’), (’/zynthian/zynthian-ui/data/zynbanks/Arpeggios/00 36-Echoed Synth.xiz’, [0, 0, 35], ‘Echoed Synth’), (’/zynthian/zynthian-ui/data/ zynbanks/Arpeggios/0037-Echo FX.xiz’, [0, 0, 36], ‘Echo FX’), (’/zynthian/zynthi an-ui/data/zynbanks/Arpeggios/0039-Soft Arpeggio1.xiz’, [0, 0, 38], ‘Soft Arpegg io1’), (’/zynthian/zynthian-ui/data/zynbanks/Arpeggios/0040-Soft Arpeggio2.xiz’, [0, 0, 39], ‘Soft Arpeggio2’), (’/zynthian/zynthian-ui/data/zynbanks/Arpeggios/ 0041-Soft Arpeggio3.xiz’, [0, 0, 40], ‘Soft Arpeggio3’), (’/zynthian/zynthian-ui /data/zynbanks/Arpeggios/0042-Soft Arpeggio4.xiz’, [0, 0, 41], ‘Soft Arpeggio4’) , (’/zynthian/zynthian-ui/data/zynbanks/Arpeggios/0043-Soft Arpeggio5.xiz’, [0, 0, 42], ‘Soft Arpeggio5’), (’/zynthian/zynthian-ui/data/zynbanks/Arpeggios/0065- Hyper Organ1.xiz’, [0, 0, 64], ‘Hyper Organ1’), (’/zynthian/zynthian-ui/data/zyn banks/Arpeggios/0066-Hyper Arpeggio.xiz’, [0, 0, 65], ‘Hyper Arpeggio’), (’/zynt hian/zynthian-ui/data/zynbanks/Arpeggios/0068-Glass Arpeggio1.xiz’, [0, 0, 67], ‘Glass Arpeggio1’), (’/zynthian/zynthian-ui/data/zynbanks/Arpeggios/0069-Glass A rpeggio2.xiz’, [0, 0, 68], ‘Glass Arpeggio2’)]
DEBUG:root:ZCTRL ‘Preset’: 0 (0 -> 24), None, None
INFO:root:Preset Selected: Arpeggio1 (0)
DEBUG:root:SET CONTROLLER SCREEN main
DEBUG:root:ZCTRL ‘volume’: 96 (0 -> 127), None, None
DEBUG:root:ZCTRL ‘pan’: 64 (0 -> 127), None, None
DEBUG:root:ZCTRL ‘cutoff’: 64 (0 -> 127), None, None
gpio: Unable to open GPIO direction interface for pin 17: No such file or direct ory
wiringPiISR: unable to open /sys/class/gpio/gpio17/value: No such file or direct ory
ERROR:root:Can’t load snapshot ‘/zynthian/zynthian-ui/my-data/snapshots/default. zss’: [Errno 2] No such file or directory: '/zynthian/zynthian-ui/my-data/snapsh ots/default.zss’
Hi @martindunne!
Have you configured your audio device as an “HifiBerry DAC+ light”?
If not, you should do it. The easiest way is using the webconf tool by accesing your Zynthian Box form your browser. See the wiki:
Thank you for your quick response. yes i have configured my audio device as hifiberry dac+ light, my display as waveshare 4" gpio and wiring as prototype 3H, although i have only connected encoders for select and back would that make a difference.
many thanks
Please, send your “/boot/config.txt”. Also verify that jackd is running (pstree).
Finally, you can run the Zynthian UI from the command line to see the logs:
systemctl stop zynthian
What makes you sure, that this prototype works?
I am using a waveshare3.2 and had to come up with my own wiring: 4_WS.
Markus
sorry for the slow reply. here is my config file
For more options and information see
http://www.raspberrypi.org/documentation/configuration/config-txt.md
Some settings may impact device functionality. See link above for details
Tell bootloader to use initram image
#initramfs initrd.img-4.1.13-v7+
Load RT Kernel for RBPI2
#kernel=kernel7-rt.img
uncomment if you get no picture on HDMI for a default “safe” mode
#hdmi_safe=1
uncomment this if your display has a black border of unused pixels visible
and your display can output without overscan
#disable_overscan=1
uncomment the following to adjust overscan. Use positive numbers if console
goes off screen, and negative if there is too much border
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
uncomment to force a console size. By default it will be display’s size minus
overscan.
#framebuffer_width=1280
#framebuffer_height=720
uncomment if hdmi display is not detected and composite is being output
#hdmi_force_hotplug=1
uncomment to force a specific HDMI mode (this will force VGA)
#hdmi_group=1
#hdmi_mode=1
uncomment to force a HDMI mode rather than DVI. This can make audio work in
DMT (computer monitor) modes
#hdmi_drive=2
uncomment to increase signal to HDMI, if you have interference, blanking, or
no display
#config_hdmi_boost=4
uncomment for composite PAL
#sdtv_mode=2
Disable Splash Screen
disable_splash=1
Disables dynamic frequency clocking
force_turbo=1
Uncomment to overclock the arm. 700 MHz is the default.
[pi2]
arm_freq=900
core_freq=250
sdram_freq=450
over_voltage=2
[all]
Uncomment some or all of these to enable the optional hardware interfaces
dtparam=i2c_arm=on
dtparam=i2s=on
dtparam=spi=on
Uncomment this to enable the lirc-rpi module
#dtoverlay=lirc-rpi
Additional overlays and parameters are documented /boot/overlays/README
Disable Blutooth Support for HifiBerry compatibility with RBPi 3
Swap back the ttyAMA0 to GPIO
[pi3]
dtoverlay=pi3-disable-bt
dtoverlay=pi3-miniuart-bt
[all]
Enable MMAP support (Jackd, etc.)
dtoverlay=i2s-mmap
Soundcard Config
dtoverlay=hifiberry-dac
Display Config
dtoverlay=waveshare35a:rotate=90
dtoverlay=ads7846,cs=1,penirq=17,penirq_pull=2,speed=1000000,keep_vref_on=1,swapxy=0,pmax=255,xohms=60,xmin=200,xmax=3900,ymin=200,ymax=3900
Adjust Serial Port Clock to allow MIDI baudrate 31250
[pi2]
init_uart_clock=2441000
init_uart_baud=38400
dtparam=uart0_clkrate=3000000
[pi3]
init_uart_clock=39062500
dtparam=uart0_clkrate=48000000
[all]
i think mheidt is correct, but i have tried all wiring prototypes. i dont think i have enough spare gpio to connect encoders. this works but i only have half the connections
You could try _WS32 and the following wiring:
still no joy i can get to the sound control section if i use hdmi for display.
Could you post a picture of your wiring?
hi there sorry for the long pause. i have decided to go for the mcp23017 option as i think my problems were to do with spare GPIO pins.i followed these build instructions: https://github.com/beckdac/zynthian-build/tree/master/case/mcp23017_encoders, and attached to wiring pi 25 and 27( which are physical pins 36-37) but still no joy. when i select mcp23017 encoders in webui i get the same zynthian error screen.
pstree is
systemd─┬─agetty
├─avahi-daemon───avahi-daemon
├─dbus-daemon
├─dhcpcd
├─htpdate
├─jackd───6*[{jackd}]
├─sshd───sshd───bash───pstree
├─startx───xinit─┬─Xorg
│ └─zynthian.sh───
zynthian_gui.py───11*[{zynthian_gui.py+
├─systemd───(sd-pam)
├─systemd-journal
├─systemd-logind
├─systemd-udevd
├─ttymidi───5*[{ttymidi}]
└─zynthian_webcon───zynthian_webcon
(==) Log file: “/var/log/Xorg.0.log”, Time: Thu Aug 31 19:14:23 2017
INFO:root:Wiring Layout MCP23017_ENCODERS
DEBUG:root:ZYNCODER A: [100, 103, 108, 111]
DEBUG:root:ZYNCODER B: [101, 104, 109, 112]
DEBUG:root:SWITCHES layout: [102, 105, 110, 113]
Zyncoder: Zynswitches poll thread created successfully
Zyncoder: MIDI tuning frequency set to 440 Hz (8192)
INFO:root:SETUP GPIO SWITCH 0 => 102
INFO:root:SETUP GPIO SWITCH 1 => 105
INFO:root:SETUP GPIO SWITCH 2 => 110
INFO:root:SETUP GPIO SWITCH 3 => 113
wiringPiISR: pin must be 0-63 (111)
Pls send a photo of your wiring
i apologise for the photos i think everything is in order thank you for the help by the way
root@zynthian:~# sudo i2cdetect -y 1
0 1 2 3 4 5 6 7 8 9 a b c d e f
00: – -- – -- – -- – -- – -- – -- –
10: – -- – -- – -- – -- – -- – -- – -- – --
20: 20 – -- – -- – -- – -- – -- – -- – -- –
30: – -- – -- – -- – -- – -- – -- – -- – --
40: – -- – -- – -- – -- – -- – -- – -- – --
50: – -- – -- – -- – -- – -- – -- – -- – --
60: – -- – -- – -- – -- – -- – -- – -- – --
70: – -- – -- – -- – --
could these update errors be part of the problem
– Build files have been written to: /zynthian/zyncoder/build
[ 25%] Building C object CMakeFiles/zyncoder.dir/zyncoder.c.o
/zynthian/zyncoder/zyncoder.c:46:25: fatal error: mcp23x0817.h: No such file or directory
#include <mcp23x0817.h>
compilation terminated.
CMakeFiles/zyncoder.dir/build.make:62: recipe for target ‘CMakeFiles/zyncoder.dir/zyncoder.c.o’ failed
make[2]: *** [CMakeFiles/zyncoder.dir/zyncoder.c.o] Error 1
CMakeFiles/Makefile2:104: recipe for target ‘CMakeFiles/zyncoder.dir/all’ failed
make[1]: *** [CMakeFiles/zyncoder.dir/all] Error 2
Makefile:127: recipe for target ‘all’ failed
make: *** [all] Error 2
Updating zynthian-ui …
Already up-to-date.
Updating zynthian-webconf …
remote: Counting objects: 16, done.
remote: Total 16 (delta 10), reused 10 (delta 10), pack-reused 6
Unpacking objects: 100% (16/16), done.
From https://github.com/zynthian/zynthian-webconf
- [new branch] SoundfontUpload -> origin/SoundfontUpload
Already up-to-date.
root@zynthian:~#
Hi @martindunne!
Are you using a Gorgona image?
You have to update (probably twice) before you get updated to the last version.
The file “mcp23x0817.h” is included in all recent WiringPi releases, so it should be there. If not, try to install/update the wiring pi development packages, although it should be installed by default in Gorgona images.
I reinstalled recently and haven’t found the file either
OK! You are right, an upgrade is needed in order to get the last wiringpi version. I’ve patched the system scripts.
Please, confirm
