hi, I am new to Zynthan and it is a really cool project, there is a problem when I try to select LinuxSampler
After selecting the engine selected “Linux Sampler”, it lets me to select the bank (in emulator) and I selected “1>”
However, it did not let me to select the GIG files in the directory
Error returned from application
Getting Bank List for LinuxSampler
ERROR: zynthian_gui.zyncoder_read() => list index out of range (it was not shown when I am using fluidsynth)
After tracing the source code, the problem should be in the function “load_bank_dirlist” in zynthian_engine.py which is used in LinuxSampler (not in Fluidsynth)
Any clue?
Francis
P.S. it seems that we can simplify the startup of emulator by updating the /home/pi/zynthian/zynthian-emuface/zynthian_gui_emu.sh (no need to start with 4 terminals)
#!/bin/bash
#start Alsa -> jack midi bridge and auto-connect
(sleep 5; /usr/bin/a2jmidid -e )&
(sleep 5; /home/pi/zynthian/zynthian-ui/zynthian_autoconnect_jack.py) &
I have not much time to check on my Zynthian. Do you have tried to update the software? Try to press controller 2 (back) until you get some menu entries called “Update *”. DO NOT UPDATE THE SYSTEM! (sorry, I think this is currently broken and will be fixed soon - I hope). I you have done this: write an new SD image- sorry, you can’t go back… But you can do the other updates. Reboot and try again.
If I have time I will take a look at this at weekend.
@C0d3man, I think @Xellosdark’s question is about the Zynthian emulator, not a real “hardware zynthian” unit
@Xellosdark, for me, emulator is working perfectly and can’t reproduce the error. Are you using the last version from repository (master branch)? Have you checked file/directory permissions in soundfont directory?
Regarding your improved script for avoiding opening 3 terminals, take into account that Zynthian Emulator is used for developping the Zynthian’s software, not for playing, so, the 3 terminals are desirable as you get separated output from each program. Anyway, thanks for the script! Perhaps some emulator users would like to use it
Thanks for the advice and let me try to update the scripts soon (in fact, I have download the script from git yesterday)
Currently, I am building my zynthian with using Raspberry 7" LCD + my old SoundBlaster THX (USB) + midi cable and this is the reason why I am using emulator as the UI (and the emulator is wonderful for my case)
For zynaddsubfx, maybe it is because the my setting of remote display is not correct, my setting does not fit the requirement of self.config_remote_display, please ignore the previous message
