Delete it!
OK. the following without guarantee:
e.g. for surge:
copy your presets to:
/ home / pi / zynthian-my-data / presets / lv2 /
then make a copy of the following file to be on the safe side .
/home/pi/config/jalv/presets_Surge.json
then delete this file, the next time the plugin is initiated, presets_Surge.json will be rewritten.
You can also click the “Search for Plugins & Presets” button, on the webconf’s LV2 panel
By doing in such a way, the file is generated, but webconf & UI don’t reload the newly generated file and need to restart. I will fix it ASAP …
Deleting it worked!
I’m looking forward to your new sounds
Not new sounds, I updated to the new image and was copying across. Here’s a linked upload typical of my average output though. Boot Zynthian from USB SSD
