Iv’e just updated an ancient machine with audio injector zero i/o encoders & Pi3B+ ( zynthian-alm.local).
What I do get is a crash when I try to record …
Hi Wyleu,
Thanks for your answer,
On my side I have :
I tryed to record: I have no problem with recording.
I could create effect layer as well now (my initial problem was fixed with buster)
Just remains a problem with encoders.
Midi In is Ok so I imagine that the “all in one board” is detected.
What do you mean by:
How can I check it ?
Nothing much, I have five 3B machines of various types. The machine I’ve had most encoder trouble has been zynthian-amp2.local which has a zynth encoder board on it. I spent a long while to get the encoders on this just not working. It came back to life when I put a new image on it.
However at the moment it’s failing with No module lilv messages that have reported here and because it kills webconf it’s not easy to update it, so I can’t check that the encoders are working yet. But I’ll get it done at some point.
jRhodes
Noize Mak3r - KB Smooth Sine TAL
Synthv1 3925Synthv1patches/ClassicBassSynth
I eq the lower end of the bass patch up quite a bit
Hello,
Thanks for your answer.
I made some other tests:
Fresh Aruk RC3: Webconf is not working, encoders are OK.
Aruk RC3 + update : Webconf is OK but LV2 are not working.
Recent build from the 28/02/2020 + update: Problem described in this thread
(seting kit V2 in webcong has no effect : encoder are not working, lv2 are ok)
Fresh Buster RC1: Webconf and Encoders are not working.
Buster RC1 + update: I can access to webconf, set Kit V2, then I get encoders working. LV2 are also working. All problem are fixed in this configuration
29/02 + Update ist perfectly working for me
I tried to upload some puredata patches via webconf. It didnt work with 29.2. But uploading the patches via sftp worked.
then you should open a bug in github and provide the files
Time has come when Zynthian team deserves some samples !
That’s rather excellently weird !!
I tried again. And this time it worked! Will try to replicate the failure.
Hello,
updated today. Unfortunately pure data does not work for me anymore. Generative relaxing (and all others) - no sound. Did update, then upload some patches and test after. Any ideas?
which img version exactly do you use?
I use Aruk Stretch if that is what you are referring too? Where can I find more precise data if that is what you are asking for?
Please, consider change to Buster. Latest “green” nightly builds are working quite well and RC-2 is almost here. The problem is that i don’t have enough BW in MasFort for downloading and testing nightly builds.
Thanks for the advice, was already thinking to do so. Could you provide me with a working link? All links in the wiki are broken…
How do you manually rebuild this cache? I’ve scp’d a bunch of lv2 presets in and they’re not showing up?
I think I found out recently. Should I disclose it or do we wait for the more qualified, detailed answer?
Ship it!
