Zynthian freezes / UI lag when loading some LinuxSampler presets
When I load some default presets in LinuxSampler, Zynthian gets stuck and no sound is produced. The UI also becomes slow and laggy, and I usually need to restart the audio engine or reboot.
Is this a known issue with LinuxSampler on Zynthian?
How can I fix or avoid this problem?
Thanks.
Please give an example of a preset / soundfont that triggers this issue.
its getting stuck when i select presets under strings category
i think mainly when i select SCC Expressive strings/SCC Expressive Strings
