Hi, again
This configuration web page does not work. I am not able to change my sound card I have changed physically.
Other sites work.
Hi, again
Other sites work.
Strange! It works for me. Could you send the webconf logs? From the terminal:
journalctl -u zynthian-webconf -f
and then provoke the error and copy/paste the error log from the terminal
â Logs begin at Thu 2019-02-14 10:12:00 GMT. â
Feb 10 21:13:20 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: ZYNTHIAN_MIDI_PROG_CHANGE_ZS3=1
Feb 10 21:13:20 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: ZYNTHIAN_MIDI_MASTER_PROGRAM_CHANGE_UP=
Feb 10 21:13:20 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: ZYNTHIAN_MIDI_MASTER_BANK_CHANGE_CCNUM=0
Feb 10 21:13:20 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: ZYNTHIAN_MIDI_MASTER_BANK_CHANGE_DOWN=
Feb 10 21:13:20 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: ZYNTHIAN_MIDI_PRESET_PRELOAD_NOTEON=1
Feb 10 21:13:20 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: ZYNTHIAN_MIDI_AUBIONOTES_ENABLED=0
Feb 10 21:13:20 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: ZYNTHIAN_MIDI_FINE_TUNING=440
Feb 10 21:13:20 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: ZYNTHIAN_MIDI_MASTER_PROGRAM_CHANGE_TYPE=Custom
Feb 10 21:13:20 zynthian zynthian_webconf.sh[382]: INFO:tornado.access:302 GET /sys-reboot (2001:a62:1ad5:8701:c82b:3d2e:81bf:9172) 172.39ms
Feb 10 21:13:20 zynthian zynthian_webconf.sh[382]: INFO:tornado.access:200 GET /login?next=%2Fsys-reboot (2001:a62:1ad5:8701:c82b:3d2e:81bf:9172) 9. 85ms
Feb 10 21:20:05 zynthian zynthian_webconf.sh[382]: /zynthian/config/zynthian_envars.sh: line 2: 000#****************************************************************************: command not found
Feb 10 21:20:05 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: CFLAGS_UNSAFE=
Feb 10 21:20:05 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: ZYNTHIAN_WIRING_CUSTOM_SWITCH_03__UI_SHORT=NONE
Feb 10 21:20:05 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: ZYNTHIAN_WIRING_ENCODER_A=0,0,0,0
Feb 10 21:20:05 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: ZYNTHIAN_WIRING_ENCODER_B=0,0,0,0
Feb 10 21:20:05 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: SOUNDCARD_CONFIG=dtoverlay=hifiberry-dacplusadcpro
Feb 10 21:20:05 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: ZYNTHIAN_LIMIT_USB_SPEED=0
Feb 10 21:20:05 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: ZYNTHIAN_PLUGINS_SRC_DIR=/zynthian/zynthian-sw/plugins
Feb 10 21:20:05 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: ZYNTHIAN_WIRING_CUSTOM_SWITCH_01__UI_SHORT=NONE
Feb 10 21:20:05 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: ZYNTHIAN_UI_RESTORE_LAST_STATE=1
Feb 10 21:20:05 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: ZYNTHIAN_UI_FONT_SIZE=14
Feb 10 21:20:05 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: ZYNTHIAN_DATA_DIR=/zynthian/zynthian-data
Feb 10 21:20:05 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: ZYNTHIAN_WIRING_CUSTOM_SWITCH_03__MIDI_CHAN=Active
Feb 10 21:20:05 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: ZYNTHIAN_WIRING_CUSTOM_SWITCH_01__UI_LONG=NONE
Feb 10 21:20:05 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: JACKD_OPTIONS=-P 70 -t 2000 -s -d alsa -d hw:sndrpihifiberry -S -r 44100 -p 256 -n 2 -X raw
Feb 10 21:20:05 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: ZYNTHIAN_UI_SNAPSHOT_MIXER_SETTINGS=0
Feb 10 21:20:05 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: ZYNTHIAN_WIRING_CUSTOM_SWITCH_04__MIDI_NUM=4
Feb 10 21:20:05 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: ZYNTHIAN_WIRING_CUSTOM_SWITCH_03=MIDI_PROG_CHANGE
Feb 10 21:20:05 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: ZYNTHIAN_UI_COLOR_TX=#ffffff
Feb 10 21:20:05 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: ZYNTHIAN_WIRING_CUSTOM_SWITCH_02=MIDI_PROG_CHANGE
Feb 10 21:20:05 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: ZYNTHIAN_WIRING_CUSTOM_SWITCH_01=MIDI_PROG_CHANGE
Feb 10 21:20:05 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: ZYNTHIAN_WIRING_CUSTOM_SWITCH_04=MIDI_PROG_CHANGE
Feb 10 21:20:05 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: ZYNTHIAN_UI_SWITCH_LONG_MS=2000
Feb 10 21:20:05 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: ZYNTHIAN_WIRING_CUSTOM_SWITCH_04__MIDI_CHAN=Active
Feb 10 21:20:05 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: ZYNTHIAN_SCRIPT_MIDI_PROFILE=/zynthian/config/midi-profiles/default.sh
Feb 10 21:20:05 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: CXXFLAGS=-mcpu=cortex-a53 -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mneon-for-64bits -mfloat-abi=hard -mlittle-endian -munaligned-access -mvectorize-with-neon-quad -ftree-vectorize
Feb 10 21:20:05 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: ZYNTHIAN_UI_COLOR_ON=#ff0000
Feb 10 21:20:05 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: ZYNTHIAN_WIRING_CUSTOM_SWITCH_02__UI_BOLD=NONE
Feb 10 21:20:05 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: ZYNTHIAN_WIRING_CUSTOM_SWITCH_02__MIDI_CHAN=Active
Feb 10 21:20:05 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: ZYNTHIAN_WIRING_ZYNAPTIK_CONFIG=
Feb 10 21:20:05 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: ZYNTHIAN_EX_DATA_DIR=/media/usb0
Feb 10 21:20:05 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: ZYNTHIAN_WIRING_CUSTOM_SWITCH_03__MIDI_NUM=3
Feb 10 21:20:05 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: ZYNTHIAN_WIRING_SWITCHES=0,0,0,0
Feb 10 21:20:05 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: ZYNTHIAN_PLUGINS_DIR=/zynthian/zynthian-plugins
Feb 10 21:20:05 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: ZYNTHIAN_WIRING_MCP23017_INTB_PIN=
Feb 10 21:20:05 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: ZYNTHIAN_WIRING_CUSTOM_SWITCH_01__MIDI_NUM=1
Feb 10 21:20:05 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: ZYNTHIAN_WIRING_CUSTOM_SWITCH_03__UI_BOLD=NONE
Feb 10 21:20:05 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: ZYNTHIAN_UI_COLOR_BG=#000000
Feb 10 21:20:05 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: ZYNTHIAN_SYS_DIR=/zynthian/zynthian-sys
Feb 10 21:20:05 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: ZYNTHIAN_WIRING_CUSTOM_SWITCH_02__MIDI_NUM=2
Feb 10 21:20:05 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: ZYNTHIAN_WIRING_CUSTOM_SWITCH_04__UI_BOLD=NONE
Feb 10 21:20:05 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: SOUNDCARD_MIXER=Digital Left,ADC Left,Digital Right,ADC Right,ADC Left Input,ADC Right Input
Feb 10 21:20:05 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: ZYNTHIAN_UI_ENABLE_CURSOR=1
Feb 10 21:20:05 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: DISPLAY_WIDTH=
Feb 10 21:20:05 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: ZYNTHIAN_VNCSERVER_ENABLED=1
Feb 10 21:20:05 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: ZYNTHIAN_UI_TOUCH_WIDGETS=1
Feb 10 21:20:05 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: ZYNTHIAN_WIRING_MCP23017_INTA_PIN=
Feb 10 21:20:05 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: ZYNTHIAN_WIFI_MODE=off
Feb 10 21:20:05 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: ZYNTHIAN_KIT_VERSION=Custom
Feb 10 21:20:05 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: RASPI=true
Feb 10 21:20:05 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: ZYNTHIAN_WIRING_CUSTOM_SWITCH_03__UI_LONG=NONE
Feb 10 21:20:05 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: DISPLAY_HEIGHT=
Feb 10 21:20:05 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: MACHINE_HW_NAME=armv7l
Feb 10 21:20:05 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: ZYNTHIAN_UI_DIR=/zynthian/zynthian-ui
Feb 10 21:20:05 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: ZYNTHIAN_UI_SHOW_CPU_STATUS=0
Feb 10 21:20:05 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: ZYNTHIAN_SW_DIR=/zynthian/zynthian-sw
Feb 10 21:20:05 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: SOUNDCARD_NAME=HifiBerry DAC+ ADC PRO
Feb 10 21:20:05 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: ZYNTHIAN_WIRING_CUSTOM_SWITCH_01__MIDI_CHAN=Active
Feb 10 21:20:05 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: ZYNTHIAN_WIRING_CUSTOM_SWITCH_01__UI_BOLD=NONE
Feb 10 21:20:05 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: RBPI_VERSION=Raspberry Pi 3 Model B Plus Rev 1.3
Feb 10 21:20:05 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: ZYNTHIAN_WIRING_CUSTOM_SWITCH_02__UI_LONG=NONE
Feb 10 21:20:05 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: ZYNTHIAN_WIRING_LAYOUT=DUMMIES
Feb 10 21:20:05 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: ZYNTHIAN_WIRING_ZYNTOF_CONFIG=
Feb 10 21:20:05 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: ZYNTHIAN_CONFIG_DIR=/zynthian/config
Feb 10 21:20:05 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: ZYNTHIAN_UI_COLOR_PANEL_BG=#3a424d
Feb 10 21:20:05 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: ZYNTHIAN_MY_DATA_DIR=/zynthian/zynthian-my-data
Feb 10 21:20:05 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: DISPLAY_NAME=Generic HDMI Display
Feb 10 21:20:05 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: ZYNTHIAN_WIRING_CUSTOM_SWITCH_02__UI_SHORT=NONE
Feb 10 21:20:05 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: ZYNTHIAN_SETUP_APT_CLEAN=TRUE
Feb 10 21:20:05 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: ZYNTHIAN_WIRING_CUSTOM_SWITCH_04__UI_SHORT=NONE
Feb 10 21:20:05 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: CFLAGS=-mcpu=cortex-a53 -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mneon-for-64bits -mfloat-abi=hard -mlittle-endian -munaligned-access -mvectorize-with-neon-quad -ftree-vectorize
Feb 10 21:20:05 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: ZYNTHIAN_UI_SWITCH_BOLD_MS=300
Feb 10 21:20:05 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: DISPLAY_CONFIG=disable_overscan=1\n\noverscan_left=50\noverscan_right=50\noverscan_top=50\noverscan_bottom=50\n
Feb 10 21:20:05 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: ZYNTHIAN_UI_FONT_FAMILY=Audiowide
Feb 10 21:20:05 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: LV2_PATH=/usr/lib/lv2:/usr/lib/arm-linux-gnueabihf/lv2:/usr/local/lib/lv2:/zynthian/zynthian-plugins/lv2:/zynthian/zynthian-data/presets/lv2:/zynthian/zynthian-my-data/presets/lv2
Feb 10 21:20:05 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: ZYNTHIAN_UI_ONSCREEN_BUTTONS=1
Feb 10 21:20:05 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: ZYNTHIAN_DIR=/zynthian
Feb 10 21:20:05 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: FRAMEBUFFER=/dev/fb0
Feb 10 21:20:05 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: ZYNTHIAN_WIRING_CUSTOM_SWITCH_04__UI_LONG=NONE
Feb 10 21:20:05 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: ZYNTHIAN_RECIPE_DIR=/zynthian/zynthian-sys/scripts/recipes
Feb 10 21:20:05 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: ZYNTHIAN_AUBIONOTES_OPTIONS=-O complex -t 0.5 -s -88 -p yinfft -l 0.5
Feb 10 21:20:06 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: ZYNTHIAN_MIDI_MASTER_BANK_CHANGE_UP=
Feb 10 21:20:06 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: ZYNTHIAN_MIDI_SYS_ENABLED=1
Feb 10 21:20:06 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: ZYNTHIAN_MIDI_MASTER_PROGRAM_CHANGE_DOWN=
Feb 10 21:20:06 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: ZYNTHIAN_MIDI_SINGLE_ACTIVE_CHANNEL=1
Feb 10 21:20:06 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: ZYNTHIAN_MIDI_RTPMIDI_ENABLED=0
Feb 10 21:20:06 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: ZYNTHIAN_MIDI_TOUCHOSC_ENABLED=0
Feb 10 21:20:06 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: ZYNTHIAN_MIDI_PORTS=DISABLED_IN=\nENABLED_OUT=ttymidi:MIDI_out\nENABLED_FB=
Feb 10 21:20:06 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: ZYNTHIAN_MIDI_MASTER_CHANNEL=16
Feb 10 21:20:06 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: ZYNTHIAN_MIDI_NETWORK_ENABLED=0
Feb 10 21:20:06 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: ZYNTHIAN_MIDI_FILTER_RULES=
Feb 10 21:20:06 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: ZYNTHIAN_MIDI_PROG_CHANGE_ZS3=1
Feb 10 21:20:06 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: ZYNTHIAN_MIDI_MASTER_PROGRAM_CHANGE_UP=
Feb 10 21:20:06 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: ZYNTHIAN_MIDI_MASTER_BANK_CHANGE_CCNUM=0
Feb 10 21:20:06 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: ZYNTHIAN_MIDI_MASTER_BANK_CHANGE_DOWN=
Feb 10 21:20:06 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: ZYNTHIAN_MIDI_PRESET_PRELOAD_NOTEON=1
Feb 10 21:20:06 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: ZYNTHIAN_MIDI_AUBIONOTES_ENABLED=0
Feb 10 21:20:06 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: ZYNTHIAN_MIDI_FINE_TUNING=440
Feb 10 21:20:06 zynthian zynthian_webconf.sh[382]: DEBUG:root:CONFIG VAR: ZYNTHIAN_MIDI_MASTER_PROGRAM_CHANGE_TYPE=Custom
Feb 10 21:20:06 zynthian zynthian_webconf.sh[382]: ********** REUSING INSTANCE ***********
Feb 10 21:20:06 zynthian zynthian_webconf.sh[382]: DEBUG:root:MIXER CTRL LIST: None
Feb 10 21:20:06 zynthian zynthian_webconf.sh[382]: Invalid card number.
Feb 10 21:20:06 zynthian zynthian_webconf.sh[382]: ERROR:root:Command âamixer -M -c sndrpihifiberryâ returned non-zero exit status 1.
Feb 10 21:20:06 zynthian zynthian_webconf.sh[382]: INFO:root:OrderedDict([(âZCONTROLLERSâ, OrderedDict())])
Feb 10 21:20:06 zynthian zynthian_webconf.sh[382]: DEBUG:root:OrderedDict([(âSOUNDCARD_NAMEâ, {âtypeâ: âselectâ, âtitleâ: âSoundcardâ, âvalueâ: âHifiBerry DAC+ ADC PROâ, âoptionsâ: [âHifiBerry DAC+ ADC PROâ, âHifiBerry DAC+ ADCâ, âHifiBerry DAC+â, âHifiBerry DAC+ lightâ, âHifiBerry DAC+ RTCâ, âHifiBerry Digiâ, âHifiBerry Ampâ, âAudioInjectorâ, âAudioInjector Isolatedâ, âAudioInjector Ultraâ, âIQAudio DACâ, âIQAudio DAC+â, âIQAudio Digiâ, âPiSoundâ, âJustBoom DACâ, âJustBoom Digiâ, âFe-Pi Audioâ, âGeneric USB deviceâ, âBehringer UCA222â, âBehringer UMC404HDâ, âBehringer UMC1820â, âSteinberg UR22 MKIIâ, âEdirol UA1-EXâ, âYeti Microphoneâ, âRBPi Headphonesâ, âRBPi HDMIâ, âDummy deviceâ, âCustom deviceâ], âpresetsâ: OrderedDict([(âHifiBerry DAC+ ADC PROâ, {âSOUNDCARD_CONFIGâ: âdtoverlay=hifiberry-dacplusadcproâ, âJACKD_OPTIONSâ: â-P 70 -t 2000 -s -d alsa -d hw:sndrpihifiberry -S -r 44100 -p 256 -n 2 -X rawâ, âSOUNDCARD_MIXERâ: âDigital Left,ADC Left,Digital Right,ADC Right,ADC Left Input,ADC Right Inputâ}), (âHifiBerry DAC+ ADCâ, {âSOUNDCARD_CONFIGâ: âdtoverlay=hifiberry-dacplusadcâ, âJACKD_OPTIONSâ: â-P 70 -t 2000 -s -d alsa -d hw:sndrpihifiberry -S -r 44100 -p 256 -n 2 -X rawâ, âSOUNDCARD_MIXERâ: âDigital Left,Digital Rightâ}), (âHifiBerry DAC+â, {âSOUNDCARD_CONFIGâ: âdtoverlay=hifiberry-dacplusâ, âJACKD_OPTIONSâ: â-P 70 -t 2000 -s -d alsa -d hw:sndrpihifiberry -S -r 44100 -p 256 -n 2 -X rawâ, âSOUNDCARD_MIXERâ: âDigital Left,Digital Rightâ}), (âHifiBerry DAC+ lightâ, {âSOUNDCARD_CONFIGâ: âdtoverlay=hifiberry-dacâ, âJACKD_OPTIONSâ: â-P 70 -t 2000 -s -d alsa -d hw:sndrpihifiberry -S -r 44100 -p 256 -n 2 -X rawâ, âSOUNDCARD_MIXERâ: âDigital Left,Digital Rightâ}), (âHifiBerry DAC+ RTCâ, {âSOUNDCARD_CONFIGâ: âdtoverlay=hifiberry-dac\ndtoverlay=i2c-rtc,ds130â, âJACKD_OPTIONSâ: â-P 70 -t 2000 -s -d alsa -d hw:sndrpihifiberry -S -r 44100 -p 256 -n 2 -X rawâ, âSOUNDCARD_MIXERâ: âDigital Left,Digital Rightâ}), (âHifiBerry Digiâ, {âSOUNDCARD_CONFIGâ: âdtoverlay=hifiberry-digiâ, âJACKD_OPTIONSâ: â-P 70 -t 2000 -s -d alsa -d hw:sndrpihifiberry -P -S -r 44100 -p 256 -n 2 -X rawâ, âSOUNDCARD_MIXERâ: ââ}), (âHifiBerry Ampâ, {âSOUNDCARD_CONFIGâ: âdtoverlay=hifiberry-ampâ, âJACKD_OPTIONSâ: â-P 70 -t 2000 -s -d alsa -d hw:sndrpihifiberry -S -r 44100 -p 256 -n 2 -X rawâ, âSOUNDCARD_MIXERâ: ââ}), (âAudioInjectorâ, {âSOUNDCARD_CONFIGâ: âdtoverlay=audioinjector-wm8731-audioâ, âJACKD_OPTIONSâ: â-P 70 -t 2000 -s -d alsa -d hw:audioinjectorpi -S -r 44100 -p 256 -n 2 -X rawâ, âSOUNDCARD_MIXERâ: âMaster Left,Capture Left,Master Right,Capture Rightâ}), (âAudioInjector Isolatedâ, {âSOUNDCARD_CONFIGâ: âdtoverlay=audioinjector-isolated-soundcardâ, âJACKD_OPTIONSâ: â-P 70 -t 2000 -s -d alsa -d hw:audioinjectoris -r 48000 -p 256 -n 2 -X rawâ, âSOUNDCARD_MIXERâ: âMaster Left,Master Rightâ}), (âAudioInjector Ultraâ, {âSOUNDCARD_CONFIGâ: âdtoverlay=audioinjector-ultraâ, âJACKD_OPTIONSâ: â-P 70 -t 2000 -s -d alsa -d hw:audioinjectorul -r 48000 -p 256 -n 2 -X rawâ, âSOUNDCARD_MIXERâ: âDAC Left,DAC Right,PGAâ}), (âIQAudio DACâ, {âSOUNDCARD_CONFIGâ: âdtoverlay=iqaudio-dacâ, âJACKD_OPTIONSâ: â-P 70 -t 2000 -s -d alsa -d hw:0 -r 44100 -p 256 -n 2 -X rawâ, âSOUNDCARD_MIXERâ: ââ}), (âIQAudio DAC+â, {âSOUNDCARD_CONFIGâ: âdtoverlay=iqaudio-dacplusâ, âJACKD_OPTIONSâ: â-P 70 -t 2000 -s -d alsa -d hw:0 -r 44100 -p 256 -n 2 -X rawâ, âSOUNDCARD_MIXERâ: ââ}), (âIQAudio Digiâ, {âSOUNDCARD_CONFIGâ: âdtoverlay=iqaudio-digi-wm8804-audioâ, âJACKD_OPTIONSâ: â-P 70 -t 2000 -s -d alsa -d hw:0 -r 44100 -p 256 -n 2 -X rawâ, âSOUNDCARD_MIXERâ: ââ}), (âPiSoundâ, {âSOUNDCARD_CONFIGâ: âdtoverlay=pisoundâ, âJACKD_OPTIONSâ: â-P 70 -t 2000 -s -d alsa -d hw:pisound -r 44100 -p 256 -n 2 -X rawâ, âSOUNDCARD_MIXERâ: ââ}), (âJustBoom DACâ, {âSOUNDCARD_CONFIGâ: âdtoverlay=justboom-dacâ, âJACKD_OPTIONSâ: â-P 70 -t 2000 -s -d alsa -d hw:0 -r 44100 -p 256 -n 2 -X rawâ, âSOUNDCARD_MIXERâ: ââ}), (âJustBoom Digiâ, {âSOUNDCARD_CONFIGâ: âdtoverlay=justboom-digiâ, âJACKD_OPTIONSâ: â-P 70 -t 2000 -s -d alsa -d hw:0 -r 44100 -p 256 -n 2 -X rawâ, âSOUNDCARD_MIXERâ: ââ}), (âFe-Pi Audioâ, {âSOUNDCARD_CONFIGâ: âdtoverlay=fe-pi-audioâ, âJACKD_OPTIONSâ: â-P 70 -t 2000 -s -d alsa -d hw:0 -r 44100 -p 256 -n 2 -X rawâ, âSOUNDCARD_MIXERâ: ââ}), (âGeneric USB deviceâ, {âSOUNDCARD_CONFIGâ: ââ, âJACKD_OPTIONSâ: â-P 70 -t 2000 -s -d alsa -d hw:0 -r 44100 -p 256 -n 2 -X rawâ, âSOUNDCARD_MIXERâ: ââ}), (âBehringer UCA222â, {âSOUNDCARD_CONFIGâ: ââ, âJACKD_OPTIONSâ: â-P 70 -t 2000 -d alsa -d hw:CODEC -r 48000 -p 256 -n 3 -s -S -X rawâ, âSOUNDCARD_MIXERâ: âPCMâ}), (âBehringer UMC404HDâ, {âSOUNDCARD_CONFIGâ: ââ, âJACKD_OPTIONSâ: â-P 70 -t 2000 -d alsa -d hw:U192k -r 48000 -p 256 -n 3 -s -S -X rawâ, âSOUNDCARD_MIXERâ: âUMC404HD_192k_Output,Micâ}), (âBehringer UMC1820â, {âSOUNDCARD_CONFIGâ: ââ, âJACKD_OPTIONSâ: â-P 70 -t 2000 -d alsa -d hw:UMC1820 -r 44100 -p 256 -n 2 -s -S -X rawâ, âSOUNDCARD_MIXERâ: âUMC1820 Outputâ}), (âSteinberg UR22 MKIIâ, {âSOUNDCARD_CONFIGâ: ââ, âJACKD_OPTIONSâ: â-P 70 -t 2000 -s -d alsa -d hw:0 -r 44100 -p 256 -n 2 -X rawâ, âSOUNDCARD_MIXERâ: âClock_Source_41_Validityâ}), (âEdirol UA1-EXâ, {âSOUNDCARD_CONFIGâ: ââ, âJACKD_OPTIONSâ: â-P 70 -t 2000 -d alsa -d hw:UA1EX -r 44100 -p 1024 -n 2 -S -X rawâ, âSOUNDCARD_MIXERâ: ââ}), (âYeti Microphoneâ, {âSOUNDCARD_CONFIGâ: ââ, âJACKD_OPTIONSâ: â-t 2000 -s -d alsa -d hw:Microphone -r 48000 -p 256 -n 2 -X rawâ, âSOUNDCARD_MIXERâ: âSpeaker Left,Mic Left,Speaker Right,Mic Rightâ}), (âRBPi Headphonesâ, {âSOUNDCARD_CONFIGâ: âdtparam=audio=on\naudio_pwm_mode=2â, âJACKD_OPTIONSâ: â-P 70 -t 2000 -s -d alsa -d hw:Headphones -r 44100 -p 512 -n 3 -X rawâ, âSOUNDCARD_MIXERâ: âHeadphone Left,Headphone Rightâ}), (âRBPi HDMIâ, {âSOUNDCARD_CONFIGâ: âdtparam=audio=onâ, âJACKD_OPTIONSâ: â-P 70 -t 2000 -s -d alsa -d hw:b1 -r 44100 -p 512 -n 2 -X rawâ, âSOUNDCARD_MIXERâ: âHDMI Left,HDMI Rightâ}), (âDummy deviceâ, {âSOUNDCARD_CONFIGâ: ââ, âJACKD_OPTIONSâ: â-P 70 -t 2000 -s -d alsa -d hw:0 -r 44100 -p 256 -n 2 -X rawâ, âSOUNDCARD_MIXERâ: ââ}), (âCustom deviceâ, {âSOUNDCARD_CONFIGâ: ââ, âJACKD_OPTIONSâ: â-P 70 -t 2000 -s -d alsa -d hw:0 -r 44100 -p 256 -n 2 -X rawâ, âSOUNDCARD_MIXERâ: ââ})]), âdisabledâ: False}), (âSOUNDCARD_CONFIGâ, {âtypeâ: âtextareaâ, âtitleâ: âConfigâ, âcolsâ: 50, ârowsâ: 4, âvalueâ: âdtoverlay=hifiberry-dacplusadcproâ, âadvancedâ: True, âdisabledâ: False}), (âJACKD_OPTIONSâ, {âtypeâ: âtextâ, âtitleâ: âJackd Optionsâ, âvalueâ: â-P 70 -t 2000 -s -d alsa -d hw:sndrpihifiberry -S -r 44100 -p 256 -n 2 -X rawâ, âadvancedâ: True, âdisabledâ: False}), (âZYNTHIAN_AUBIONOTES_OPTIONSâ, {âtypeâ: âtextâ, âtitleâ: âAubionotes Optionsâ, âvalueâ: â-O complex -t 0.5 -s -88 -p yinfft -l 0.5â, âadvancedâ: True}), (âZYNTHIAN_LIMIT_USB_SPEEDâ, {âtypeâ: âbooleanâ, âtitleâ: âLimit USB speed to 12Mb/sâ, âvalueâ: â0â, âadvancedâ: True}), (âSOUNDCARD_MIXERâ, {âtypeâ: âtextareaâ, âtitleâ: âMixer Controlsâ, âvalueâ: âDigital Left,ADC Left,Digital Right,ADC Right,ADC Left Input,ADC Right Inputâ, âcolsâ: 50, ârowsâ: 3, âaddButtonâ: âdisplay_zcontroller_panelâ, âaddPanelâ: âzcontroller.htmlâ, âaddPanelConfigâ: OrderedDict([(âZCONTROLLERSâ, OrderedDict())]), âadvancedâ: True}), (âZYNTHIAN_RBPI_HEADPHONESâ, {âtypeâ: âbooleanâ, âtitleâ: âRBPi Headphonesâ, âvalueâ: False})])
Feb 10 21:20:06 zynthian zynthian_webconf.sh[382]: ERROR:tornado.application:Uncaught exception GET /hw-audio (192.168.178.58)
Feb 10 21:20:06 zynthian zynthian_webconf.sh[382]: HTTPServerRequest(protocol=âhttpâ, host=â192.168.178.55â, method=âGETâ, uri=â/hw-audioâ, version=âHTTP/1.1â, remote_ip=â192.168.178.58â, headers={âHostâ: â192.168.178.55â, âConnectionâ: âkeep-aliveâ, âUpgrade-Insecure-Requestsâ: â1â, âUser-Agentâ: âMozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/88.0.4324.146 Safari/537.36â, âAcceptâ: 'text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,/;q=0.8,application/signed-exchange;v=b3;q=0.9â, âRefererâ: âhttp://192.168.178.55/â, âAccept-Encodingâ: âgzip, deflateâ, âAccept-Languageâ: âde-DE,de;q=0.9,en-US;q=0.8,en;q=0.7â, âCookieâ: âadvanced_view=1; user=â2|1:0|10:1612986721|4:user|8:cm9vdA==|94ee550d110aabc87ee66c295bd8bfee53bbdb34d5cb88ac85444811c606e994ââ})
Feb 10 21:20:06 zynthian zynthian_webconf.sh[382]: Traceback (most recent call last):
Feb 10 21:20:06 zynthian zynthian_webconf.sh[382]: File â/usr/local/lib/python3.7/dist-packages/tornado/web.pyâ, line 1346, in _execute
Feb 10 21:20:06 zynthian zynthian_webconf.sh[382]: result = method(*self.path_args, **self.path_kwargs)
Feb 10 21:20:06 zynthian zynthian_webconf.sh[382]: File â/usr/local/lib/python3.7/dist-packages/tornado/web.pyâ, line 2626, in wrapper
Feb 10 21:20:06 zynthian zynthian_webconf.sh[382]: return method(self, *args, **kwargs)
Feb 10 21:20:06 zynthian zynthian_webconf.sh[382]: File â/home/pi/zynthian-webconf/lib/audio_config_handler.pyâ, line 282, in get
Feb 10 21:20:06 zynthian zynthian_webconf.sh[382]: super().get(âAudioâ, config, errors)
Feb 10 21:20:06 zynthian zynthian_webconf.sh[382]: File â/home/pi/zynthian-webconf/lib/zynthian_config_handler.pyâ, line 147, in get
Feb 10 21:20:06 zynthian zynthian_webconf.sh[382]: super().get(âconfig_block.htmlâ, title, config, errors)
Feb 10 21:20:06 zynthian zynthian_webconf.sh[382]: File â/home/pi/zynthian-webconf/lib/zynthian_config_handler.pyâ, line 106, in get
Feb 10 21:20:06 zynthian zynthian_webconf.sh[382]: self.render(âconfig.htmlâ, body=body, config=config, title=title, errors=errors)
Feb 10 21:20:06 zynthian zynthian_webconf.sh[382]: File â/home/pi/zynthian-webconf/lib/zynthian_config_handler.pyâ, line 84, in render
Feb 10 21:20:06 zynthian zynthian_webconf.sh[382]: super().render(tpl, info=info, **kwargs)
Feb 10 21:20:06 zynthian zynthian_webconf.sh[382]: File â/usr/local/lib/python3.7/dist-packages/tornado/web.pyâ, line 664, in render
Feb 10 21:20:06 zynthian zynthian_webconf.sh[382]: html = self.render_string(template_name, **kwargs)
Feb 10 21:20:06 zynthian zynthian_webconf.sh[382]: File â/usr/local/lib/python3.7/dist-packages/tornado/web.pyâ, line 771, in render_string
Feb 10 21:20:06 zynthian zynthian_webconf.sh[382]: return t.generate(**namespace)
Feb 10 21:20:06 zynthian zynthian_webconf.sh[382]: File â/usr/local/lib/python3.7/dist-packages/tornado/template.pyâ, line 278, in generate
Feb 10 21:20:06 zynthian zynthian_webconf.sh[382]: return execute()
Feb 10 21:20:06 zynthian zynthian_webconf.sh[382]: File âconfig_html.generated.pyâ, line 149, in _tt_execute
Feb 10 21:20:06 zynthian zynthian_webconf.sh[382]: _tt_tmp = _tt_modules.Template(body, config=config, title=title, errors=errors) # config.html:152
Feb 10 21:20:06 zynthian zynthian_webconf.sh[382]: File â/usr/local/lib/python3.7/dist-packages/tornado/web.pyâ, line 1429, in render
Feb 10 21:20:06 zynthian zynthian_webconf.sh[382]: rendered = self._active_modules[name].render(*args, **kwargs)
Feb 10 21:20:06 zynthian zynthian_webconf.sh[382]: File â/usr/local/lib/python3.7/dist-packages/tornado/web.pyâ, line 2736, in render
Feb 10 21:20:06 zynthian zynthian_webconf.sh[382]: **kwargs)
Feb 10 21:20:06 zynthian zynthian_webconf.sh[382]: File â/usr/local/lib/python3.7/dist-packages/tornado/web.pyâ, line 2691, in render_string
Feb 10 21:20:06 zynthian zynthian_webconf.sh[382]: return self.handler.render_string(path, **kwargs)
Feb 10 21:20:06 zynthian zynthian_webconf.sh[382]: File âconfig_block_html.generated.pyâ, line 157, in _tt_execute
Feb 10 21:20:06 zynthian zynthian_webconf.sh[382]: if escape(value)==â1â: # config_block.html:52
Feb 10 21:20:06 zynthian zynthian_webconf.sh[382]: File â/usr/local/lib/python3.7/dist-packages/tornado/escape.pyâ, line 69, in xhtml_escape
Feb 10 21:20:06 zynthian zynthian_webconf.sh[382]: to_basestring(value))
Feb 10 21:20:06 zynthian zynthian_webconf.sh[382]: File â/usr/local/lib/python3.7/dist-packages/tornado/escape.pyâ, line 251, in to_basestring
Feb 10 21:20:06 zynthian zynthian_webconf.sh[382]: âExpected bytes, unicode, or None; got %râ % type(value)
Feb 10 21:20:06 zynthian zynthian_webconf.sh[382]: TypeError: Expected bytes, unicode, or None; got <class âboolâ>
Feb 10 21:20:06 zynthian zynthian_webconf.sh[382]: ERROR:tornado.access:500 GET /hw-audio (192.168.178.58) 259.89ms
Feb 10 21:20:05 zynthian zynthian_webconf.sh[382]: /zynthian/config/zynthian_envars.sh: line 2: 000#******************************************************************************: command not found
This line looks crooked. But I donât understand enough of the inner workings of Zynthian
This â000â shouldnât be at the beginning of line 2. Anyway, this doesnât look the problem.
Let me check the source code âŚ
â Logs begin at Tue 2021-02-09 18:28:23 GMT. â
Feb 11 06:53:24 zynthian zynthian_webconf.sh[376]: return execute()
Feb 11 06:53:24 zynthian zynthian_webconf.sh[376]: File âconfig_block_html.generated.pyâ, line 157, in _tt_execute
Feb 11 06:53:24 zynthian zynthian_webconf.sh[376]: if escape(value)==â1â: # config_block.html:52
Feb 11 06:53:24 zynthian zynthian_webconf.sh[376]: File â/usr/local/lib/python3.7/dist-packages/tornado/escape.pyâ, line 69, in xhtml_escape
Feb 11 06:53:24 zynthian zynthian_webconf.sh[376]: to_basestring(value))
Feb 11 06:53:24 zynthian zynthian_webconf.sh[376]: File â/usr/local/lib/python3.7/dist-packages/tornado/escape.pyâ, line 251, in to_basestring
Feb 11 06:53:24 zynthian zynthian_webconf.sh[376]: âExpected bytes, unicode, or None; got %râ % type(value)
Feb 11 06:53:24 zynthian zynthian_webconf.sh[376]: TypeError: Expected bytes, unicode, or None; got <class âboolâ>
Feb 11 06:53:24 zynthian zynthian_webconf.sh[376]: ERROR:tornado.access:500 GET /hw-audio (192.168.108.147) 353.06ms
Feb 11 06:53:24 zynthian zynthian_webconf.sh[376]: INFO:tornado.access:200 GET /favicon.ico (192.168.108.147) 5.23ms
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: DEBUG:root:CONFIG VAR: CFLAGS_UNSAFE=
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: DEBUG:root:CONFIG VAR: ZYNTHIAN_WIRING_CUSTOM_SWITCH_03__UI_SHORT=NONE
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: DEBUG:root:CONFIG VAR: ZYNTHIAN_WIRING_ENCODER_A=25,21,16,7
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: DEBUG:root:CONFIG VAR: ZYNTHIAN_WIRING_ENCODER_B=27,26,8,9
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: DEBUG:root:CONFIG VAR: SOUNDCARD_CONFIG=dtoverlay=hifiberry-dac
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: DEBUG:root:CONFIG VAR: ZYNTHIAN_LIMIT_USB_SPEED=0
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: DEBUG:root:CONFIG VAR: ZYNTHIAN_PLUGINS_SRC_DIR=/zynthian/zynthian-sw/plugins
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: DEBUG:root:CONFIG VAR: ZYNTHIAN_WIRING_CUSTOM_SWITCH_01__UI_SHORT=NONE
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: DEBUG:root:CONFIG VAR: ZYNTHIAN_UI_RESTORE_LAST_STATE=1
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: DEBUG:root:CONFIG VAR: ZYNTHIAN_UI_FONT_SIZE=14
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: DEBUG:root:CONFIG VAR: ZYNTHIAN_DATA_DIR=/zynthian/zynthian-data
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: DEBUG:root:CONFIG VAR: ZYNTHIAN_WIRING_CUSTOM_SWITCH_03__MIDI_CHAN=Active
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: DEBUG:root:CONFIG VAR: ZYNTHIAN_WIRING_CUSTOM_SWITCH_01__UI_LONG=NONE
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: DEBUG:root:CONFIG VAR: JACKD_OPTIONS=-P 70 -t 2000 -s -d alsa -d hw:sndrpihifiberry -S -r 44100 -p 256 -n 2 -X raw
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: DEBUG:root:CONFIG VAR: ZYNTHIAN_UI_SNAPSHOT_MIXER_SETTINGS=0
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: DEBUG:root:CONFIG VAR: ZYNTHIAN_WIRING_CUSTOM_SWITCH_04__MIDI_NUM=4
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: DEBUG:root:CONFIG VAR: ZYNTHIAN_WIRING_CUSTOM_SWITCH_03=NONE
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: DEBUG:root:CONFIG VAR: ZYNTHIAN_UI_COLOR_TX=#ffffff
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: DEBUG:root:CONFIG VAR: ZYNTHIAN_WIRING_CUSTOM_SWITCH_02=NONE
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: DEBUG:root:CONFIG VAR: ZYNTHIAN_WIRING_CUSTOM_SWITCH_01=NONE
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: DEBUG:root:CONFIG VAR: ZYNTHIAN_WIRING_CUSTOM_SWITCH_04=NONE
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: DEBUG:root:CONFIG VAR: ZYNTHIAN_UI_SWITCH_LONG_MS=2000
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: DEBUG:root:CONFIG VAR: ZYNTHIAN_WIRING_CUSTOM_SWITCH_04__MIDI_CHAN=Active
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: DEBUG:root:CONFIG VAR: ZYNTHIAN_SCRIPT_MIDI_PROFILE=/zynthian/config/midi-profiles/default.sh
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: DEBUG:root:CONFIG VAR: CXXFLAGS=-mcpu=cortex-a53 -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mneon-for-64bits -mfloat-abi=hard -mlittle-endian -munaligned-access -mvectorize-with-neon-quad -ftree-vectorize
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: DEBUG:root:CONFIG VAR: ZYNTHIAN_UI_COLOR_ON=#ff0000
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: DEBUG:root:CONFIG VAR: ZYNTHIAN_WIRING_CUSTOM_SWITCH_02__UI_BOLD=NONE
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: DEBUG:root:CONFIG VAR: ZYNTHIAN_WIRING_CUSTOM_SWITCH_02__MIDI_CHAN=Active
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: DEBUG:root:CONFIG VAR: ZYNTHIAN_WIRING_ZYNAPTIK_CONFIG=
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: DEBUG:root:CONFIG VAR: ZYNTHIAN_EX_DATA_DIR=/media/usb0
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: DEBUG:root:CONFIG VAR: ZYNTHIAN_WIRING_CUSTOM_SWITCH_03__MIDI_NUM=3
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: DEBUG:root:CONFIG VAR: ZYNTHIAN_WIRING_SWITCHES=23,15,2,22
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: DEBUG:root:CONFIG VAR: ZYNTHIAN_PLUGINS_DIR=/zynthian/zynthian-plugins
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: DEBUG:root:CONFIG VAR: ZYNTHIAN_WIRING_MCP23017_INTB_PIN=
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: DEBUG:root:CONFIG VAR: ZYNTHIAN_WIRING_CUSTOM_SWITCH_01__MIDI_NUM=1
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: DEBUG:root:CONFIG VAR: ZYNTHIAN_WIRING_CUSTOM_SWITCH_03__UI_BOLD=NONE
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: DEBUG:root:CONFIG VAR: ZYNTHIAN_UI_COLOR_BG=#000000
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: DEBUG:root:CONFIG VAR: ZYNTHIAN_SYS_DIR=/zynthian/zynthian-sys
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: DEBUG:root:CONFIG VAR: ZYNTHIAN_WIRING_CUSTOM_SWITCH_02__MIDI_NUM=2
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: DEBUG:root:CONFIG VAR: ZYNTHIAN_WIRING_CUSTOM_SWITCH_04__UI_BOLD=NONE
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: DEBUG:root:CONFIG VAR: SOUNDCARD_MIXER=Master Left,Capture Left,Master Right,Capture Right
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: DEBUG:root:CONFIG VAR: ZYNTHIAN_UI_ENABLE_CURSOR=0
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: DEBUG:root:CONFIG VAR: DISPLAY_WIDTH=480
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: DEBUG:root:CONFIG VAR: ZYNTHIAN_UI_TOUCH_WIDGETS=0
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: DEBUG:root:CONFIG VAR: ZYNTHIAN_WIRING_MCP23017_INTA_PIN=
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: DEBUG:root:CONFIG VAR: ZYNTHIAN_WIFI_MODE=on
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: DEBUG:root:CONFIG VAR: ZYNTHIAN_KIT_VERSION=Custom
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: DEBUG:root:CONFIG VAR: RASPI=true
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: DEBUG:root:CONFIG VAR: ZYNTHIAN_WIRING_CUSTOM_SWITCH_03__UI_LONG=NONE
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: DEBUG:root:CONFIG VAR: DISPLAY_HEIGHT=320
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: DEBUG:root:CONFIG VAR: MACHINE_HW_NAME=armv7l
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: DEBUG:root:CONFIG VAR: ZYNTHIAN_UI_DIR=/zynthian/zynthian-ui
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: DEBUG:root:CONFIG VAR: ZYNTHIAN_SW_DIR=/zynthian/zynthian-sw
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: DEBUG:root:CONFIG VAR: SOUNDCARD_NAME=AudioInjector
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: DEBUG:root:CONFIG VAR: ZYNTHIAN_WIRING_CUSTOM_SWITCH_01__MIDI_CHAN=Active
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: DEBUG:root:CONFIG VAR: ZYNTHIAN_WIRING_CUSTOM_SWITCH_01__UI_BOLD=NONE
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: DEBUG:root:CONFIG VAR: RBPI_VERSION=Raspberry Pi 3 Model B Plus Rev 1.3
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: DEBUG:root:CONFIG VAR: ZYNTHIAN_WIRING_CUSTOM_SWITCH_02__UI_LONG=NONE
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: DEBUG:root:CONFIG VAR: ZYNTHIAN_WIRING_LAYOUT=DUMMIES
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: DEBUG:root:CONFIG VAR: ZYNTHIAN_CONFIG_DIR=/zynthian/config
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: DEBUG:root:CONFIG VAR: ZYNTHIAN_UI_COLOR_PANEL_BG=#3a424d
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: DEBUG:root:CONFIG VAR: ZYNTHIAN_MY_DATA_DIR=/zynthian/zynthian-my-data
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: DEBUG:root:CONFIG VAR: DISPLAY_NAME=ZynScreen 3.5 (v1)
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: DEBUG:root:CONFIG VAR: ZYNTHIAN_WIRING_CUSTOM_SWITCH_02__UI_SHORT=NONE
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: DEBUG:root:CONFIG VAR: ZYNTHIAN_SETUP_APT_CLEAN=TRUE
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: DEBUG:root:CONFIG VAR: ZYNTHIAN_WIRING_CUSTOM_SWITCH_04__UI_SHORT=NONE
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: DEBUG:root:CONFIG VAR: CFLAGS=-mcpu=cortex-a53 -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mneon-for-64bits -mfloat-abi=hard -mlittle-endian -munaligned-access -mvectorize-with-neon-quad -ftree-vectorize
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: DEBUG:root:CONFIG VAR: ZYNTHIAN_UI_SWITCH_BOLD_MS=300
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: DEBUG:root:CONFIG VAR: DISPLAY_CONFIG=dtoverlay=piscreen2r-notouch,rotate=270\ndtoverlay=ads7846,speed=2000000,cs=1,penirq=17,penirq_pull=2,swapxy=1,xohms=100,pmax=255\n
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: DEBUG:root:CONFIG VAR: ZYNTHIAN_UI_FONT_FAMILY=Audiowide
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: DEBUG:root:CONFIG VAR: LV2_PATH=/usr/lib/lv2:/usr/lib/arm-linux-gnueabihf/lv2:/usr/local/lib/lv2:/zynthian/zynthian-plugins/lv2:/zynthian/zynthian-data/presets/lv2:/zynthian/zynthian-my-data/presets/lv2
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: DEBUG:root:CONFIG VAR: ZYNTHIAN_DIR=/zynthian
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: DEBUG:root:CONFIG VAR: FRAMEBUFFER=/dev/fb1
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: DEBUG:root:CONFIG VAR: ZYNTHIAN_WIRING_CUSTOM_SWITCH_04__UI_LONG=NONE
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: DEBUG:root:CONFIG VAR: ZYNTHIAN_RECIPE_DIR=/zynthian/zynthian-sys/scripts/recipes
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: DEBUG:root:CONFIG VAR: ZYNTHIAN_AUBIONOTES_OPTIONS=-O complex -t 0.5 -s -88 -p yinfft -l 0.5
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: DEBUG:root:CONFIG VAR: ZYNTHIAN_MIDI_MASTER_BANK_CHANGE_UP=
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: DEBUG:root:CONFIG VAR: ZYNTHIAN_MIDI_SYS_ENABLED=1
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: DEBUG:root:CONFIG VAR: ZYNTHIAN_MIDI_MASTER_PROGRAM_CHANGE_DOWN=
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: DEBUG:root:CONFIG VAR: ZYNTHIAN_MIDI_SINGLE_ACTIVE_CHANNEL=0
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: DEBUG:root:CONFIG VAR: ZYNTHIAN_MIDI_RTPMIDI_ENABLED=0
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: DEBUG:root:CONFIG VAR: ZYNTHIAN_MIDI_TOUCHOSC_ENABLED=0
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: DEBUG:root:CONFIG VAR: ZYNTHIAN_MIDI_PORTS=DISABLED_IN=\nENABLED_OUT=ttymidi:MIDI_out\nENABLED_FB=
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: DEBUG:root:CONFIG VAR: ZYNTHIAN_MIDI_MASTER_CHANNEL=16
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: DEBUG:root:CONFIG VAR: ZYNTHIAN_MIDI_NETWORK_ENABLED=0
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: DEBUG:root:CONFIG VAR: ZYNTHIAN_MIDI_FILTER_RULES=
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: DEBUG:root:CONFIG VAR: ZYNTHIAN_MIDI_PROG_CHANGE_ZS3=1
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: DEBUG:root:CONFIG VAR: ZYNTHIAN_MIDI_MASTER_PROGRAM_CHANGE_UP=
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: DEBUG:root:CONFIG VAR: ZYNTHIAN_MIDI_MASTER_BANK_CHANGE_CCNUM=0
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: DEBUG:root:CONFIG VAR: ZYNTHIAN_MIDI_MASTER_BANK_CHANGE_DOWN=
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: DEBUG:root:CONFIG VAR: ZYNTHIAN_MIDI_PRESET_PRELOAD_NOTEON=1
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: DEBUG:root:CONFIG VAR: ZYNTHIAN_MIDI_AUBIONOTES_ENABLED=0
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: DEBUG:root:CONFIG VAR: ZYNTHIAN_MIDI_FINE_TUNING=440
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: DEBUG:root:CONFIG VAR: ZYNTHIAN_MIDI_MASTER_PROGRAM_CHANGE_TYPE=Custom
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: ********** REUSING INSTANCE ***********
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: DEBUG:root:MIXER CTRL LIST: None
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: INFO:root:OrderedDict([(âZCONTROLLERSâ, OrderedDict())])
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: DEBUG:root:OrderedDict([(âSOUNDCARD_NAMEâ, {âtypeâ: âselectâ, âtitleâ: âSoundcardâ, âvalueâ: âAudioInjectorâ, âoptionsâ: [âHifiBerry DAC+ ADC PROâ, âHifiBerry DAC+ ADCâ, âHifiBerry DAC+â, âHifiBerry DAC+ lightâ, âHifiBerry DAC+ RTCâ, âHifiBerry Digiâ, âHifiBerry Ampâ, âAudioInjectorâ, âAudioInjector Isolatedâ, âAudioInjector Ultraâ, âIQAudio DACâ, âIQAudio DAC+â, âIQAudio Digiâ, âPiSoundâ, âJustBoom DACâ, âJustBoom Digiâ, âFe-Pi Audioâ, âGeneric USB deviceâ, âBehringer UCA222â, âBehringer UMC404HDâ, âBehringer UMC1820â, âSteinberg UR22 MKIIâ, âEdirol UA1-EXâ, âYeti Microphoneâ, âRBPi Headphonesâ, âRBPi HDMIâ, âDummy deviceâ, âCustom deviceâ], âpresetsâ: OrderedDict([(âHifiBerry DAC+ ADC PROâ, {âSOUNDCARD_CONFIGâ: âdtoverlay=hifiberry-dacplusadcproâ, âJACKD_OPTIONSâ: â-P 70 -t 2000 -s -d alsa -d hw:sndrpihifiberry -S -r 44100 -p 256 -n 2 -X rawâ, âSOUNDCARD_MIXERâ: âDigital Left,ADC Left,Digital Right,ADC Right,ADC Left Input,ADC Right Inputâ}), (âHifiBerry DAC+ ADCâ, {âSOUNDCARD_CONFIGâ: âdtoverlay=hifiberry-dacplusadcâ, âJACKD_OPTIONSâ: â-P 70 -t 2000 -s -d alsa -d hw:sndrpihifiberry -S -r 44100 -p 256 -n 2 -X rawâ, âSOUNDCARD_MIXERâ: âDigital Left,Digital Rightâ}), (âHifiBerry DAC+â, {âSOUNDCARD_CONFIGâ: âdtoverlay=hifiberry-dacplusâ, âJACKD_OPTIONSâ: â-P 70 -t 2000 -s -d alsa -d hw:sndrpihifiberry -S -r 44100 -p 256 -n 2 -X rawâ, âSOUNDCARD_MIXERâ: âDigital Left,Digital Rightâ}), (âHifiBerry DAC+ lightâ, {âSOUNDCARD_CONFIGâ: âdtoverlay=hifiberry-dacâ, âJACKD_OPTIONSâ: â-P 70 -t 2000 -s -d alsa -d hw:sndrpihifiberry -S -r 44100 -p 256 -n 2 -X rawâ, âSOUNDCARD_MIXERâ: âDigital Left,Digital Rightâ}), (âHifiBerry DAC+ RTCâ, {âSOUNDCARD_CONFIGâ: âdtoverlay=hifiberry-dac\ndtoverlay=i2c-rtc,ds130â, âJACKD_OPTIONSâ: â-P 70 -t 2000 -s -d alsa -d hw:sndrpihifiberry -S -r 44100 -p 256 -n 2 -X rawâ, âSOUNDCARD_MIXERâ: âDigital Left,Digital Rightâ}), (âHifiBerry Digiâ, {âSOUNDCARD_CONFIGâ: âdtoverlay=hifiberry-digiâ, âJACKD_OPTIONSâ: â-P 70 -t 2000 -s -d alsa -d hw:sndrpihifiberry -P -S -r 44100 -p 256 -n 2 -X rawâ, âSOUNDCARD_MIXERâ: ââ}), (âHifiBerry Ampâ, {âSOUNDCARD_CONFIGâ: âdtoverlay=hifiberry-ampâ, âJACKD_OPTIONSâ: â-P 70 -t 2000 -s -d alsa -d hw:sndrpihifiberry -S -r 44100 -p 256 -n 2 -X rawâ, âSOUNDCARD_MIXERâ: ââ}), (âAudioInjectorâ, {âSOUNDCARD_CONFIGâ: âdtoverlay=audioinjector-wm8731-audioâ, âJACKD_OPTIONSâ: â-P 70 -t 2000 -s -d alsa -d hw:audioinjectorpi -S -r 44100 -p 256 -n 2 -X rawâ, âSOUNDCARD_MIXERâ: âMaster Left,Capture Left,Master Right,Capture Rightâ}), (âAudioInjector Isolatedâ, {âSOUNDCARD_CONFIGâ: âdtoverlay=audioinjector-isolated-soundcardâ, âJACKD_OPTIONSâ: â-P 70 -t 2000 -s -d alsa -d hw:audioinjectoris -r 48000 -p 256 -n 2 -X rawâ, âSOUNDCARD_MIXERâ: âMaster Left,Master Rightâ}), (âAudioInjector Ultraâ, {âSOUNDCARD_CONFIGâ: âdtoverlay=audioinjector-ultraâ, âJACKD_OPTIONSâ: â-P 70 -t 2000 -s -d alsa -d hw:audioinjectorul -r 48000 -p 256 -n 2 -X rawâ, âSOUNDCARD_MIXERâ: âDAC Left,DAC Right,PGAâ}), (âIQAudio DACâ, {âSOUNDCARD_CONFIGâ: âdtoverlay=iqaudio-dacâ, âJACKD_OPTIONSâ: â-P 70 -t 2000 -s -d alsa -d hw:0 -r 44100 -p 256 -n 2 -X rawâ, âSOUNDCARD_MIXERâ: ââ}), (âIQAudio DAC+â, {âSOUNDCARD_CONFIGâ: âdtoverlay=iqaudio-dacplusâ, âJACKD_OPTIONSâ: â-P 70 -t 2000 -s -d alsa -d hw:0 -r 44100 -p 256 -n 2 -X rawâ, âSOUNDCARD_MIXERâ: ââ}), (âIQAudio Digiâ, {âSOUNDCARD_CONFIGâ: âdtoverlay=iqaudio-digi-wm8804-audioâ, âJACKD_OPTIONSâ: â-P 70 -t 2000 -s -d alsa -d hw:0 -r 44100 -p 256 -n 2 -X rawâ, âSOUNDCARD_MIXERâ: ââ}), (âPiSoundâ, {âSOUNDCARD_CONFIGâ: âdtoverlay=pisoundâ, âJACKD_OPTIONSâ: â-P 70 -t 2000 -s -d alsa -d hw:pisound -r 44100 -p 256 -n 2 -X rawâ, âSOUNDCARD_MIXERâ: ââ}), (âJustBoom DACâ, {âSOUNDCARD_CONFIGâ: âdtoverlay=justboom-dacâ, âJACKD_OPTIONSâ: â-P 70 -t 2000 -s -d alsa -d hw:0 -r 44100 -p 256 -n 2 -X rawâ, âSOUNDCARD_MIXERâ: ââ}), (âJustBoom Digiâ, {âSOUNDCARD_CONFIGâ: âdtoverlay=justboom-digiâ, âJACKD_OPTIONSâ: â-P 70 -t 2000 -s -d alsa -d hw:0 -r 44100 -p 256 -n 2 -X rawâ, âSOUNDCARD_MIXERâ: ââ}), (âFe-Pi Audioâ, {âSOUNDCARD_CONFIGâ: âdtoverlay=fe-pi-audioâ, âJACKD_OPTIONSâ: â-P 70 -t 2000 -s -d alsa -d hw:0 -r 44100 -p 256 -n 2 -X rawâ, âSOUNDCARD_MIXERâ: ââ}), (âGeneric USB deviceâ, {âSOUNDCARD_CONFIGâ: ââ, âJACKD_OPTIONSâ: â-P 70 -t 2000 -s -d alsa -d hw:0 -r 44100 -p 256 -n 2 -X rawâ, âSOUNDCARD_MIXERâ: ââ}), (âBehringer UCA222â, {âSOUNDCARD_CONFIGâ: ââ, âJACKD_OPTIONSâ: â-P 70 -t 2000 -d alsa -d hw:CODEC -r 48000 -p 256 -n 3 -s -S -X rawâ, âSOUNDCARD_MIXERâ: âPCMâ}), (âBehringer UMC404HDâ, {âSOUNDCARD_CONFIGâ: ââ, âJACKD_OPTIONSâ: â-P 70 -t 2000 -d alsa -d hw:U192k -r 48000 -p 256 -n 3 -s -S -X rawâ, âSOUNDCARD_MIXERâ: âUMC404HD_192k_Output,Micâ}), (âBehringer UMC1820â, {âSOUNDCARD_CONFIGâ: ââ, âJACKD_OPTIONSâ: â-P 70 -t 2000 -d alsa -d hw:UMC1820 -r 44100 -p 256 -n 2 -s -S -X rawâ, âSOUNDCARD_MIXERâ: âUMC1820 Outputâ}), (âSteinberg UR22 MKIIâ, {âSOUNDCARD_CONFIGâ: ââ, âJACKD_OPTIONSâ: â-P 70 -t 2000 -s -d alsa -d hw:0 -r 44100 -p 256 -n 2 -X rawâ, âSOUNDCARD_MIXERâ: âClock_Source_41_Validityâ}), (âEdirol UA1-EXâ, {âSOUNDCARD_CONFIGâ: ââ, âJACKD_OPTIONSâ: â-P 70 -t 2000 -d alsa -d hw:UA1EX -r 44100 -p 1024 -n 2 -S -X rawâ, âSOUNDCARD_MIXERâ: ââ}), (âYeti Microphoneâ, {âSOUNDCARD_CONFIGâ: ââ, âJACKD_OPTIONSâ: â-t 2000 -s -d alsa -d hw:Microphone -r 48000 -p 256 -n 2 -X rawâ, âSOUNDCARD_MIXERâ: âSpeaker Left,Mic Left,Speaker Right,Mic Rightâ}), (âRBPi Headphonesâ, {âSOUNDCARD_CONFIGâ: âdtparam=audio=on\naudio_pwm_mode=2â, âJACKD_OPTIONSâ: â-P 70 -t 2000 -s -d alsa -d hw:Headphones -r 44100 -p 512 -n 3 -X rawâ, âSOUNDCARD_MIXERâ: âHeadphone Left,Headphone Rightâ}), (âRBPi HDMIâ, {âSOUNDCARD_CONFIGâ: âdtparam=audio=onâ, âJACKD_OPTIONSâ: â-P 70 -t 2000 -s -d alsa -d hw:b1 -r 44100 -p 512 -n 2 -X rawâ, âSOUNDCARD_MIXERâ: âHDMI Left,HDMI Rightâ}), (âDummy deviceâ, {âSOUNDCARD_CONFIGâ: ââ, âJACKD_OPTIONSâ: â-P 70 -t 2000 -s -d alsa -d hw:0 -r 44100 -p 256 -n 2 -X rawâ, âSOUNDCARD_MIXERâ: ââ}), (âCustom deviceâ, {âSOUNDCARD_CONFIGâ: ââ, âJACKD_OPTIONSâ: â-P 70 -t 2000 -s -d alsa -d hw:0 -r 44100 -p 256 -n 2 -X rawâ, âSOUNDCARD_MIXERâ: ââ})]), âdisabledâ: False}), (âSOUNDCARD_CONFIGâ, {âtypeâ: âtextareaâ, âtitleâ: âConfigâ, âcolsâ: 50, ârowsâ: 4, âvalueâ: âdtoverlay=hifiberry-dacâ, âadvancedâ: True, âdisabledâ: False}), (âJACKD_OPTIONSâ, {âtypeâ: âtextâ, âtitleâ: âJackd Optionsâ, âvalueâ: â-P 70 -t 2000 -s -d alsa -d hw:sndrpihifiberry -S -r 44100 -p 256 -n 2 -X rawâ, âadvancedâ: True, âdisabledâ: False}), (âZYNTHIAN_AUBIONOTES_OPTIONSâ, {âtypeâ: âtextâ, âtitleâ: âAubionotes Optionsâ, âvalueâ: â-O complex -t 0.5 -s -88 -p yinfft -l 0.5â, âadvancedâ: True}), (âZYNTHIAN_LIMIT_USB_SPEEDâ, {âtypeâ: âbooleanâ, âtitleâ: âLimit USB speed to 12Mb/sâ, âvalueâ: â0â, âadvancedâ: True}), (âSOUNDCARD_MIXERâ, {âtypeâ: âtextareaâ, âtitleâ: âMixer Controlsâ, âvalueâ: âMaster Left,Capture Left,Master Right,Capture Rightâ, âcolsâ: 50, ârowsâ: 3, âaddButtonâ: âdisplay_zcontroller_panelâ, âaddPanelâ: âzcontroller.htmlâ, âaddPanelConfigâ: OrderedDict([(âZCONTROLLERSâ, OrderedDict())]), âadvancedâ: True}), (âZYNTHIAN_RBPI_HEADPHONESâ, {âtypeâ: âbooleanâ, âtitleâ: âRBPi Headphonesâ, âvalueâ: False})])
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: ERROR:tornado.application:Uncaught exception GET /hw-audio (192.168.108.147)
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: HTTPServerRequest(protocol=âhttpâ, host=â192.168.108.112â, method=âGETâ, uri=â/hw-audioâ, version=âHTTP/1.1â, remote_ip=â192.168.108.147â, headers={âHostâ: â192.168.108.112â, âConnectionâ: âkeep-aliveâ, âUpgrade-Insecure-Requestsâ: â1â, âUser-Agentâ: âMozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/88.0.4324.150 Safari/537.36â, âAcceptâ: âtext/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,/;q=0.8,application/signed-exchange;v=b3;q=0.9â, âRefererâ: âhttp://192.168.108.112/â, âAccept-Encodingâ: âgzip, deflateâ, âAccept-Languageâ: âcs-CZ,cs;q=0.9,en;q=0.8,pl;q=0.7,sk;q=0.6â, âCookieâ: âuser=â2|1:0|10:1613026399|4:user|8:cm9vdA==|200a13d926ca17290b742ac1b0f3ef33d38675300a2ec1c15da8153e3243565dââ})
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: Traceback (most recent call last):
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: File â/usr/local/lib/python3.7/dist-packages/tornado/web.pyâ, line 1346, in _execute
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: result = method(*self.path_args, **self.path_kwargs)
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: File â/usr/local/lib/python3.7/dist-packages/tornado/web.pyâ, line 2626, in wrapper
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: return method(self, *args, **kwargs)
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: File â/home/pi/zynthian-webconf/lib/audio_config_handler.pyâ, line 282, in get
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: super().get(âAudioâ, config, errors)
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: File â/home/pi/zynthian-webconf/lib/zynthian_config_handler.pyâ, line 147, in get
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: super().get(âconfig_block.htmlâ, title, config, errors)
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: File â/home/pi/zynthian-webconf/lib/zynthian_config_handler.pyâ, line 106, in get
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: self.render(âconfig.htmlâ, body=body, config=config, title=title, errors=errors)
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: File â/home/pi/zynthian-webconf/lib/zynthian_config_handler.pyâ, line 84, in render
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: super().render(tpl, info=info, **kwargs)
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: File â/usr/local/lib/python3.7/dist-packages/tornado/web.pyâ, line 664, in render
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: html = self.render_string(template_name, **kwargs)
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: File â/usr/local/lib/python3.7/dist-packages/tornado/web.pyâ, line 771, in render_string
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: return t.generate(**namespace)
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: File â/usr/local/lib/python3.7/dist-packages/tornado/template.pyâ, line 278, in generate
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: return execute()
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: File âconfig_html.generated.pyâ, line 149, in _tt_execute
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: _tt_tmp = _tt_modules.Template(body, config=config, title=title, errors=errors) # config.html:152
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: File â/usr/local/lib/python3.7/dist-packages/tornado/web.pyâ, line 1429, in render
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: rendered = self._active_modules[name].render(*args, **kwargs)
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: File â/usr/local/lib/python3.7/dist-packages/tornado/web.pyâ, line 2736, in render
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: **kwargs)
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: File â/usr/local/lib/python3.7/dist-packages/tornado/web.pyâ, line 2691, in render_string
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: return self.handler.render_string(path, **kwargs)
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: File âconfig_block_html.generated.pyâ, line 157, in _tt_execute
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: if escape(value)==â1â: # config_block.html:52
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: File â/usr/local/lib/python3.7/dist-packages/tornado/escape.pyâ, line 69, in xhtml_escape
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: to_basestring(value))
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: File â/usr/local/lib/python3.7/dist-packages/tornado/escape.pyâ, line 251, in to_basestring
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: âExpected bytes, unicode, or None; got %râ % type(value)
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: TypeError: Expected bytes, unicode, or None; got <class âboolâ>
Feb 11 06:53:59 zynthian zynthian_webconf.sh[376]: ERROR:tornado.access:500 GET /hw-audio (192.168.108.147) 224.44ms
Thanks, the last update resolved this issue.
But still ERROR on LCD: (I am testing it with RPi Headphones soundcard now)
root@zynthian:~# systemctl status zynthian
â zynthian.service - Zynthian User Interface
Loaded: loaded (/etc/systemd/system/zynthian.service; enabled; vendor preset: enabled)
Active: active (running) since Thu 2021-02-11 07:36:47 GMT; 4min 17s ago
Main PID: 434 (startx)
Tasks: 18 (limit: 2200)
Memory: 74.9M
CGroup: /system.slice/zynthian.service
ââ 434 /bin/sh /usr/bin/startx ./zynthian.sh
ââ 453 xinit ./zynthian.sh â /etc/X11/xinit/xserverrc :0 -auth /tmp/serverauth.jJLtcfi47i
ââ 454 /usr/lib/xorg/Xorg -nolisten tcp :0 -auth /tmp/serverauth.jJLtcfi47i
ââ 511 /bin/bash ./zynthian.sh
ââ1992 /usr/local/bin/jack_transport
ââ2370 sleep 3
Feb 11 07:41:01 zynthian startx[434]: screen_obj.hide();
Feb 11 07:41:01 zynthian startx[434]: File â/home/pi/zynthian-ui/zyngui/zynthian_gui_midi_key_range.pyâ, line 275, in hide
Feb 11 07:41:01 zynthian startx[434]: zyncoder.lib_zyncoder.set_midi_learning_mode(0)
Feb 11 07:41:01 zynthian startx[434]: AttributeError: âNoneTypeâ object has no attribute âset_midi_learning_modeâ
Feb 11 07:41:01 zynthian startx[434]: zynseq exit
Feb 11 07:41:03 zynthian startx[434]: PNG file: /zynthian/config/img/fb_zynthian_error_ip.png - Application must supply a known background gamma
Feb 11 07:41:03 zynthian startx[434]: /zynthian/config/img/fb_zynthian_error_ip.png is 480x320 PNG image, color type RGB_ALPHA, 8 bit, file gamma 0.4546
Feb 11 07:41:03 zynthian startx[434]: Zooming image by 100%âŚdone
Feb 11 07:41:03 zynthian startx[434]: MergingâŚdone
Feb 11 07:41:03 zynthian startx[434]: Building XImageâŚdone
OK, fresh install. Like usual
Welcome to the world of development âŚ
Hello @Kiron . Error message on display with zynthianâs IP means that jack audio server isnât started. Log in to the webconf with a web browser pointing to the given IP adress and set your audio device correctly.
No way. I tried everything. I write posts after hours and hours of experimenting
I can confirm !!!
My test setup was working fine under feature/stepseq branch from 5 feb, commit 2c944bb
Iâve just done a system upgrade and get the error screen with the IP adress. Iâve checked if this happens because jackd server not running and jackd server is running !!!
Please note that Iâm running a test setup, without encoders.
And now it starts !
Yeah, jack must be running on mine, as it even works as an amp for me⌠I mean⌠I plug in a guitar and I hear output. Something to do with how âdummiesâ bind midi perhaps? I will try your fix this evening.
Thanks @le51. Changing the wiring as you showed worked for me. Now I can try out the new NoVNC web UI.
Thanks guys⌠the 0,0,0,0 trick worked for me
