I’m facing restarts on my Zynthian as this. Zynhtian starts, I can play for few seconds, then it restarts UI (zynthian service/not reboot) on itself, then I can play again same amount (seem like same amount to me) of time and next restart and so on.
It happens on one USB audio interface (Topping NX4DSD) which resides under hw:1 under jack/alsa config. This was previously working without issues (some month ago when I tried Zynthian for the first time). There is no USB device disconnect in dmesg, switched cables, same issue.
When using different USB audio interface (Fiio M5) residing on hw:0, it stops restarting. Unfortunately, this interface is not usable for playing as it have too much internal latency [aaargh, if it wasn’t so, it would be the best solution as it is small as matchbox and sounds fantastic too].
Besides hw:0 vs hw:1 difference, all other jackd settings are the same
Anyone has any idea? It was working perfectly before, no custom things on this besides screen calibration. Anything to check? Any logs needed? Please help.
OK, situation is this. If I start zynthian without MIDI keyboard, it works. If I start it with keyboard, it doesn’t . Card ID is different, then (aplay -l reports card 0), but it plays for some time anyway. When I connect MIDI keyboard after Zythian UI starts, it works as should.
Removed log as it wasn’t corespnding to errorneous state as I thought.
I have put it away already. My musical inspiration has been burried by this issue. Maybe after few days I will turn it on again Meanwhile could you please check that list above if it not somehow related?
Yes, this could solve the problem using console But some straight forward setup from within UI/Webconf would be better for non-fiddlers. At least show the name of the card to not having to open up ssh console to find out.
