Zynthian User Guides
If you are new to zynthian or upgrading to a new version, please read the user guides that the team have spent so much time creating. These may not yet be complete and you may need to look at some older guides to further inform yourself of operations that are yet to be documented in the latest version but most of what you want to know is there.
Doing this may reduce the quantity of repeated questions here in the forum and you will learn a lot about what zynthian can do and how you may use it in ways you didn’t expect.
The main guides are:
The index of guides is here which lists all the guides including legacy ones.
Thank you so much to everyone involved for Orum and the updated guides. I love them so much xxx
Regarding the ORAM User’s Guide, where can I report findings for that? I just found the note:
Note:
The MAIN Volume is always available with one click. Push MIX button and rotate Knob#3 to change the MAIN volume.
But directly when the PAD/STEP button is pressed with the step sequencer, this shortcut isn’t working anymore.
What is the right workflow?
HW: Zynthian V5.1
zyncoder: oram (ea17c87)
zynthian-ui: oram (37b776a)
zynthian-sys: oram (ec9de8c)
zynthian-data: oram (781d76c)
zynthian-webconf: oram (0e2c255)
same in oram-2511.3
