First message here, so hello community , and congrats to the team for this exciting project.
I bought the V2 kit some time ago, assembled it and encountered a problem with the encoders. It was February then, I intended to post on this board but didn’t do it, and now it’s September – more than time to try to solve this issue, my Deluge is craving for a multitimbral companion!
The issue is the following: soldering looks good, assembly too, the Zynthian is starting when I plug it in, I see the UI and the touch screen seems to work, but none of the encoders are responding. Again, the assembly and soldering look good.
Hi @JeremyG!
What SD-image are you using? It’s updated to the last?
Could you send some photos of your encoders and AllInOne circuit?
Also, send a screenshot of the webconf tool dashboard …
If you are using the Aruk RC-3 SD image (you should!), you will note that the controllers are not working at all. This SD image is pre-configured for working with the kit v2, so you need to configure the software for working with the kit v3.
