You can download the latest ZynthianOS nightly-builds from here:
We removed the ttl generation of DISTHRO which needs to be fixed, but still.
Greaaaat!! We are sooo close now … currently I’m on holidays, but i will work on the TTL generation as soon as i come back to home.
Thanks for your great work!!
Hi guys!
I updated my Zynthian with the last image available for download.
I noticed a small problem in the AmpVTS - CAPS plugin. When I add it to the pedalboard, the plugin is muted.
Any tips?
Regards, Rod
Just got a Pi Zero up and running Raspbian Lite.
This tells you how to boot without anything other than a PSU !!
Basically you build an image with a wpa_supplicant.conf file in /boot
and also an empty ssh file to enable ssh
Well it saves having to buy Micro HDMI cables!
and you don’t even need a mains PSU … .
The new nightly (which is not stable at all) comes with a file zynthianos-wpa-supplicant.txt in the boot folder, so you don’t have to create it.
I suspect I’m going to have to get a screen on it to see what it’s actually up to.
More money for amazon cables . …
So how should we report issues with this? github zynthian-sys?
1 - Its causing Pianoteq with the new Steingraeber to crackle (I assume thats cpu issues) significantly ie sometimes every minute or so as I’m playing.
2 - the encoders do not work at all. Boots into zynthian fine with no error but encoders don’t work
3 - small text, reorganization is hard to evaluate without working encoders because it definitely makes the touchscreen much harder to use.
4 - X11 forwarding (required for pianoteq licensing/configuration) is broken because of the pi user acting as the ssh login point. Adding a password to root is the most direct fix. If my X11 forwarding foo was stronger maybe there is a better workaround?
zynthian-sys is a good location to report to. Sorry for the delay. I didn’t see this here.
Jenkins url has been updated now to: https://jenkins.zynthian.org/
Has https too
Thanks a lot, @guysoft!!
uhh! Since the last update something broke…
When I’m adding more than one layer I see that the midichannel I used is eliminated from the list! So I can use each midi channel for only one layer. Help please!
and I just realized, it doesnt matter anymore which midi channel I chose. If I select ch1 its playing even though my keyboard is set to ch7
sounds like you enabled SingleChannelMode
I know! But I didnt!
My friend, but this is not a bug, but a feature.
Having several layers un the same MIDI Channel is not allowed never more. You should be using the clone option …
oops, thanks! Thats good news! Great that we have this layer effect option now also!!
Hello! I would like to try the new OS but I can’t find anything there, I’m doing something wrong, I suppose…
andrea
Hello @jofemodo,
I can confirm @sadkermit’s posted picture,
but I see this file with Win7 firefox as well as opera:
2019-02-05_.md5 from 2019-02-05 23:04 filesize 0
I guess the nightly build was not ready, at least for this night…
Hi @zynthianers!
ZynthianOS nightly builds are failing from some days ago, and the auto-remove script has deleted the last builds. Sorry … i will check it ASAP. Give me some days for putting some order in my new house …
look good thanks
