New webconf menu item under library. Soundfonts?
The screen contains an upload area for gig, sfz or sf2 files.
They are stored under zynthian-my-data/soundfonts.
Guess we need something for the subdirectory structure as well.
I have to figure out first, if fluidsynth can handle subdirectories under /sf2 as well.
So maybe we need a left tree for the directories and a right part for the upload.
I going to provide a renaming feature.
Do we need a Download as well?
I am not sure because of security reason.
The webconf has a login, but most of the time it will be the default password.
And imagine you have a licenced soundfont?
Excuse the “silence”. I was full-time busy moving back from the country side to the city …
I’ve been testing the new soundfont manager and it works perfectly. The Musical Artifacts integrations is woaooooo!! Greaaaaaat!! Congratulations for your huge work!! I love you, man!!!
The only detail i see is when renaming soundfonts: you can change the file extension and this is not desirable because Zynthian UI use extensions to find and list the soundfonts, so if you make an error while renaming and change the extension, the soundfont wont be availble in the UI and you would need to rename again to fix the problem. I think it would be better to exclude the extension from the renaming function. Anyway, it’s not a priority task
I merge with master, but the development of this feature continues in the specific branch.
after hading much trouble with updates, now I got everything up and running from a fresh gorgona image. I had to “apt update && apt upgrade -y” between some update steps. AND I had to fix some lines in /boot/config.txt for getting the new kernel running with MIDI:
# Adjust Serial Port Clock to allow MIDI baudrate 31250
#init_uart_clock=2441000
#init_uart_baud=38400
#dtparam=uart0_clkrate=3000000
dtoverlay=midi-uart0
I also tested the soundfont upload feature. Wow - everything’s working currently really fine! Thanks for your effort the last weeks!!! Nice work!
sorry for opening this old topic, but I have a question:
Is it possible to change the upload path for records to another location like usb stick?
As I use internal usb stick as music and record storage, I want to be able to just upload music/records without the struggle of usb stick dis-/connection.
The recording infrastructure with regard to capacity is probably one of the hardest bits of all this to test.
as @le51 says if you go to Github where code hangs out.
Then select New Feature request, people often mistake bugs for feature requests cos it aon’t doing what I want, so it’s a bug… Nope you are requesting a feature.
Now you have to get specific cos there’s a template there to help you.
exactly.
And if you have permanently the problem that you want to record to the external drive, make the capture directory a symbolic link to your external device.
