After it’s whistlestop tour of Essex the Pedalboard has now had a large 100 x 500mm piece of stripboard added to mount the hall effect boards on and the arduino added and all connected up . . .
I suspect I might combine the two emergency switch with audio relays so the audio path is not taken to the front paneland also so that one switch also switches the audio straight throu’ in analogue bypass whilst the machine reboots. But that’s a long term plan.
Just back from dungeons 2020.
oubliette water features very big this year…
Pedalboard rebraining proceeds apace.
I have a dns issue somewhere as zynthian.local wont resolve, but The maturity of the boot up process revealed as once the zynth had tried to run itself a couple of times it failed out to the hdmi screen, with the current IP address displayed!
If this was designed, it’s good!
So I can get to the webconf…
And give the machine it’s identity. (Should really try a backup and restore).
Your reed switch scale reminds me of a guy who made something (The chimaera) a “poly-magneto-phonic-theremin” that can sound like a violin, played with a magnet acting like a guitar slide. He used an array of about 128 hall sensors. He shared a bunch of math involved in spanning a range. They have 13 utility LV2 plugins that work with arm7, arm64.
(I got some 3D hall sensors like you see used inside rotary and slide controls, to see if fewer sensors could be used for a continuous musical control.)
Another nonsequter, Vangelis has a rig with odd preset iconography on paper selection drums he’s shown improvising and orchestrating a sound tracks using 16 expression pedals to mix patches.
Yes, I really like the hall effect sensors.
I can also get a variable voltage out of them as well which I’ve mentally confined to the subsequent upgrade. Because I am being chased for a I need to declare this finished !!
And I’ve seen the Vangelis interface. I have been watching several CS80 vids ( The synth I’d most like to own) and I was surprised how much of vangelis’s sounds were actually straight presets … Unless of course you listen to Beaubourg !!!
Black Lotus Audio has a free Vital preset called “I want a CS80” their description: “For when you’re Vangealous of the bladerunner soundtrack”
It sounds like a Trombone.
Noice! One suggestion, how about adding a hinged flap that covers the screen with a catch or magnet to hold it closed during transit? Maybe it could drop down the back when in use. The screen looks prone for damage.
I think you might be right about the screen. I ended up using double sided tape to hold the screen so it’s a little more proud than would have been preferable.
One possible solution which I rather liked was a CNC cut brass plate right across the front with the switches set in to and the screen recessed …
Just really glad to have ‘finished’ ( Yeah right) the hardware side.
Now just setting up the audio in and out levels using a zynth on the input and one on the output… and the sine wave generator engine, which sadly doesn’t have a left/right mute which would be really helpful. I’m reading up on LV2 to see if I could alter it suitably to add them or build a test tone generator from scratch…
Given the complexities of stereo in with mono defeat on one channel and the cross wired mono outputs that should provide stereo if two jacks plugged in and a mixed mono if only one used ( nicked from the alpha juno 2 circuit ) .
However the bypass switch is helping a lot with the line up process and it’s status is now indicated by the colour of the LED on the front panel. Red for zynth in circuit, green or off for bypassed… IT’s mostly sitting and soak testing at the moment.
