Akai APC mini mk2
Dear Zynthian community,
is there a chance that the Akai APC mini mk2 will be supported with Zynthian OS Vangelis? It is a great controler and I think it would work just perfect with ZynSeq. Someone was working on it in 2024, but it seems the project was not continued.
Best regards,
Anzound
I don’t know what the chances are that someone will write a Control-Driver for the Akai APC mini mk2.
Are you aware of the support for the Akai MPK mini MK3?
and the Akai APC Key25 MK2:
Yes, I do know that these controlers are supported. I saw that eif was working on it:
But I think the apc mini mk2 is still not supported. I’m not a programmer so I don’t know how difficult it is to change the driver from the akai apc key25.
The major problem here is that the developer needs to have access to that specific device. Otherwise, while may be posible, is far more complicated, cumbersome and prone to be a source of frustration, if not a waste of time.
What I mean is that we need a developer with that device and also the time and desire to do it.
Thank you for your reply. I understand that it is necessary to have the device to make a driver. Would it somehow be possible to use the drivenbymoss driver which is available for Bitwig and Reaper in Linux?
Best regards.
That driver is made with Java, and for other, very different platform. It could be a source of relevant information, but porting it would mean more work than adapting an existing Zynthian driver.
Since the wishlist ist not continued ist there another way to promote the idea of an akai apc mini mk2 driver?
We love the idea of providing integration with as many devices as we can but there is a technical challenge to design, build and test integration with a device we don’t possess. There is a time challenge to do this when other commitments are more urgent. There is an enthusiasm challenge where the author is not the beneficiary. These developments tend to happen when someone has the device and the skills, time and enthusiasm to do it.
Hi Riban, I do understand. Thank you for the explanation. I was maybe naively thinking that the driver for the Akai APC key might with some easy tweaking be able to run the APC mini MK2 as well. But I’m not an prorgrammer. So I might have understimated the complexity. Thank you for the work you put otherwise in Zynthian :slight_smile:
Hi @Anzound,
Have you considered trying to create such a driver yourself? Others have been motivated to learn this even if they didn’t have the knowledge before.
I bought one and hoped that i could make a driver, but i have not yet!
But i have started to look at ctrl-drivers in general, and have gone some very small baby steps - and i sort of wait for the other Akai drivers (specifically that for the Akai APC Key25 MK2) are ready for Vangelis
All I can say is: sit tight. It’s proving more difficult than I had hoped. Especially the fact that the Zynthian UI (launcher, which has taken the place of zynpad, and pattern editor) does not respond as automatically to changes in zynseq (at least, in the way that driver makes them) and friends as before it seems. But it’s getting better all the time. Most stuff works, but there are crazy spots that need ironing out.
In case you want to track my progress, it is at GitHub - pft/zynthian-ui at fix-apckey25-in-zynbleton .
Note that I often rebase this on vangelis, to keep the commit history clearer to myself.
I will follow progress and try to learn something. Thanks Niels for the work!
I’m sorry but I think that’s beyond my skill level. I try to make music software work in linux, too. But coding is out of my league.
So you were right @jawn . Thanks to Vibecoding I could develop a nice driver with the help of the european AI Vibe from Mistral :grin: So it’s literally vibecoding. I’m happy that it not only offers the control of Zynbleton but that the Drum and Note Mode works too. So you can use it as a launcher for scenes and as a Midi controller to play your instruments. Have fun playing with it.
Attached you find the driver and the readme @jofemodo @riban I’m glad that I could now contribute actively to the Zynthian project :slightly_smiling_face:
readme-akai-apc-mini-mk2-treiber-für-zynthian-v5-vangelis.pdf (43.4 KB)
zynthian-v5-1-vangelis-treiber-akai-apc-mini-mk2.py (31.5 KB)
