Really nice extension! Congratulations, my friend! Do you intend to use it with the SooperLooper plugin or what? I think it work nicely with the momentary switches (play/stop/back,etc.). Also setBfree allows toggling the lesslie speed using momentary switch. I would like to add some code for allowing to use momentary switches as “normal” switches with 2 states: 0 or 127. There are many parameters that works in that way and currently you can’t use the momentary switches for controlling these parameters.
Yes, it is mainly for SooperLooper, sequencer, this kind of things…
I also developed a small puredata FM synth combinated with generative events (samples, sequences, tone changes, …) and I want to pilot it with this pedal. Sure, I’ll make some sample !
The pedalboard is made of wood, I used what I had in my stock to build it.
It is a 32cm * 8 cm * 3,2 cm box. Any similar dimension box would do.
3,2 cm is a bit thick, the thiner the better, but the limit is the switch dimension.
It is also a bit wobbly, I need to add some anti-slip pads.
A puredata sequencer controled by the 4 switches:
Buton 1: Start/Stop
Buton 2: Activate noises
Buton 3: Activate random voice samples
Buton 4: Activate random FM modulation on sequenced patern
