I know what I will be playing with end of the year
Contributed
You are awesome !
With this hardware release, I am trying to standardise the analogue connectors for my sound cards. So that preamplifiers and other āskinsā can be reused between products.
The end goal is also to have people design their own analogue skins and reuse them.
Matt
Made my contribution as well!
Been looking for that additional motivation to make a younger brother to my zynthian (as in better, and not more stubborn
Would the analogue skins be powered and if so how�
Great, thanks for the backing!
Regarding power, I am creating a standard :
Basically, ±12V rails and phantom. There is also a dirty un-isolated +5V, which requires an isolation barrier if you try to use that rail. That rail ties to some GPIO lines for unisolated control.
Winter is comingā¦
And I made the first steps in the snow.
Installed it with dtoverlay=audioinjector-isolated-soundcard,
jackd-options:
-P 70 -t 2000 -s -d alsa -d hw:audioinjectoris -S -r 44100 -p 256 -n 2 -X raw
alsamixer sees it.
But no sound with mpg123 test.mp3
Started qjackctl, no service running.
In the options, (default) as interface was still selected. Hence I chose audioinjectoris.
But when starting:
12:37:02.496 /usr/local/bin/jackd -dalsa -dhw:audioinjectoris -r48000 -p1024 -n3
Cannot read socket fd = 18 err = Success
CheckRes error
JackSocketClientChannel read fail
Cannot open qjackctl client
JackShmReadWritePtr1::~JackShmReadWritePtr1 - Init not done for -1, skipping unlock
JackShmReadWritePtr::~JackShmReadWritePtr - Init not done for -1, skipping unlock
12:37:02.520 JACK was started with PID=1980.
`defaultā server already active
Do I have to stop a zynthian instance first? Does qjackctl not see it?
And we will have a little coding to do as well, @jofemodo.
The capture controls are not displayed, because they are integrated.
Simple mixer control 'Master',0
Capabilities: pvolume pswitch cswitch
Playback channels: Front Left - Front Right
Capture channels: Front Left - Front Right
Limits: Playback 0 - 127
Front Left: Playback 120 [76%] [-7.00dB] [on] Capture [on]
Front Right: Playback 120 [76%] [-7.00dB] [on] Capture [on]
Our parser canāt handle this. Only the Master Left and Master Right are displayed.
Pictures �
4 posts were split to a new topic: Audioinjector issues
my issue is isolated related. It doesnāt work in raspbianos either. I wrote @flatmax already.
Matt and I figured that my card must be broken.
So I have time to tackle the next issues.
I am not able to mount the USB-C plain to the case.
What is the best solution? Has anybody tried the Neutrik NMC-C receptacle?
Or is it a bad idea to use an adapter at all?
I think youād be better off taking the connectors off the board and just taking the hot & cold twisted together to a separate connector.
Letās deal with that on email.
Hi folks! Took me a long while to start experimenting with this Isolated board, but Iām now getting to it.
Iāve picked up a RPi4, with a 5ā touchscreen LCD (USB+HDMI), and Iām reusing the AllInOne 2.0 that I had on my previous RPi3 Zynthian (connecting it to the 4 encoders, 3 MIDI DINs and now soldered to a 5 prong JST to allow me to get those lovely switches that popped up in the Zynthian world since I last messed around with the box!)
Advised by @flatmax, I set the automute to off in alsamixer, and that gets rid of some really nasty physical clicks after note offs - that makes it sound fantastic (Big thangs, Matt!). I tried the audio in, and while thereās no capture level settings on alsamixer, it works perfectly.
Some issues Iām experiencing:
- MIDI DIN IN isnāt working, i can only use USB. Leds work, MIDI through works, but nothing comes up in the log when using the MIDI IN. I read some other posts here advising to test different connectors, but nothing. I did one better, and swapped the Isolated DAC with my old (but working) Hifiberry DAC+. And this gets MIDI IN to work! so I know itās something in the Isolated board side. Iāll go over the 40pin soldering quality (visually looks ok, but I have to be sure, I know), but I wonder if this board is using GPIO pins that Hifiberry DAC+ isnāt? Anyone knows if I can āredirectā the MIDI in to another unused pin (and how? webconf somewhere?)
- The stack is āfatā
@mheidt, how did you get along with your board? I think @wyleu has the right idea if this has to get into a tight enclosure. Iām using a plastic Hammond box, and itās rather messy, with RCA cables coming out through a hole - all very temporary until Iām happy with the whole system. But the HDMI cable is actually the major blocker. - Temperature. Iāve got no fans / additional heatsinks, so the boards warm up a bit - but nothing critical. I get the temperature icon only if I close the box completely - which I donāt intend to, leaving the base 5mm separated is enough to give airflow, without breaking any functionality / without looking terrible
- Power. I had a step down converter (to USB) that fed my Hifiberry old box without issues, now with this board it seems to cause undervoltage (the red icon on screen at least). For now Iām using a power bank straight to RBPi usbc ,and seems to work. So Iāll try a different approach, using a step down convertor soldered straight to the Pi, maybe with a ferrite ring to reduce the noise (i think i saw some posts here as success stories for that). Btw, the powerbank is very clean!
Of the above, my priority is to have my MIDI IN working via DIN - Iāll welcome any pointers to look into!
(Last, but not least - Iāve ordered some food for the ravens, just need time away for the day job for a bit and Iāll feed them accordingly)
Anyone else using this board? Would be nice to see some feedback for it in the forum.
Hi Edgar,
Yes, itās still an open project for me. Unfortunately I donāt find a lot of time since Corona. I am the only happy internal developer that had to take the job of 5 external ones.
But I can show you, what I got.
- Yes, I had issues finding the right pins. I think, MIDI did work. But itās been almost 2 years since I tested it.
- Yes, itās fatā¦fatmax he should call himselfā¦
I am trying to lay it on a square MIDI port.
- And yesā¦HDMI: I bought a āU-Turnā
I had another issue, that the screen needed the USB as well.
Hi @mheidt!!
Nice to read from you!
You are building a nice wood case. Hope you can finish it soon.
Cheers!
Oh wow, your enclosure looks promising! Iāll show what Iām currently at, but itāll just serve as a boost to how good yours look
please, donāt give up on it - take your time but see it through
As for its insides. Please consider that this is functionally an open workbench - crammed up into a plastic box so I can easily turn it around and test it
(itās dreadful, I know!)
Still about the midi in GPIO pin, I assume the all in one is picking up the midi in/out/trough and sending them via the chip to the fixed RBPi GPIO pins. My question is, would I be able to swap the pins say from through to in, in any configuration file/webconf? I know the Through DIN is working (it passes midi received via USB). Just to understand whatās the problem - soldering, or anything else on my setup.
There is a well known (withing the zynthian world anywayā¦) That the LED is an active component in the MIDI circuit and if not included removes a current return path.
Might this is be involved?
There is an infuriating level with all MIDI hardware that you are simply relying on magic to happen, and reversals tend to upset the rig as well, so that is well worth a multimeter check to ensure pins go in the correct direction. Itās easy to see it as a voltage based system, but itās current based and itās an important point to realise.
My Audio injectors,( I havent got the big one, althouā I do believe I kickstarted, but probably didnāt pick up ) tend to not start up when stored as a dfault layer. Since I use this in both my guitar input devices this is a bit of a pain because a restart live would involve about two minutes of audience chattter, and then you have to delete and reaquire the zeros I use ( they are small and you can take wires directly onto the board. As with all zynth hardware it all comes down to how you access the connectors, especially if you wire i/o pin to i/o pin.
Iāve added fans into the pedal board and the temperature is a much more acceptable 45 degrees. This is a Pi4. My other audio injector input device (zynthian-alm.local) is a Pi3 in a Pi3 case so is more likely to be replaced rather than upgraded.
It seems the audio injector disciples, donāt add S1-4
Two things tell me it shouldnāt be the case. One, LEDs are lightning up on activity - even for this MIDI IN that Iām complaining about. Two, the MIDI IN is working if I swap the DAC (same components otherwise).
Thatās next on my to-do, but need a bit more time to get to it. I also need to check the audioinjector 40 pin connector is well soldered.
Itās still early days, but I havenāt found that to be the case!
And considering Iād keep this zynthian close to me, would you say the fans are noisy enough to be a nuisance? I like how quiet it is right now!
Hey, I do want them - nay, I need them
itās just not as high on the priority list as getting MIDI, power and a case I can be proud to look at, sorted. That being said, I did make the first step and soldered the JST in the all in one board - Iām still wondering wether Iāll have the soft buttons or a pedal switchboard (I havenāt tested zynthianās loopers, that might be a big influence on that decision!)
I have heard complaints of this, so give it a look. Not seen it myself unless itās a very pernicious intermittent!
Seems to depend on the fans. The pedal board has got 3(?) in it simply cos I could produce a fiendish contraption with cable ties to easily carry the fans near the 7" screen . . .
Itās a fairly solid piece of mdf and the fan noise cannot be detected in any environment it was doing any work. Itās not been in a studio yet so thatās where it would be tested properly.
However the 5v fan on a hifiberry 2/pi4/ hifiberry steel case thingy (zynthian-amp4.local) is a noisy beast with particularly irritating and detectable overtones.
The whole world has come on in the world of Raspberry Pi fans and they are now a supported tool in the raspi-config where you can specify on off temps etc if you are willing to add a transistor and a defined GPIpin or better still a PWM 5v fan.
I donāt think this has made it into the zynth yet but it would seem a sensible addition to support house style in this regard.
Adding heat sinks to the chips in the hifberry seems to addressed the problems and it sustains itself ( on all the time) so I havenāt really pursued that too much.
