<BETA-WARNING>
I have written some installation scripts for much more LV2 plugins. To use them you can do the following:
ssh admin@<YOUR-ZYNTHIAN-IP>
cd /zynthian
git clone https://github.com/dcoredump/zynthian-recipe
cd zynthian-recipe/recipe
sh update_zynthian.sh # This will take a while an dhopefully produces no error!
After installation there will be about 500 plugins available. Take a look at update_zynthian.sh for a list of bundles which will be updated or installed. You can call the script as often as you like. It should update your system if there were changes in the repositories.
Some installation scripts are not used because there are already system installations in use. </BETA-WARNING>
This sounds great - thankyou! I tried to update (I changed ‘cd zynthian-recipe/recpipe’ to ‘…recipe’ as I guess that’s a typo?) and it all downloaded etc but the update failed with these messages:
zynthian_envars.sh [[:not found
56: export: 3: bad variable name.
Any ideas?
It works great! Thank you very much! It’s like Christmas!
Not wishing to derail the topic, but do you know if it’s possible to build a modular synth with this? I can see all sorts of components in there which look like bits of a modular, but there are some crucial things missing (or I can’t find them) to get MIDI into them. I’m guessing some kind of MIDI-CV thing and a triggerable envelope / gate. I’m sure I’m missing a trick somewhere as there are so many esoteric plugins that look suspiciously modular?
I think I have found the problem. I located a wrong package I installed inside mod-sdk.sh. It is fixed in the current recipe but for roll back you need to do the following:
apt-get purge python3-tornado python3-pystache
If this does not help the following may also help:
cd /zynthian/zynthian-sw/mod-ui
pip3 uninstall tornado
pip3 install tornado
I also fixed an error inside fil4.sh - there were some errors in the script and it stopped without installation. Can you try the fixes?
update_zynthian.sh: 45: /zynthian/zynthian-recipe/zynthian_envars.sh: [[: not found
update_zynthian.sh: 56: export: 3: bad variable name
Then I tried the infamous plugins on the Zynthian and it failed the following way:
root@zynthian:/zynthian/zynthian-recipe/recipe# sh infamous.sh
Cloning into 'infamousPlugins'...
remote: Counting objects: 5309, done.
remote: Compressing objects: 100% (10/10), done.
remote: Total 5309 (delta 2), reused 7 (delta 2), pack-reused 5297
Receiving objects: 100% (5309/5309), 3.96 MiB | 2.61 MiB/s, done.
Resolving deltas: 100% (3892/3892), done.
Checking connectivity... done.
-- The C compiler identification is GNU 4.9.2
-- The CXX compiler identification is GNU 4.9.2
-- Check for working C compiler: /usr/bin/cc
-- Check for working C compiler: /usr/bin/cc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Detecting C compile features
-- Detecting C compile features - done
-- Check for working CXX compiler: /usr/bin/c++
-- Check for working CXX compiler: /usr/bin/c++ -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Performing Test SUPPORTS_SSE
-- Performing Test SUPPORTS_SSE - Failed
-- Performing Test SUPPORTS_FAST_MATH
-- Performing Test SUPPORTS_FAST_MATH - Success
-- Found PkgConfig: /usr/bin/pkg-config (found version "0.28")
-- Checking for module 'cairo'
-- Found cairo, version 1.14.0
-- Checking for module 'ntk'
-- Found ntk, version 1.3.0
-- Checking for module 'lv2>=.0.1.0'
-- Found lv2, version 1.15.1
-- Checking for module 'fftw3f'
-- Found fftw3f, version 3.3.4
-- Configuring done
-- Generating done
-- Build files have been written to: /zynthian/zynthian-sw/plugins/infamousPlugins/build
Scanning dependencies of target infamous-rule
[ 1%] Building C object CMakeFiles/infamous-rule.dir/src/rule.c.o
[ 2%] Linking C executable infamous-rule
[ 2%] Built target infamous-rule
[ 4%] Generating casynth_ui.h
Scanning dependencies of target casynth_ui
[ 5%] Building CXX object src/casynth/CMakeFiles/casynth_ui.dir/casynth_ui_main.cxx.o
[ 6%] Building CXX object src/casynth/CMakeFiles/casynth_ui.dir/casynth_ui.cxx.o
[ 8%] Linking CXX shared library casynth_ui.so
[ 9%] Built target casynth_ui
[ 10%] Building C object src/casynth/CMakeFiles/casynth.dir/casynth.c.o
[ 12%] Building C object src/casynth/CMakeFiles/casynth.dir/waves.c.o
[ 13%] Building C object src/casynth/CMakeFiles/casynth.dir/note.c.o
[ 14%] Linking C shared library casynth.so
[ 14%] Built target casynth
[ 16%] Generating envfollowerCV_ui.h
Scanning dependencies of target envfollowerCV_ui
[ 17%] Building CXX object src/envfollower/CMakeFiles/envfollowerCV_ui.dir/envfollower_ui_main.cxx.o
[ 18%] Building CXX object src/envfollower/CMakeFiles/envfollowerCV_ui.dir/envfollowerCV_ui.cxx.o
[ 20%] Linking CXX shared library envfollowerCV_ui.so
[ 21%] Built target envfollowerCV_ui
[ 22%] Generating envfollower_ui.h
Scanning dependencies of target envfollower_ui
[ 24%] Building CXX object src/envfollower/CMakeFiles/envfollower_ui.dir/envfollower_ui_main.cxx.o
[ 25%] Building CXX object src/envfollower/CMakeFiles/envfollower_ui.dir/envfollower_ui.cxx.o
[ 27%] Linking CXX shared library envfollower_ui.so
[ 28%] Built target envfollower_ui
[ 29%] Building C object src/envfollower/CMakeFiles/envfollower.dir/envfollower.c.o
[ 31%] Building C object src/envfollower/CMakeFiles/envfollower.dir/rms_calc.c.o
[ 32%] Linking C shared library envfollower.so
[ 32%] Built target envfollower
[ 33%] Generating hip2b_ui.h
Scanning dependencies of target hip2b_ui
[ 35%] Building CXX object src/hip2b/CMakeFiles/hip2b_ui.dir/hip2b_ui_main.cxx.o
[ 36%] Building CXX object src/hip2b/CMakeFiles/hip2b_ui.dir/hip2b_ui.cxx.o
[ 37%] Linking CXX shared library hip2b_ui.so
[ 39%] Built target hip2b_ui
[ 40%] Building C object src/hip2b/CMakeFiles/hip2b.dir/square.c.o
[ 41%] Linking C shared library hip2b.so
[ 41%] Built target hip2b
[ 43%] Generating powerup_ui.h
Scanning dependencies of target powerup_ui
[ 44%] Building CXX object src/powerup/CMakeFiles/powerup_ui.dir/powerup_ui_main.cxx.o
[ 45%] Building CXX object src/powerup/CMakeFiles/powerup_ui.dir/powerup_ui.cxx.o
[ 47%] Linking CXX shared library powerup_ui.so
[ 48%] Built target powerup_ui
[ 50%] Building C object src/powerup/CMakeFiles/powerup.dir/powerup.c.o
[ 51%] Linking C shared library powerup.so
[ 51%] Built target powerup
[ 52%] Generating powercut_ui.h
Scanning dependencies of target powercut_ui
[ 54%] Building CXX object src/powercut/CMakeFiles/powercut_ui.dir/powercut_ui_main.cxx.o
[ 55%] Building CXX object src/powercut/CMakeFiles/powercut_ui.dir/powercut_ui.cxx.o
[ 56%] Linking CXX shared library powercut_ui.so
[ 58%] Built target powercut_ui
[ 59%] Building C object src/powercut/CMakeFiles/powercut.dir/powercut.c.o
[ 60%] Linking C shared library powercut.so
[ 60%] Built target powercut
[ 62%] Generating cheapdist_ui.h
Scanning dependencies of target cheapdist_ui
[ 63%] Building CXX object src/cheapdist/CMakeFiles/cheapdist_ui.dir/cheapdist_ui_main.cxx.o
[ 64%] Building CXX object src/cheapdist/CMakeFiles/cheapdist_ui.dir/cheapdist_ui.cxx.o
[ 66%] Linking CXX shared library cheapdist_ui.so
[ 67%] Built target cheapdist_ui
[ 68%] Building C object src/cheapdist/CMakeFiles/cheapdist.dir/cheapdist.c.o
[ 70%] Linking C shared library cheapdist.so
[ 70%] Built target cheapdist
[ 71%] Generating stuck_ui.h
Scanning dependencies of target stuck_ui
[ 72%] Building CXX object src/stuck/CMakeFiles/stuck_ui.dir/stuck_ui_main.cxx.o
[ 74%] Building CXX object src/stuck/CMakeFiles/stuck_ui.dir/stuck_ui.cxx.o
[ 75%] Linking CXX shared library stuck_ui.so
[ 77%] Built target stuck_ui
[ 78%] Building C object src/stuck/CMakeFiles/stuck.dir/stuck.c.o
[ 79%] Building C object src/stuck/CMakeFiles/stuck.dir/rms_calc.c.o
[ 81%] Linking C shared library stuck.so
[ 81%] Built target stuck
Scanning dependencies of target ewham
[ 82%] Building C object src/ewham/CMakeFiles/ewham.dir/ewham.c.o
[ 83%] Building C object src/ewham/CMakeFiles/ewham.dir/retuner.c.o
/zynthian/zynthian-sw/plugins/infamousPlugins/src/ewham/retuner.c: In function ‘RetunerAlloc’:
/zynthian/zynthian-sw/plugins/infamousPlugins/src/ewham/retuner.c:235:1: warning: label ‘fail’ defined but not used [-Wunused-label]
fail:
/zynthian/zynthian-sw/plugins/infamousPlugins/src/ewham/retuner.c: In function ‘findcycle’:
/zynthian/zynthian-sw/plugins/infamousPlugins/src/ewham/retuner.c:295:12: warning: variable ‘d’ set but not used [-Wunused-but-set-variable]
int d, h, i, j, k;
[ 85%] Linking C shared library ewham.so
/usr/bin/ld: cannot find -lzita-resampler
collect2: error: ld returned 1 exit status
src/ewham/CMakeFiles/ewham.dir/build.make:120: recipe for target 'src/ewham/ewham.so' failed
make[2]: *** [src/ewham/ewham.so] Error 1
CMakeFiles/Makefile2:851: recipe for target 'src/ewham/CMakeFiles/ewham.dir/all' failed
make[1]: *** [src/ewham/CMakeFiles/ewham.dir/all] Error 2
Makefile:127: recipe for target 'all' failed
make: *** [all] Error 2
[ 82%] Linking C shared library ewham.so
mv: cannot stat ‘/zynthian/zynthian-plugins/bin/infamous-rule’: No such file or directory
