Boot asks for login on new V5.1 [Solved]
Hi! I just assembled the V5.1 and after first boot I got the reversed boot info, then a single “_” character on screen.
I waited for a while and nothing happened.
Then rebooted and I get a “zynthian login:” tty screen.
Any idea how to start troubleshooting this? My first step would be trying another sd, but I got none at hand, hopefully I can try one today/tomorrow.
I read some issues with the overclocking setting, but that doesn’t seem to apply to my case, as the rp5 led is just green.
Ahhh, nevermind, looks like I just had to wait for some more minutes! All is good so far! Amazing!
Glad this worked for you! I’m stuck on:
Debian GNU/Linux 12 Zynthian ttyl
zynthian login:
I let it run for a few hours while I went out.
Any ideas appreciated.
Hi @mredelstein !
Welcome to zynthianland!
Did you try to power-off / power on?
A few times. Same screen. I’m reflashing the SD and checking connections.
If the issue persist, please, try accessing the webconf’s terminal and send the output of this command:
cat /root/first_boot.log
So I reflashed - got scrolling code briefly on the display, then a _ at the bottom right. Then nothing. On reboot, the OPT / ADMIN button is lit purple. Green LED on Pi5 acts as if it’s reading. I’m not sure how to access using terminal given that it won’t boot.
There is no display.
Hi @mredelstein !
Don’t be worried nor frustrated. You will get your zynthian working, OK?
There is some problem with your build, but we will find and solve the issue.
  • Please, confirm the image version you are using is the last one.
I assume you already double-checked the wiring and everything is OK. Please, tell me if you have some doubts/problems while building.
Then , follow this steps carefully:
  • Burn the latest image in a good quality SD-card (>= 32GB)
  • Burn the firmware recovery image in a second SD-card
  • Boot with the recovery image, until you see the blinking green led in the RPi5
  • Boot with the zynthianOS image. It shouldn’t take more than 1-2 minutes to finish and you should see the splash screen before 1 minute
If this doesn’t work, please, try accessing the webconf tool:
  • Connect the zynthian to your router using an ethernet cable
  • Point your browser to one of this locations:
http://zynthian.local
http://zynthian.lan
If you get it, access the terminal and send the output from this command:
If you can’t reach the webconf tool, extract the SD-card and plug in your computer, then access the big partition and send the content of this file:
To be sure, i just tested the latest image (again!) with a fresh zynthian V5.1.
The boot sequence is:
  • Short white flash in the display
  • Inverted log for 1-2 seconds
  • Blanking with small “-” in the right-bottom corner (3-4 seconds)
  • Inverted log for 1/2 second
  • Blanking (5-8 seconds)
  • Splash image before 30 seconds from boot
Thank you for your responses!
  • I have used two different high quality working SD cards - one 32GB and one 256GB with the latest image.
  • I’ve booted with the recovery image and seen the blinking green LED.
  • I’ve attempted the to boot with the latest zynthianOS image.
I’ve repeated the above many times, with fresh images, many formatting of SD cards etc. I’ve even tried SD card direct in the Pi5 and only connecting the display.
One thing that’s odd to me is sometimes I’ll get the white LEDs on the board, and sometimes not. Also the LEDs under the keypad will sometimes light up differently - usually just the top left (different colors) and occasionally the whole keypad. Although the last few attempts they haven’t lit at all.
Another thing - when I first completed the build and tried running, the screen was working. I couldn’t get past the “Debian GNU/Linux 12 Zynthian ttyl
zynthian login:” screen. When I powered off / on and tried again, the screen eventually stopped functioning.
I’m trying to access the partition using Paragon NTFS on my MacBook. I can get the partition to show up but it is not accessible, even using this software so I can’t find the first_boot.log file. Not sure what to do!
The partition is not NTFS but an ext4 partition. For mounting it the best is trying with a linux machine, although i suppose there is some utility for mounting in macOS. For instance:
https://www.jeffgeerling.com/blog/2024/mounting-ext4-linux-usb-drive-on-macos-2024
It’s really strange that you don’t get it working. Have you verified the MD5 sum from the download dir?
https://os.zynthian.org/
We would need some logs to know what is going on, so please, try getting it.
You could try to get the zynthian’s IP from the router to try connecting to the webconf.I’m not sure your mac is resolving the zynthian local name.
Here is first_boot.log
Running autoconfig…
Detected I2C Chips: [‘MCP23017@0x20’, ‘MCP23017@0x21’, ‘PCM1863@0x4A’, ‘PCM5242@0x4D’, ‘RV3028@0x52’, ‘TPA6130@0x60’]
Checking Boards: [‘V5_MAIN’, ‘V5_CONTROL’]
OK: All hardware has been detected!
Detected V5 kit!
Configuring Zynthian for V5 …
Reboot…
Running autoconfig…
Detected V5 kit!
Zynthian already configured for V5.
Fixing ALSA mixer settings…
Regenerating keys…
Removing current webconf cookie secret…
A new webconf cookie secret will be generated on next request.
Removing current system SSH keys…
Generating new system SSH keys…
Generating public/private rsa key pair.
Your identification has been saved in /etc/ssh/ssh_host_rsa_key
Your public key has been saved in /etc/ssh/ssh_host_rsa_key.pub
The key fingerprint is:
SHA256:rZRNgfGxRloDTP04CBKxlxeyE7DxuW3sbHgU+zZ9kig root@zynthian
The key’s randomart image is:
±–[RSA 3072]----+
| =+oo==* |
| .=.o.= |
| o.B.+.=o |
| . .Oo . |
| . S o. |
| B o o . |
| . E = + . |
| o o . o |
±—[SHA256]-----+
Generating public/private dsa key pair.
Your identification has been saved in /etc/ssh/ssh_host_dsa_key
Your public key has been saved in /etc/ssh/ssh_host_dsa_key.pub
SHA256:I5A3DOTQR9opFWQA+wz0LBh+gCyU/bLZdnZHmqWcPAw root@zynthian
±–[DSA 1024]----+
|=o
.B.O… |
|o.+.X.* |
| .* = E o |
| B . S B |
| o o + % . |
| . o . o |
±—[SHA256]-----+
Generating public/private ecdsa key pair.
Your identification has been saved in /etc/ssh/ssh_host_ecdsa_key
Your public key has been saved in /etc/ssh/ssh_host_ecdsa_key.pub
SHA256:sJZINs7w2JWGqDE74D5u5sIDrfxVM4lgBbKQbkWbobI root@zynthian
±–[ECDSA 256]—+
|.o.+… |
|o +o=. . |
|*o+== = |
|+O.X.=.+. |
|Eo. .+=S |
|o… … o |
|=oo. |
±—[SHA256]-----+
Restarting SSH server …
Removing current SSL certificate…
Generating new SSL certificate for 100 years…
Resizing partition…
Hi @mredelstein !
Everything seems totally OK except i can’t see the “splash generation” process for some reason.
The good is that your zynthian is totally operative, but the first boot process is frozen at this last step, preventing the GUI to be launched,.
If you could access the terminal, you could solve it very easily by running this simple command from there:
systemctl disable first_boot
reboot
For reaching the terminal you have several options:
  • If you have the "prompt"in the display, you could connect a keyboard and login:
user: root
password: opensynth
Then simply run the commands above.
  • Connect by ethernet to the router. Then use one of these the local names:
zynthian.local
zynthian.lan
or get the IP your router assign to the zynthian to access in one of this ways.
  • from the browser, to access webconf
  • from a terminal emulator, using SSH
I’m trying to understand what is going on with the first boot process and deploy a fix to avoid this kind of blocking.
Also, please answer these 3 questions:
  1. Could you tell download date of your image?
  2. What is the download link you used and what is the file name you downloaded?
  3. Also, did you check the MD5 sum of this file?
  1. Yesterday
  2. https://os.zynthian.org/zynthianos-last-stable.img.xz
  3. Yes.
I’m uploading a SD image with some changes in the first boot process.
I can’t be sure it works, because i can’t reproduce your issue, but it will generate some extra log on the first boot process. It should be ready for tomorrow.
Anyway, please, try accessing to the terminal by some of the methods i described above.
If you get it, you probably can fix the image and get it to boot. Anyway, something really strange is happening in you first boot process and it must be investigated and fixed.
OK I’m IN the webconfig!
Restarting UI in debug mode
Oct 02 17:40:13 zynthian systemd[1]: Started zynthian_debug.service - Zynthian User Interface (DEBUG).
Oct 02 17:40:13 zynthian startx[1338]: X.Org X Server 1.21.1.7
Oct 02 17:40:13 zynthian startx[1338]: X Protocol Version 11, Revision 0
Oct 02 17:40:13 zynthian startx[1338]: Current Operating System: Linux zynthian 6.6.47-v8-16k+ #1794 SMP PREEMPT Thu Aug 29 16:30:28 BST 2024 aarch64
Oct 02 17:40:13 zynthian startx[1338]: Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe bcm2708_fb.fbwidth=640 bcm2708_fb.fbheight=480 bcm2708_fb.fbdepth=16 bcm2708_fb.fbswap=1 smsc95xx.macaddr=2C:CF:67:75:F8:2B vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000 root=PARTUUID=e249d476-02 rootfstype=ext4 fsck.repair=yes rootwait video=DSI-1:800x480@60,rotate=180 console=tty3 logo.nologo quiet loglevel=2 vt.global_cursor_default=0 modules-load=dwc2,libcomposite
Oct 02 17:40:13 zynthian startx[1338]: xorg-server 2:21.1.7-3+rpt3+deb12u7 (Debian -- User Support)
Oct 02 17:40:13 zynthian startx[1338]: Current version of pixman: 0.42.2
Oct 02 17:40:13 zynthian startx[1338]: Before reporting problems, check http://wiki.x.org
Oct 02 17:40:13 zynthian startx[1338]: to make sure that you have the latest version.
Oct 02 17:40:13 zynthian startx[1338]: Markers: (–) probed, () from config file, (==) default setting,
Oct 02 17:40:13 zynthian startx[1338]: (++) from command line, (!!) notice, (II) informational,
Oct 02 17:40:13 zynthian startx[1338]: (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
Oct 02 17:40:13 zynthian startx[1338]: (==) Log file: “/var/log/Xorg.0.log”, Time: Wed Oct 2 17:40:13 2024
Oct 02 17:40:13 zynthian startx[1338]: (==) Using config directory: “/etc/X11/xorg.conf.d”
Oct 02 17:40:13 zynthian startx[1338]: (==) Using system config directory “/usr/share/X11/xorg.conf.d”
Oct 02 17:40:13 zynthian startx[1338]: (EE)
Oct 02 17:40:13 zynthian startx[1338]: Fatal server error:
Oct 02 17:40:13 zynthian startx[1338]: (EE) no screens found(EE)
Oct 02 17:40:13 zynthian startx[1338]: Please consult the The X.Org Foundation support
Oct 02 17:40:13 zynthian startx[1338]: at http://wiki.x.org
Oct 02 17:40:13 zynthian startx[1338]: for help.
Oct 02 17:40:13 zynthian startx[1338]: (EE) Please also check the log file at “/var/log/Xorg.0.log” for additional information.
Oct 02 17:40:13 zynthian startx[1338]: (EE) Server terminated with error (1). Closing log file.
Oct 02 17:40:28 zynthian startx[1337]: xinit: giving up
Oct 02 17:40:28 zynthian startx[1337]: xinit: unable to connect to X server: Connection refused
Oct 02 17:40:28 zynthian startx[1337]: xinit: server error
Oct 02 17:40:28 zynthian systemd[1]: zynthian_debug.service: Main process exited, code=exited, status=1/FAILURE
Oct 02 17:40:28 zynthian systemd[1]: zynthian_debug.service: Failed with result ‘exit-code’.
Oct 02 17:40:33 zynthian systemd[1]: zynthian_debug.service: Scheduled restart job, restart counter is at 1.
Oct 02 17:40:33 zynthian systemd[1]: Stopped zynthian_debug.service - Zynthian User Interface (DEBUG).
Oct 02 17:40:33 zynthian systemd[1]: Started zynthian_debug.service - Zynthian User Interface (DEBUG).
Oct 02 17:40:33 zynthian startx[1378]: X.Org X Server 1.21.1.7
Oct 02 17:40:33 zynthian startx[1378]: X Protocol Version 11, Revision 0
Oct 02 17:40:33 zynthian startx[1378]: Current Operating System: Linux zynthian 6.6.47-v8-16k+ #1794 SMP PREEMPT Thu Aug 29 16:30:28 BST 2024 aarch64
Oct 02 17:40:33 zynthian startx[1378]: Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe bcm2708_fb.fbwidth=640 bcm2708_fb.fbheight=480 bcm2708_fb.fbdepth=16 bcm2708_fb.fbswap=1 smsc95xx.macaddr=2C:CF:67:75:F8:2B vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000 root=PARTUUID=e249d476-02 rootfstype=ext4 fsck.repair=yes rootwait video=DSI-1:800x480@60,rotate=180 console=tty3 logo.nologo quiet loglevel=2 vt.global_cursor_default=0 modules-load=dwc2,libcomposite
Oct 02 17:40:33 zynthian startx[1378]: xorg-server 2:21.1.7-3+rpt3+deb12u7 (Debian -- User Support)
Oct 02 17:40:33 zynthian startx[1378]: Current version of pixman: 0.42.2
Oct 02 17:40:33 zynthian startx[1378]: Before reporting problems, check http://wiki.x.org
Oct 02 17:40:33 zynthian startx[1378]: to make sure that you have the latest version.
Oct 02 17:40:33 zynthian startx[1378]: Markers: (–) probed, (
Oct 02 17:40:33 zynthian startx[1378]: (++) from command line, (!!) notice, (II) informational,
Oct 02 17:40:33 zynthian startx[1378]: (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
Oct 02 17:40:33 zynthian startx[1378]: (==) Log file: “/var/log/Xorg.0.log”, Time: Wed Oct 2 17:40:33 2024
Oct 02 17:40:33 zynthian startx[1378]: (==) Using config directory: “/etc/X11/xorg.conf.d”
Oct 02 17:40:33 zynthian startx[1378]: (==) Using system config directory “/usr/share/X11/xorg.conf.d”
Oct 02 17:40:33 zynthian startx[1378]: (EE)
Oct 02 17:40:33 zynthian startx[1378]: Fatal server error:
Oct 02 17:40:33 zynthian startx[1378]: (EE) no screens found(EE)
Oct 02 17:40:33 zynthian startx[1378]: Please consult the The X.Org Foundation support
Oct 02 17:40:33 zynthian startx[1378]: at http://wiki.x.org
Oct 02 17:40:33 zynthian startx[1378]: for help.
Oct 02 17:40:33 zynthian startx[1378]: (EE) Please also check the log file at “/var/log/Xorg.0.log” for additional information.
Oct 02 17:40:33 zynthian startx[1378]: (EE) Server terminated with error (1). Closing log file.
Oct 02 17:40:48 zynthian startx[1377]: xinit: giving up
Oct 02 17:40:48 zynthian startx[1377]: xinit: unable to connect to X server: Connection refused
Oct 02 17:40:48 zynthian startx[1377]: xinit: server error
Oct 02 17:40:48 zynthian systemd[1]: zynthian_debug.service: Main process exited, code=exited, status=1/FAILURE
Oct 02 17:40:48 zynthian systemd[1]: zynthian_debug.service: Failed with result ‘exit-code’.
Oct 02 17:40:53 zynthian systemd[1]: zynthian_debug.service: Scheduled restart job, restart counter is at 2.
Oct 02 17:40:53 zynthian systemd[1]: Stopped zynthian_debug.service - Zynthian User Interface (DEBUG).
Oct 02 17:40:53 zynthian systemd[1]: Started zynthian_debug.service - Zynthian User Interface (DEBUG).
Oct 02 17:40:53 zynthian startx[1419]: X.Org X Server 1.21.1.7
Oct 02 17:40:53 zynthian startx[1419]: X Protocol Version 11, Revision 0
Oct 02 17:40:53 zynthian startx[1419]: Current Operating System: Linux zynthian 6.6.47-v8-16k+ #1794 SMP PREEMPT Thu Aug 29 16:30:28 BST 2024 aarch64
Oct 02 17:40:53 zynthian startx[1419]: Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe bcm2708_fb.fbwidth=640 bcm2708_fb.fbheight=480 bcm2708_fb.fbdepth=16 bcm2708_fb.fbswap=1 smsc95xx.macaddr=2C:CF:67:75:F8:2B vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000 root=PARTUUID=e249d476-02 rootfstype=ext4 fsck.repair=yes rootwait video=DSI-1:800x480@60,rotate=180 console=tty3 logo.nologo quiet loglevel=2 vt.global_cursor_default=0 modules-load=dwc2,libcomposite
Oct 02 17:40:53 zynthian startx[1419]: xorg-server 2:21.1.7-3+rpt3+deb12u7 (Debian -- User Support)
Oct 02 17:40:53 zynthian startx[1419]: Current version of pixman: 0.42.2
Oct 02 17:40:53 zynthian startx[1419]: Before reporting problems, check http://wiki.x.org
Oct 02 17:40:53 zynthian startx[1419]: to make sure that you have the latest version.
Oct 02 17:40:53 zynthian startx[1419]: Markers: (–) probed, () from config file, (==) default setting,
Oct 02 17:40:53 zynthian startx[1419]: (++) from command line, (!!) notice, (II) informational,
Oct 02 17:40:53 zynthian startx[1419]: (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
Oct 02 17:40:53 zynthian startx[1419]: (==) Log file: “/var/log/Xorg.0.log”, Time: Wed Oct 2 17:40:53 2024
Oct 02 17:40:53 zynthian startx[1419]: (==) Using config directory: “/etc/X11/xorg.conf.d”
Oct 02 17:40:53 zynthian startx[1419]: (==) Using system config directory “/usr/share/X11/xorg.conf.d”
Oct 02 17:40:53 zynthian startx[1419]: (EE)
Oct 02 17:40:53 zynthian startx[1419]: Fatal server error:
Oct 02 17:40:53 zynthian startx[1419]: (EE) no screens found(EE)
Oct 02 17:40:53 zynthian startx[1419]: Please consult the The X.Org Foundation support
Oct 02 17:40:53 zynthian startx[1419]: at http://wiki.x.org
Oct 02 17:40:53 zynthian startx[1419]: for help.
Oct 02 17:40:53 zynthian startx[1419]: (EE) Please also check the log file at “/var/log/Xorg.0.log” for additional information.
Oct 02 17:40:53 zynthian startx[1419]: (EE) Server terminated with error (1). Closing log file.
Oct 02 17:41:08 zynthian startx[1418]: xinit: giving up
Oct 02 17:41:08 zynthian startx[1418]: xinit: unable to connect to X server: Connection refused
Oct 02 17:41:08 zynthian startx[1418]: xinit: server error
Oct 02 17:41:08 zynthian systemd[1]: zynthian_debug.service: Main process exited, code=exited, status=1/FAILURE
Oct 02 17:41:08 zynthian systemd[1]: zynthian_debug.service: Failed with result ‘exit-code’.
Oct 02 17:41:13 zynthian systemd[1]: zynthian_debug.service: Scheduled restart job, restart counter is at 3.
Oct 02 17:41:13 zynthian systemd[1]: Stopped zynthian_debug.service - Zynthian User Interface (DEBUG).
Oct 02 17:41:13 zynthian systemd[1]: Started zynthian_debug.service - Zynthian User Interface (DEBUG).
Oct 02 17:41:13 zynthian startx[1458]: X.Org X Server 1.21.1.7
Oct 02 17:41:13 zynthian startx[1458]: X Protocol Version 11, Revision 0
Oct 02 17:41:13 zynthian startx[1458]: Current Operating System: Linux zynthian 6.6.47-v8-16k+ #1794 SMP PREEMPT Thu Aug 29 16:30:28 BST 2024 aarch64
Oct 02 17:41:13 zynthian startx[1458]: Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe bcm2708_fb.fbwidth=640 bcm2708_fb.fbheight=480 bcm2708_fb.fbdepth=16 bcm2708_fb.fbswap=1 smsc95xx.macaddr=2C:CF:67:75:F8:2B vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000 root=PARTUUID=e249d476-02 rootfstype=ext4 fsck.repair=yes rootwait video=DSI-1:800x480@60,rotate=180 console=tty3 logo.nologo quiet loglevel=2 vt.global_cursor_default=0 modules-load=dwc2,libcomposite
Oct 02 17:41:13 zynthian startx[1458]: xorg-server 2:21.1.7-3+rpt3+deb12u7 (Debian -- User Support)
Oct 02 17:41:13 zynthian startx[1458]: Current version of pixman: 0.42.2
Oct 02 17:41:13 zynthian startx[1458]: Before reporting problems, check http://wiki.x.org
Oct 02 17:41:13 zynthian startx[1458]: to make sure that you have the latest version.
Oct 02 17:41:13 zynthian startx[1458]: Markers: (–) probed, (
Oct 02 17:41:13 zynthian startx[1458]: (++) from command line, (!!) notice, (II) informational,
Oct 02 17:41:13 zynthian startx[1458]: (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
Oct 02 17:41:13 zynthian startx[1458]: (==) Log file: “/var/log/Xorg.0.log”, Time: Wed Oct 2 17:41:13 2024
Oct 02 17:41:13 zynthian startx[1458]: (==) Using config directory: “/etc/X11/xorg.conf.d”
Oct 02 17:41:13 zynthian startx[1458]: (==) Using system config directory “/usr/share/X11/xorg.conf.d”
Oct 02 17:41:13 zynthian startx[1458]: (EE)
Oct 02 17:41:13 zynthian startx[1458]: Fatal server error:
Oct 02 17:41:13 zynthian startx[1458]: (EE) no screens found(EE)
Oct 02 17:41:13 zynthian startx[1458]: Please consult the The X.Org Foundation support
Oct 02 17:41:13 zynthian startx[1458]: at http://wiki.x.org
Oct 02 17:41:13 zynthian startx[1458]: for help.
Oct 02 17:41:13 zynthian startx[1458]: (EE) Please also check the log file at “/var/log/Xorg.0.log” for additional information.
Oct 02 17:41:13 zynthian startx[1458]: (EE) Server terminated with error (1). Closing log file.
Oct 02 17:41:28 zynthian startx[1457]: xinit: giving up
Oct 02 17:41:28 zynthian startx[1457]: xinit: unable to connect to X server: Connection refused
Oct 02 17:41:28 zynthian startx[1457]: xinit: server error
Oct 02 17:41:28 zynthian systemd[1]: zynthian_debug.service: Main process exited, code=exited, status=1/FAILURE
Oct 02 17:41:28 zynthian systemd[1]: zynthian_debug.service: Failed with result ‘exit-code’.
Oct 02 17:41:34 zynthian systemd[1]: zynthian_debug.service: Scheduled restart job, restart counter is at 4.
Oct 02 17:41:34 zynthian systemd[1]: Stopped zynthian_debug.service - Zynthian User Interface (DEBUG).
Oct 02 17:41:34 zynthian systemd[1]: Started zynthian_debug.service - Zynthian User Interface (DEBUG).
Oct 02 17:41:34 zynthian startx[1498]: X.Org X Server 1.21.1.7
Oct 02 17:41:34 zynthian startx[1498]: X Protocol Version 11, Revision 0
Oct 02 17:41:34 zynthian startx[1498]: Current Operating System: Linux zynthian 6.6.47-v8-16k+ #1794 SMP PREEMPT Thu Aug 29 16:30:28 BST 2024 aarch64
Oct 02 17:41:34 zynthian startx[1498]: Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe bcm2708_fb.fbwidth=640 bcm2708_fb.fbheight=480 bcm2708_fb.fbdepth=16 bcm2708_fb.fbswap=1 smsc95xx.macaddr=2C:CF:67:75:F8:2B vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000 root=PARTUUID=e249d476-02 rootfstype=ext4 fsck.repair=yes rootwait video=DSI-1:800x480@60,rotate=180 console=tty3 logo.nologo quiet loglevel=2 vt.global_cursor_default=0 modules-load=dwc2,libcomposite
Oct 02 17:41:34 zynthian startx[1498]: xorg-server 2:21.1.7-3+rpt3+deb12u7 (Debian -- User Support)
Oct 02 17:41:34 zynthian startx[1498]: Current version of pixman: 0.42.2
Oct 02 17:41:34 zynthian startx[1498]: Before reporting problems, check http://wiki.x.org
Oct 02 17:41:34 zynthian startx[1498]: to make sure that you have the latest version.
Oct 02 17:41:34 zynthian startx[1498]: Markers: (–) probed, () from config file, (==) default setting,
Oct 02 17:41:34 zynthian startx[1498]: (++) from command line, (!!) notice, (II) informational,
Oct 02 17:41:34 zynthian startx[1498]: (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
Oct 02 17:41:34 zynthian startx[1498]: (==) Log file: “/var/log/Xorg.0.log”, Time: Wed Oct 2 17:41:34 2024
Oct 02 17:41:34 zynthian startx[1498]: (==) Using config directory: “/etc/X11/xorg.conf.d”
Oct 02 17:41:34 zynthian startx[1498]: (==) Using system config directory “/usr/share/X11/xorg.conf.d”
Oct 02 17:41:34 zynthian startx[1498]: (EE)
Oct 02 17:41:34 zynthian startx[1498]: Fatal server error:
Oct 02 17:41:34 zynthian startx[1498]: (EE) no screens found(EE)
Oct 02 17:41:34 zynthian startx[1498]: Please consult the The X.Org Foundation support
Oct 02 17:41:34 zynthian startx[1498]: at http://wiki.x.org
Oct 02 17:41:34 zynthian startx[1498]: for help.
Oct 02 17:41:34 zynthian startx[1498]: (EE) Please also check the log file at “/var/log/Xorg.0.log” for additional information.
Oct 02 17:41:34 zynthian startx[1498]: (EE) Server terminated with error (1). Closing log file.
Oct 02 17:41:49 zynthian startx[1497]: xinit: giving up
Oct 02 17:41:49 zynthian startx[1497]: xinit: unable to connect to X server: Connection refused
Oct 02 17:41:49 zynthian startx[1497]: xinit: server error
Oct 02 17:41:49 zynthian systemd[1]: zynthian_debug.service: Main process exited, code=exited, status=1/FAILURE
Oct 02 17:41:49 zynthian systemd[1]: zynthian_debug.service: Failed with result ‘exit-code’.
Oct 02 17:41:54 zynthian systemd[1]: zynthian_debug.service: Scheduled restart job, restart counter is at 5.
Oct 02 17:41:54 zynthian systemd[1]: Stopped zynthian_debug.service - Zynthian User Interface (DEBUG).
Oct 02 17:41:54 zynthian systemd[1]: Started zynthian_debug.service - Zynthian User Interface (DEBUG).
Oct 02 17:41:54 zynthian startx[1538]: X.Org X Server 1.21.1.7
Oct 02 17:41:54 zynthian startx[1538]: X Protocol Version 11, Revision 0
Oct 02 17:41:54 zynthian startx[1538]: Current Operating System: Linux zynthian 6.6.47-v8-16k+ #1794 SMP PREEMPT Thu Aug 29 16:30:28 BST 2024 aarch64
Oct 02 17:41:54 zynthian startx[1538]: Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe bcm2708_fb.fbwidth=640 bcm2708_fb.fbheight=480 bcm2708_fb.fbdepth=16 bcm2708_fb.fbswap=1 smsc95xx.macaddr=2C:CF:67:75:F8:2B vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000 root=PARTUUID=e249d476-02 rootfstype=ext4 fsck.repair=yes rootwait video=DSI-1:800x480@60,rotate=180 console=tty3 logo.nologo quiet loglevel=2 vt.global_cursor_default=0 modules-load=dwc2,libcomposite
Oct 02 17:41:54 zynthian startx[1538]: xorg-server 2:21.1.7-3+rpt3+deb12u7 (Debian -- User Support)
Oct 02 17:41:54 zynthian startx[1538]: Current version of pixman: 0.42.2
Oct 02 17:41:54 zynthian startx[1538]: Before reporting problems, check http://wiki.x.org
Oct 02 17:41:54 zynthian startx[1538]: to make sure that you have the latest version.
Oct 02 17:41:54 zynthian startx[1538]: Markers: (–) probed, (
Oct 02 17:41:54 zynthian startx[1538]: (++) from command line, (!!) notice, (II) informational,
Oct 02 17:41:54 zynthian startx[1538]: (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
Oct 02 17:41:54 zynthian startx[1538]: (==) Log file: “/var/log/Xorg.0.log”, Time: Wed Oct 2 17:41:54 2024
Oct 02 17:41:54 zynthian startx[1538]: (==) Using config directory: “/etc/X11/xorg.conf.d”
Oct 02 17:41:54 zynthian startx[1538]: (==) Using system config directory “/usr/share/X11/xorg.conf.d”
Oct 02 17:41:54 zynthian startx[1538]: (EE)
Oct 02 17:41:54 zynthian startx[1538]: Fatal server error:
Oct 02 17:41:54 zynthian startx[1538]: (EE) no screens found(EE)
Oct 02 17:41:54 zynthian startx[1538]: Please consult the The X.Org Foundation support
Oct 02 17:41:54 zynthian startx[1538]: at http://wiki.x.org
Oct 02 17:41:54 zynthian startx[1538]: for help.
Oct 02 17:41:54 zynthian startx[1538]: (EE) Please also check the log file at “/var/log/Xorg.0.log” for additional information.
Oct 02 17:41:54 zynthian startx[1538]: (EE) Server terminated with error (1). Closing log file.
It seems some error with your display. Perhaps cable is not well attached or damaged. Please, re-check both extremes. If not, it could be a damaged display or the RBPi DSI interface. In such a case i would send you a replacement. It’s very rare but not impossible.
Ok, thank you! Both ends of the display cable seem ok, and they were working right at the start. both ends seem to be seated right.
Upon wiggling the display cable on the screen end I am able to get the screen to flicker but not stay on.
UPDATE: IT’S WORKING. I had the clamp on the display cable ON TOP of the cable instead of underneath. Let this be a lesson. Thanks @jofemodo for your patience with a big ol’ noob.
Hi @jofemodo ,
I ordered a regular zynthian v5.1 kit and drove into the same issues as described above.
Now I downloaded the image again and saw, that the md5sum is again shows the wrong file, but the md5sum is ok. Just a small thingy.
