Build with pisound and MCP23017
Hy,
I had some parts laying around and decided to do something with it: Trying out Zynthian.
I have Raspberry Pi 3B and a 7" Touchscreen (USB and HDMI) already running Zynthian with dummy config.
I Also have a MCP23017, encoders and a Pisound laying around. I read about problems with the pins using a Pisound but also that these Problems are fixed with the new all in one board that is using MCP23017.
What do i have to do to get the Pisound working with the encoders?
Thanks for your help,
Matthias
Just open up the webconf (zynthian.local zynthian-amp2.local is just one of my machines . . . )
and after selecting custom in the kit menu,
select Pisound in the audio hardware section . . .
That should get your audio side going…
then send us a sound sample when it works ! :face_with_monocle:
Thanks! I already have the audio side of things sorted out. I think I should have made clearer that I’m confused on how to wire the encoders.
HI @matzemoerk!
Nice to meet you, mate! Welcome to the Zynthian community!
Have you took a look to the AllInOne schematic? :wink:
http://wiki.zynthian.org/images/4/44/Zynthian_allinone.sch.svg
sch
EDIT: Just found out, that the pins are configurable in the webconfig tool. Great!!
Thanks! I just had a look at the available Pins when using a Pisound. I have the I2C Pins available on the PiSound Headers (BCM 2 and BCM 3). In the schematic MCP pins 19 and 20 are connected to BCM 26 and BCM 16. These two pins are not available when using the Pisound.
Can i change the mappings in the software so i can use two of the remaining pins? Available on the Pisound header is BCM 2,3,4,5,6,7,14,15,22,23,27.
You can use any of the available pins as INT pins and configure from the webconf tool (hardware => wiring).
I wired everything up on a breadboard following the schematics. But it is not working.
I can see, that the MCP23017 is detected, but the encoder Test is not changing.
root@zynthian:~# i2cdetect -y 1
0 1 2 3 4 5 6 7 8 9 a b c d e f
00: – -- – -- – -- – -- – -- – -- –
10: – -- – -- – -- – -- – -- – -- – -- – --
20: 20 – -- – -- – -- – -- – -- – -- – -- –
30: – -- – -- – -- – -- – -- – -- – -- – --
40: – -- – -- – -- – -- – -- – -- – -- – --
50: – -- – -- – -- – -- – -- – -- – -- – --
60: – -- – -- – -- – -- – -- – -- – -- – --
70: – -- – -- – -- – --
SW0 = 0
ZC0 = 64
SW1 = 0
ZC1 = 64
SW2 = 0
ZC2 = 64
SW3 = 0
ZC3 = 64
I think that something is wrong with my MCP23017 (i have this one: https://www.amazon.de/gp/product/B07PMGGPN8/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1).
I also tried multiple encoders.
Anything else i can check before ordering replacements?
Have you tried to disconnect the pisound board?
I did all the encoder testing without it. I have some replacements ordered. I’m pretty shure the MCP23017 is dead. I noticed that it got pretty hot, maybe there was a short i didn’t notice on the breadboard somewere.
Some else had a hot chip on the Blank screen (HDMI Shows boot to black screen with terminal prompt))
This might help.
They did kill the chip sadly … :frowning:
I took some steps towards a working system. Pisound and the encoders are working. Changed the mcp and it just worked fine
Excellent ! :slight_smile:
Wonderful :smiley:
Any chance of a sound sample?:face_with_monocle:
As soon as I have time for it!
Please … and some photos also will be great!! :wink:
One from the workbench. I’m designing and printing some prototype brackets to mount the encoders to the display.
Small update:
