Hey all,
Thought you might like to know building the zynthian image has just become much more simpler, and can be done on windows, mac and linux, using docker.
The steps to build using docker are:
This is as easy now as:
Install Docker
Install docker-compose
git clone https://github.com/guysoft/ZynthianOS.git
cd ZynthianOS/src
wget https://raw.githubusercontent.com/guysoft/CustomPiOS/devel/src/docker/docker-compose.yml
wget --directory-prefix=./image -c --trust-server-names 'https://downloads.raspberrypi.org/raspbian_lite_latest'
echo "DISTRO_NAME=zynthianos" > .env
sudo docker-compose up -d
sudo docker exec -it zynthianos-build /CustomPiOS/nightly_build_scripts/custompios_nightly_build
Thats it! a few hours later you have a zynthian image ready.
Official nightly build also uses this method.
guysoft
December 10, 2018, 3:26pm
3
There was a bug in the inscrutions.
Step 7 should have been:
7. echo "DISTRO_NAME=zynthianos" > .env
Fixed
wyleu
December 11, 2018, 2:32am
4
Failed on build . . . .
umount: /distro/workspace/mount: target is busy
(In some cases useful info about processes that
use the device is found by lsof(8) or fuser(1).)
++++ true
++++ echo_red -e ‘\nBUILD FAILED!\n’
++++ echo -e -n ‘\e[91m’
++++ echo -e ‘\nBUILD’ ‘FAILED!\n’
BUILD FAILED!
++++ echo -e -n ‘\e[0m’
docker_build_fail.txt (6.4 KB)
guysoft
December 11, 2018, 10:30am
5
umount: /distro/workspace/mount: target is busy suggests something is wrong with the container.
Run:
docker rm -f zynthianos-build
And try again, if you still use zynthianos-build-build delete that too.,
wyleu
December 11, 2018, 10:47am
6
New beast launched 10:34 (Tuesday )
wyleu
December 12, 2018, 6:01pm
7
Ok i finally stopped it after over a day …
git submodule init
Submodule ‘robtk’ (git://github.com/x42/robtk) registered for path ‘robtk’
git submodule update
Cloning into ‘/home/pi/zynthian-sw/plugins/fat1.lv2/robtk’…
strip -s build/fat1.so
zynthian_build2.txt (3.2 KB)
guysoft
December 12, 2018, 9:48pm
8
Looks ok in the nightly build:
03:39:29 make[3]: Entering directory '/home/pi/zynthian-sw/plugins/stepseq.lv2'
03:39:29 git submodule init
03:39:30 Submodule 'robtk' (git://github.com/x42/robtk) registered for path 'robtk'
03:39:30 git submodule update
03:39:30 echo "]; ." >> build/stepseq.ttl
03:39:30 cp -r modgui/* build/modgui/
03:39:31 Cloning into '/home/pi/zynthian-sw/plugins/stepseq.lv2/robtk'...
03:39:32 strip -s build/stepseq.so
03:39:33 Submodule path 'robtk': checked out '3abd3e14306d9eb01e95775a321b7fab4af78f57'
03:39:33 make[3]: Leaving directory '/home/pi/zynthian-sw/plugins/stepseq.lv2'
03:39:33 make[2]: Leaving directory '/home/pi/zynthian-sw/plugins/stepseq.lv2'
03:39:34 make[1]: Leaving directory '/home/pi/zynthian-sw/plugins/stepseq.lv2'
03:39:34 sudo: unable to resolve host f39a8248424b
The line is a little different, I’d try again, the code might have changed. Its not showing strip -s build/fat1.so there.
In general it looks like your build is working at this point, give or take its success.
wyleu
December 13, 2018, 8:37am
9
I burn it to something …
I hunted thew img file… The only one I found under the ZynthianOS folder.
But it does at least boot a pi!!
And away it goes for another build (11:00 13/12/2018)
wyleu
December 13, 2018, 11:20am
10
+++ dirname /CustomPiOS/build_custom_os
++ cd /CustomPiOS
++ pwd
DIR=/CustomPiOS
/CustomPiOS/build
‘[’ -n ‘’ ‘]’
LOG=build.log
define SCRIPT
IFS=’\n’
read -r -d ‘’ SCRIPT
true
‘[’ build.log ‘!=’ no ‘]’
touch build.log
touch: cannot touch ‘build.log’: No such file or directory
guysoft
December 13, 2018, 9:25pm
11
Can you show the output of df from the container,
its saying it can’t create build.log which suggest your mount pints for /distro are wrong.
guysoft
December 13, 2018, 9:32pm
12
It looks from the image installed something
The build has been broken the past few days, see: https://jenkins.zynthian.org/job/ZynthianOS/
Take it up with @jofemodo
I think at the moment its good others can build. perhaps in the future it might be worth to shorten he build process so its easy to build at home. But for not I’d recommend making debuging of it easy first because every other commit @jofemodo does, the build breaks. That should be a rare event. Shortening the build might help it, but Zythian is HUGE, and the only real way to do that is to maintain a Debian software repository.
It might be worth making a docker container that boots the nightly image and lets everyone try out the nightly and debug it.
wyleu
December 14, 2018, 8:24am
13
guysoft
December 16, 2018, 12:29am
14
That is df from your host system and not from the container. The issue you are having is because the mount points inside your container are most likely wrong.
Try this:
sudo docker inspect -f '{{ .Mounts }}' zynthianos-build
Should list a mount point.
wyleu
December 16, 2018, 11:09am
15
wyleu@wyleu-HP-G72-Notebook-PC:~$ sudo docker inspect -f ‘{{.Mounts }}’ zynthianos-build
Error: No such object: zynthianos-build
wyleu@wyleu-HP-G72-Notebook-PC:~$ cd ZynthianOS/
wyleu@wyleu-HP-G72-Notebook-PC:~/ZynthianOS$ sudo docker inspect -f ‘{{.Mounts }}’ zynthianos-build
guysoft
December 16, 2018, 11:00am
16
It says the container os not there dude
sudo docker ps -a?
wyleu
December 16, 2018, 11:15am
17
~/ZynthianOS/src$ sudo docker ps -a
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
fec5648853d0 redis:2.8 “docker-entrypoint.s…” 2 months ago Exited (255) 2 months ago 0.0.0.0:6379->6379/tcp distracted_wright
f21f214e4f0b redis:2.8 “docker-entrypoint.s…” 3 months ago Created confident_lalande
e51cc8cb1725 redis:2.8 “docker-entrypoint.s…” 3 months ago Exited (0) 2 months ago 0.0.0.0:6379->6379/tcp friendly_babbage
320ab0510c8a ubuntu “bash” 3 months ago Exited (130) 3 months ago agitated_raman
22c849d1da06 ubuntu “bash” 3 months ago Exited (0) 3 months ago festive_archimedes
baa461250855 ubuntu “bash” 3 months ago Exited (0) 3 months ago practical_feynman
8636120ff0e2 hello-world “/hello” 3 months ago Exited (0) 3 months ago zen_jackson
cleared down, started again . . .
This run looks like it’s doing something
wyleu
December 16, 2018, 1:15pm
18
++++ grep 2018-11-13-raspbian-stretch-lite.img2
++++ awk ‘{print $4-0}’
+++ root_offset=50331648
+++ echo ‘Mounting image 2018-11-13-raspbian-stretch-lite.img on /distro/workspace/mount, offset for boot partition is 4194304, offset for root partition is 50331648’
+++ sudo mount -o loop,offset=50331648 2018-11-13-raspbian-stretch-lite.img /distro/workspace/mount/
+++ [[ 1 != \2 ]]
++++ expr 50331648 - 4194304
+++ sudo mount -o loop,offset=4194304,sizelimit=46137344 2018-11-13-raspbian-stretch-lite.img /distro/workspace/mount/boot
mount: /distro/workspace/2018-11-13-raspbian-stretch-lite.img: failed to setup loop device: No such file or directory
Sorry that this is little more than an error msg dump . . .
Perhaps I should dispose of my docker installation and start again . . .
wyleu
December 16, 2018, 2:51pm
20
No direct reply.
Tried that but I don’t see a loop module in lsmod after doing it . . .
and now I’m back to the instant error about the build.log…
I’m sorry this has become just plain bewildering . . .
Time to read a docker book. . . .
Again . . .
No such file or directory error gives missing loopback kernel module too. On device tree loopback nodes created?
rmmod loop && ls /dev/loop*
ls: /dev/loop* ei saa kasutada: No such file or directory
modprobe loop && ls /dev/loop*
/dev/loop0 /dev/loop1 /dev/loop2 /dev/loop3 /dev/loop4 /dev/loop5 /dev/loop6 /dev/loop7 /dev/loop-control
