I try to use Docker to make an image for my raspberry 4.
I use Linux Mint, to use Docker, I also need to install Docker.io
When I run the building with step 9, I have an error about git not installed, since I don’t know what to do, I look in the source and finally add in Zynthianos/src/modules/zynthianos/start_chroot_script the line apt install git before gitclone.
With this modification, the build process run normally.
I see that start_chroot_script call the wrong sh file to buster :bash -x setup_system_rbpi_raspbian_lite_stretch.sh I think we need now bash -x setup_system_rbpi_raspbian_lite_buster.sh
Do I need to make an issue on github?
How can I help, I’m not a developper but I make some compilation in the past and try to solve compilation error when possible
Ok, I try another compilation with the modification of setup_system_rbpi_raspbian_lite_buster.sh
The last build.log is more than 3MB, do I need to provide all the log?
Just for my knowledge, for the installation of git, start_chroot_script is the good place to make the modification?
Hello, Zynthian boots up ok on my V2 kit adapted for RPi4, b̶u̶t̶ ̶c̶o̶n̶t̶r̶o̶l̶ ̶k̶n̶o̶b̶s̶ ̶d̶o̶ ̶n̶o̶t̶ ̶w̶o̶r̶k̶. First test results of Pianoteq (using touch screen, which works) are good. No crackling, but both cores fully loaded. I will give it more time later.
Mod-UI and pure data work. I will try later with Mod-UI, lv2 plugins
Linuxsampler does not show any preset
Edit: I miss that there is no soundfont, I add one sfz(Salamander piano) but no sound, I have this message in the CLI: ERROR:root:sfz (ERR 0)
Dexed does not work
That’s all for moment, will try to run zynthian from CLI to have debug information
The SFZ soundfont collection is not downloaded when building the image, but copied from a local directory, so your fresh-build image don’t have any SFZ for Linuxsampler.
Also, copying an SFZ to the directory doesn’t work., You have to create some bank directory, like “pianos”, and put your SFZ inside. Please, confirm that this work for you …
I erased my build and put the nightly which works, so until I make a new build I can’t test.
On the nightly build, work as expected, I will try to add some soundfont on nightly.
The big problematic for me is the missing wifi, I try the command ifup wlan0, the raspberry tell me that there is no wlan0
I try to understand all modification made when running the installation process.
setup_system for buster make a firmware downgrade, I try to upgrade the firmware and after a reboot Wifi works
I just make a try and don’t have the problem.
I make it on Linux Mint 19.2
I do this step:
1 sudo apt-get install docker docker-compose docker.io 2 git clone https://github.com/guysoft/ZynthianOS.git 3 cd ZynthianOS/src 4 wget https://raw.githubusercontent.com/guysoft/CustomPiOS/devel/src/docker/docker-compose.yml 5 wget --directory-prefix=./image -c --trust-server-names ‘https://downloads.raspberrypi.org/raspbian_lite_latest’ 6 echo “DISTRO_NAME=zynthianos” > .env 7 sudo docker-compose up -d I’ve got an error :
ERROR: Version in “./docker-compose.yml” is unsupported. You might be seeing this error because you’re using the wrong Compose file version. Either specify a supported version (e.g “2.2” or “3.3”) and place your service definitions under the services key, or omit the version key and place your service definitions at the root of the file to use version 1.
I put 3.3 instead of 3.6 in docker-compose.yml 8 sudo docker exec -it zynthianos-build /CustomPiOS/nightly_build_scripts/custompios_nightly_build
I have the file from your github
The docker-compose on linux mint is version 1.17.1
I change the version number by 3.3 and on my computer the compilation works
