Allright, so it failed for me in my windows box, so I started a fresh ubuntu 18 box and tried the magic commands, and it failed also, log file attached.build.log (17.0 KB)
Also one point to mention, is the step 4, we do a wget to get another docker-compose.yml, but this command as is will not overwrite the already checkouted docker-compose.yml file but will make a new file with number 1 suffix, so if one does not rename or replace the file then the compose up command will process the wrong one, so one should do this instead if one wants to replace the file:
wget -q https://raw.githubusercontent.com/guysoft/CustomPiOS/devel/src/docker/docker-compose.yml -O docker-compose.yml
Looks like you have issues with failed to setup loop device for device
It is reporting a free loopback device at: /dev/loop8
What is the output of:
sudo losetup
We can try figure out what is going on, but also using vagrant build method is a workaround.
thanks for looking, so sudo losetup inside the container you mean, right ?
root@52388e741f5b:/# sudo losetup
NAME SIZELIMIT OFFSET AUTOCLEAR RO BACK-FILE DIO LOG-SEC
/dev/loop1 0 0 1 1 /var/lib/snapd/snaps/gnome-logs_61.snap 0 512
/dev/loop6 0 0 1 1 /var/lib/snapd/snaps/gnome-characters_296.snap 0 512
/dev/loop4 0 0 1 1 /var/lib/snapd/snaps/gnome-calculator_406.snap 0 512
/dev/loop2 0 0 1 1 /var/lib/snapd/snaps/core18_1066.snap 0 512
/dev/loop0 0 0 1 1 /var/lib/snapd/snaps/gnome-3-28-1804_67.snap 0 512
/dev/loop7 0 0 1 1 /var/lib/snapd/snaps/core_7270.snap 0 512
/dev/loop5 0 0 1 1 /var/lib/snapd/snaps/gtk-common-themes_1313.snap 0 512
/dev/loop3 0 0 1 1 /var/lib/snapd/snaps/gnome-system-monitor_100.snap 0 512
Both would work. You can also try to stop-start docker.
restarted the box & docker, and still the same error:
++++ expr 276824064 - 4194304
+++ sudo mount -o loop,offset=4194304,sizelimit=272629760 2019-07-10-raspbian-buster-lite.img /distro/workspace/mount/boot
mount: /distro/workspace/mount/boot: failed to setup loop device for /distro/workspace/2019-07-10-raspbian-buster-lite.img.
+ exit 1
losetup output, this time loop8 has the file:
/dev/loop1 0 0 1 1 /var/lib/snapd/snaps/gnome-characters_296.snap 0 512
/dev/loop8 0 276824064 1 0 /distro/workspace/2019-07-10-raspbian-buster-lite.img 0 512
/dev/loop6 0 0 1 1 /var/lib/snapd/snaps/gtk-common-themes_1313.snap 0 512
/dev/loop4 0 0 1 1 /var/lib/snapd/snaps/core_7270.snap 0 512
/dev/loop2 0 0 1 1 /var/lib/snapd/snaps/gnome-system-monitor_100.snap 0 512
/dev/loop7 0 0 1 1 /var/lib/snapd/snaps/core18_1066.snap 0 512
/dev/loop5 0 0 1 1 /var/lib/snapd/snaps/gnome-calculator_406.snap 0 512
/dev/loop3 0 0 1 1 /var/lib/snapd/snaps/gnome-logs_61.snap 0 512
and the file is there:
root@52388e741f5b:/distro/workspace# ls -l
total 16482312
-rw-r--r-- 1 root root 16877879296 Aug 26 13:26 2019-07-10-raspbian-buster-lite.img
drwxr-xr-x 21 root root 4096 Jul 10 00:06 mount
Also a point I should mention is that Iām doing it in a virtual machine.
So after having stopped and removed the container, removed the image, removed mount and loop device by hand and restarted process from step 8 compose up, it passed the loop device issue.
Now I get a build failed because of āUnable to fetch some archivesā, Iāll try again
build.log (30.7 KB)
Looks like you donāt have internet connection on the container/ virtual machine.
Check if your VM has internet connection. And if there is a container inside it, then check that too.
I have internet cnx inside and outside, I can issue apt instal htop for example.
No problem Iāll try on another physical machine. Thanks for the advise. brgs Seb
⦠(I reuse post because system tell me to as I write too much )
So on the physical dev machine, ubuntu 16 updated today, had to update yml file to docker compose 2.0 but that is ok I guess, the build fail at update-binfmts, see log attached.build.log (20.3 KB)
guysoft
August 27, 2019, 12:21pm
51
Might also be the image is using the wrong DNS server. Name resolution means it canāt find the DNS server.
Ok looks liek the error is now:
+ '[' -f /.dockerenv ']'
+ update-binfmts --enable qemu-arm
update-binfmts: warning: unable to close /proc/sys/fs/binfmt_misc/register: Invalid argument
update-binfmts: exiting due to previous errors
Thats a new one for me.
There is a bug about it here:
https://bugs.debian.org/cgi-bin/bugreport.cgi?bug=843032
Found in version qemu/1:2.7+dfsg-3
Fixed in version qemu/1:2.8+dfsg-2
What version of qemu-arm-static do you have?
output of
qemu-arm-static --version
Mine is 3.1.0 for refrence
same here
root@1ce5a99d3df0:/# qemu-arm-static --version
qemu-arm version 3.1.0 (Debian 1:3.1+dfsg-8~deb10u1)
Copyright (c) 2003-2018 Fabrice Bellard and the QEMU Project developers
ricard
September 27, 2021, 12:21pm
53
Are the instructions at the top of the thread still valid? I would guess so since this thread is linked from the wiki. However, I tried building (Debian Buster), and all commands went well except the last one terminates with:
+++ source /distro/config
/CustomPiOS/config: line 24: /distro/config: No such file or directory
+ exit 1
guysoft
September 27, 2021, 1:10pm
54
Should work. can you please provide the full log and also if possible the commands you are running?
Thanks.
That config file exists here:
export DIST_NAME=ZynthianOS
export DIST_VERSION=1.0.0
export MODULES="base(network, disable-services(zynthianos))"
export BASE_OVERRIDE_HOSTNAME=zynthian
# if set will enlarge root parition prior to build by provided size in MB
#export BASE_IMAGE_ENLARGEROOT=14000
export BASE_IMAGE_ENLARGEROOT=34500
# if set will resize root partition on image after build to minimum size +
# provided size in MB
export BASE_IMAGE_RESIZEROOT=500
BASE_APT_CACHE=${DIST_PATH}/aptcache
le51
September 27, 2021, 2:06pm
55
Hi all,
Iām not sure @jofemodo use this to build the latest stable ZynthianOs. On @guysoft repo, last commit is 6 month old and there is a :
ZYNTHIANOS_SYS_REPO_BRANCH=master
in some config file, but as far as I know, weāre now on a āstableā or on a ātestingā branch.
ricard
September 28, 2021, 9:04pm
56
Sorry, I goofed up. I realized when I was putting together a log of what Iād done that Iād done cd ZynthianOS rather than cd ZynthianOS/src .
Havenāt completed the build yet, but itās well underway at least. Thanks for confirming that the instructions are still valid!
ricard
September 29, 2021, 6:01am
57
Damn. Went well initially, but after a 9 hour build (did this on an old 2nd generation i3 which was available), terminated with:
+ unpack /filesystem/soundfonts /zynthian/zynthian-data/soundfonts
+ from=/filesystem/soundfonts
+ to=/zynthian/zynthian-data/soundfonts
+ owner=
+ '[' 2 -gt 2 ']'
+ mkdir -p /tmp/unpack/
+ cp -v -r --preserve=mode,timestamps /filesystem/soundfonts/. /tmp/unpack/
/bin/cp: cannot stat '/filesystem/soundfonts/.': No such file or directory
++++ echo_red 'build failed, unmounting image...'
++++ echo -e -n '\e[91m'
++++ echo build failed, unmounting image...
++++ echo -e -n '\e[0m'
++++ cd /distro
++++ unmount_image /distro/workspace/mount force
++++ mount_path=/distro/workspace/mount
++++ force=
++++ '[' 2 -gt 1 ']'
++++ force=force
++++ sync
++++ '[' -n force ']'
+++++ sudo lsof -t /distro/workspace/mount
+++++ sudo mount
+++++ grep /distro/workspace/mount
+++++ awk -F ' on ' '{print $2}'
+++++ sort -r
+++++ awk '{print $1}'
++++ for m in $(sudo mount | grep $mount_path | awk -F " on " '{print $2}' | awk '{print $1}' | sort -r)
++++ echo 'Unmounting /distro/workspace/mount/var/cache/apt...'
++++ sudo umount /distro/workspace/mount/var/cache/apt
++++ echo 'Unmounting /distro/workspace/mount/proc...'
++++ sudo umount /distro/workspace/mount/proc
++++ echo 'Unmounting /distro/workspace/mount/dev/pts...'
++++ sudo umount /distro/workspace/mount/dev/pts
++++ echo 'Unmounting /distro/workspace/mount/dev...'
++++ echo 'Unmounting /distro/workspace/mount/boot...'
++++ sudo umount /distro/workspace/mount/boot
++++ echo 'Unmounting /distro/workspace/mount...'
++++ echo_red -e '\nBUILD FAILED!\n'
++++ echo -e '\nBUILD' 'FAILED!\n'
BUILD FAILED!
+ exit 1
The commands run are identical to what was posted at the top of this thread:
git clone https://github.com/guysoft/ZynthianOS.git
cd ZynthianOS/src
wget https://raw.githubusercontent.com/guysoft/CustomPiOS/devel/src/docker/docker-compose.yml
wget --directory-prefix=./image -c --trust-server-names 'https://downloads.raspberrypi.org/raspbian_lite_latest'
echo "DISTRO_NAME=zynthianos" > .env
sudo docker-compose up -d
sudo docker exec -it zynthianos-build /CustomPiOS/nightly_build_scripts/custompios_nightly_build
build.log (2.9 MB)
This seems to be building a bit out of date, the Raspberry Pi lite image is from 2020. I also hit the āsoundfontā issue, so one fix at a timeā¦
Hereās how to get a working build:
Starting with Step 7.
mkdir modules/zynthianos/filesystem/soundfonts
sudo docker exec -it zynthianos-build CustomPiOS/nightly_build_scripts/custompios_nightly_build
