waveshare32 doesn’t work.
My screen stays white
more /var/log/Xorg.0.log
[ 3159.292]
X.Org X Server 1.19.2
Release Date: 2017-03-02
[ 3159.292] X Protocol Version 11, Revision 0
[ 3159.292] Build Operating System: Linux 4.9.41-v7+ armv7l Raspbian
[ 3159.292] Current Operating System: Linux zynthian 4.9.59-v7+ #1047 SMP Sun O
ct 29 12:19:23 GMT 2017 armv7l
[ 3159.292] Kernel command line: 8250.nr_uarts=1 bcm2708_fb.fbwidth=656 bcm2708
_fb.fbheight=416 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=
0x40000000 dwc_otg.lpm_enable=0 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext
4 elevator=deadline fsck.repair=yes rootwait
[ 3159.292] Build Date: 18 October 2017 04:55:30PM
[ 3159.292] xorg-server 2:1.19.2-1+rpt1+deb9u2 (https://www.debian.org/support)
[ 3159.292] Current version of pixman: 0.34.0
[ 3159.292] Before reporting problems, check http://wiki.x.org
[ 3159.292] Markers: (–) probed, () from config file, (==) default setting,
[ 3159.292] (==) Log file: “/var/log/Xorg.0.log”, Time: Sun Feb 25 08:57:12 201
8
[ 3159.293] (==) Using config directory: “/etc/X11/xorg.conf.d”
[ 3159.293] (==) Using system config directory “/usr/share/X11/xorg.conf.d”
[ 3159.294] (==) No Layout section. Using the first Screen section.
[ 3159.294] (==) No screen section available. Using defaults.
[ 3159.294] () |–>Screen “Default Screen Section” (0)
[ 3159.294] () | |–>Monitor “”
[ 3159.294] (==) No device specified for screen “Default Screen Section”.
Using the first device section listed.
[ 3159.294] () | |–>Device “Display”
[ 3159.294] (==) No monitor specified for screen “Default Screen Section”.
Using a default monitor configuration.
[ 3159.294] (==) Automatically adding devices
[ 3159.294] (==) Automatically enabling devices
[ 3159.294] (==) Automatically adding GPU devices
[ 3159.294] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 3159.294] (WW) The directory “/usr/share/fonts/X11/cyrillic” does not exist.
[ 3159.295] Entry deleted from font path.
[ 3159.295] (WW) The directory “/usr/share/fonts/X11/100dpi/” does not exist.
[ 3159.295] (WW) The directory “/usr/share/fonts/X11/75dpi/” does not exist.
[ 3159.295] (WW) The directory “/usr/share/fonts/X11/Type1” does not exist.
[ 3159.295] (WW) The directory “/usr/share/fonts/X11/100dpi” does not exist.
[ 3159.295] (WW) The directory “/usr/share/fonts/X11/75dpi” does not exist.
[ 3159.295] (==) FontPath set to:
/usr/share/fonts/X11/misc,
built-ins
[ 3159.295] (==) ModulePath set to “/usr/lib/xorg/modules”
[ 3159.295] (II) The server relies on udev to provide the list of input devices
If no devices become available, reconfigure udev or disable AutoAddDevic
es.
[ 3159.295] (II) Loader magic: 0x1fbf40
[ 3159.295] (II) Module ABI versions:
[ 3159.295] X.Org ANSI C Emulation: 0.4
[ 3159.295] X.Org Video Driver: 23.0
[ 3159.295] X.Org XInput driver : 24.1
[ 3159.295] X.Org Server Extension : 10.0
[ 3159.297] (++) using VT number 3
[ 3159.297] (II) systemd-logind: logind integration requires -keeptty and -keep
tty was not provided, disabling logind integration
[ 3159.297] (II) no primary bus or device found
[ 3159.297] (II) LoadModule: “glx”
[ 3159.298] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 3159.302] (II) Module glx: vendor=“X.Org Foundation”
[ 3159.302] compiled for 1.19.2, module version = 1.0.0
[ 3159.302] ABI class: X.Org Server Extension, version 10.0
[ 3159.302] (II) LoadModule: “fbdev”
[ 3159.303] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[ 3159.303] (II) Module fbdev: vendor=“X.Org Foundation”
[ 3159.303] compiled for 1.19.0, module version = 0.4.4
[ 3159.303] Module class: X.Org Video Driver
[ 3159.303] ABI class: X.Org Video Driver, version 23.0
[ 3159.303] (II) FBDEV: driver for framebuffer: fbdev
[ 3159.306] (WW) Falling back to old probe method for fbdev
[ 3159.306] (II) Loading sub module “fbdevhw”
[ 3159.306] (II) LoadModule: “fbdevhw”
[ 3159.306] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[ 3159.307] (II) Module fbdevhw: vendor=“X.Org Foundation”
[ 3159.307] compiled for 1.19.2, module version = 0.0.2
[ 3159.307] ABI class: X.Org Video Driver, version 23.0
[ 3159.307] (EE) open /dev/fb1: No such file or directory
[ 3159.307] (EE) No devices detected.
[ 3159.307] (EE)
Fatal server error:
[ 3159.307] (EE) no screens found(EE)
[ 3159.307] (EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
[ 3159.307] (EE) Please also check the log file at “/var/log/Xorg.0.log” for ad
ditional information.
[ 3159.307] (EE)
[ 3159.313] (EE) Server terminated with error (1). Closing log file.
pi@zynthian:/zynthian/zynthian-sys/sbin $
*** /etc/X11/xorg.conf.d: directory ***
pi@zynthian:/zynthian/zynthian-sys/sbin $ more /usr/share/X11/xorg.conf.d
*** /usr/share/X11/xorg.conf.d: directory ***
