- the internal server error is due to :
● zynthian-webconf.service - Zynthian Webconf
Loaded: loaded (/etc/systemd/system/zynthian-webconf.service; enabled; vendor preset: enabled)
Active: active (running) since Sun 2018-03-18 10:57:48 UTC; 27min ago
Main PID: 355 (zynthian_webcon)
CGroup: /system.slice/zynthian-webconf.service
├─355 /bin/bash /zynthian/zynthian-webconf/zynthian_webconf.sh
└─389 /usr/bin/python3 ./zynthian_webconf.py
Mar 18 11:24:43 zynthian zynthian_webconf.sh[355]: result = self.prepare()
Mar 18 11:24:43 zynthian zynthian_webconf.sh[355]: File "/home/pi/zynthian-webconf/lib/zynthian_config_handler.py", line 46, in prepare
Mar 18 11:24:43 zynthian zynthian_webconf.sh[355]: zynconf.load_midi_config()
Mar 18 11:24:43 zynthian zynthian_webconf.sh[355]: File "/zynthian/zynthian-ui/zynconf/zynthian_config.py", line 94, in load_midi_config
Mar 18 11:24:43 zynthian zynthian_webconf.sh[355]: return load_config(set_env, fpath)
Mar 18 11:24:43 zynthian zynthian_webconf.sh[355]: File "/zynthian/zynthian-ui/zynconf/zynthian_config.py", line 56, in load_config
Mar 18 11:24:43 zynthian zynthian_webconf.sh[355]: with open(fpath) as f:
Mar 18 11:24:43 zynthian zynthian_webconf.sh[355]: FileNotFoundError: [Errno 2] No such file or directory: '/zynthian/zynthian-data/midi-profiles/default.sh'
Mar 18 11:24:43 zynthian zynthian_webconf.sh[355]: ERROR:tornado.access:500 GET / (192.168.40.105) 84.19ms
Mar 18 11:24:43 zynthian zynthian_webconf.sh[355]: INFO:tornado.access:200 GET /favicon.ico (192.168.40.105) 27.96ms
The workaround is the one I gave here (ls -s): https://github.com/zynthian/zynthian-sys/issues/36#issuecomment-372143086
- confirm ssh works only on second time. Opening a CustmPiOS bug. A workaround would be to reboot after first boot.
