I’ve been using a vpc1 + pianoteq setup on a Pi400 and Pisound for a while with no issues.
I’ve been trying to boot Zynthian to test and consider using it as a mani build fo rmore flexibility, but cannot seem to even boot it.
After burning the img, and booting, I just see a flash of text, then goes black and nothing.
Tried taking out the Pisound, as it was flashing 2 red leds ( not quite sure what those are :(… ) And still the same issue.
CHanging the config option on the htmi to for mode 16 also make no difference ( texted on my samsung g9, older hd screen and oled tv. Still the same behaviour.
Tried commentting off additional hardware and sound card, and still always the same behaviour.
I don’t think it is booting, even though it shows up on my network as zynthian. But nothing on screen, and nothing on .local or the machine’s ip.
Any ideas on what else to try?
I have an older Rpi3 around somewhere which I’ll test as well once i can find it ![]()
EDIT: ALso commented the display config options, to make sure it wasn’t trying to set the zynthian’s touchscreen. ALso no change
Display Config
#dtoverlay=piscreen2r-notouch,rotate=270
#dtoverlay=ads7846,speed=2000000,cs=1,penirq=17,penirq_pull=2,swapxy=1,xohms=100,pmax=255
#dtoverlay=piscreen2r-backlight
