Jtunes
January 17, 2020, 10:58pm
1
Hi, everyone!
Every time any one of us powers on our Zynthian, the first thing we see (hopefully) is this:
Well, I am attempting to replace that image with a custom image I made in Blender :
I copied a .png version and a .gif version from a USB stick to /zynthian/zynthian-ui/img/, but, after rebooting, I saw:
I copied the files back from /img/, only to find that they were both:
Apparently, the images copied over successfully, but the Zynthian doesn’t display them on boot.
So… what exactly am I missing? Does this problem have anything to do with those .raw files ?
-Jack
Simply deleite de raw files and reboot.
Could you send the PNG files? I could replace the current ones with something better …
Jtunes
January 18, 2020, 12:24pm
3
@jofemodo Thanks for the tip!
No success as of yet. I’ll keep trying. Here are the images:
mheidt
January 18, 2020, 1:34pm
6
Around the error :)…X/z around y
I just looks blurry if it is static
wyleu
January 18, 2020, 1:36pm
7
and that’s before we start on startup sound… see short sound thread . . .
Do you think we might be overthinking this . … ?
mheidt
January 18, 2020, 1:59pm
8
Nah, good idea!
We should broadcast a nice midi tune on all channels
Small prove that everything works
wyleu
January 18, 2020, 2:11pm
9
Not good as a stage reboot. . . .
Jtunes
January 18, 2020, 3:00pm
10
@mheidt I’m with @wyleu . The image is enough. That is, if I can get it to work!!!
I copied, copied, and recopied the files to /img/. I even copied /img/ back to my USB stick to confirm that it worked. I deleted all the .raw files and rebooted.
Maybe I should try reflashing my SD card. What do you guys think?
Jtunes
January 18, 2020, 3:14pm
11
Another idea:
I’ll look into it when I have time.
mheidt
January 18, 2020, 4:37pm
12
Yes, I was thinking the same when I wrote it and chuckled
wyleu
January 18, 2020, 4:42pm
13
Not ever played with raw. Presumably it’s a data dump straight into the framebuffer…?
Jtunes
January 18, 2020, 10:16pm
15
I tried making my own .raw files and copying them to /img/, but I still got the original boot screen. Time to try reflashing my SD card.
You have to remove this folder with its contents:
/zynthian/config/img
and copy your png to:
Then reboot …
The problem is that your files will be over overwrite on every update.
Let me try your images …
OK! I love them. I just replaced the old ones in the master repoitory
Those wanting to enjoy the new ones, simply remove the:
directory.
Jtunes
January 20, 2020, 12:38am
18
Yes! It finally works! @jofemodo Thanks so much for your guidance!
I’ll post a victory soundclip once I’m done backing up my SD card.
Jtunes
January 20, 2020, 1:03am
19
riban
January 21, 2020, 12:36pm
20
Oh dear! Either my eyesight has dramatically worsened in the past few minutes or the new splash screens are horribly out of focus on my 1024x600 7" screen. Sorry but I don’t like it .
