Jajaja! Ohhh! I love it, it’s kind of dark … but all my zynthian displays are smaller than yours. Anyway, it’s a matter of taste. I will allow to have a custom set of images, OK?
Please, open an issue …
Feature request #123
Hi @ll,
nice work! But I have a problem on the PiTFT-2.8":
It looks like the image is too big for this display… any chance to get it working?
Regards, Holger
That’s weird. I did render the image at 320x240. I think something else is wrong…
It’s working for me on the same display. Try deleting old images and update again.
Ahhh, ok - got it! The problem was: I started the fresh image first on my Zynthian v2 (with the 3.5" OzMaker screen). After that I took the SD card and put it into the Disco-Zynthian with the 2.8" PiTFT, so (I think) the generated images were for the 3.5" screen.
I started the script /zynthian/sbin/generate_fb_splash.sh and now it looks better
Regards, Holger
hm, but shouldn’t it be possible to change the screen?
I had no issues using images in different zynthians so far.
Yes, it should work … when changing the display from webconf, background images are regenerated.
So, should I render the images at a higher resolution? Would that improve the quality of images on bigger screens?
I personally like the glowing Error. But the bending effect of the logo and the zynthian is a bit disturbing to me.
Let me see if I can rig up a better set of images. Stay tuned…
Brand new default Zynthian splash screens!
BTW, these images are rendered at 1280x960. If they need to be smaller, I can make that happen.
You should do it ![]()
Done!
Merged! Thanks a lot!
Can I use png or jpeg images or do I need to use raw?
I used .png and these instructions:
You shouldn’t have to mess with the .raw files.
According to this code in zynthian-ui/zynthian.sh:
function splash_zynthian() {
xloadimage -fullscreen -onroot $ZYNTHIAN_CONFIG_DIR/img/fb_zynthian_boot.jpg
…I decided to put my fb_zynthian_boot.jpg in /zynthian/config/img; it work!
Is this a wrong way ?
