The DeepBass sfz sampleset has high latency (from 20 to 70 msec!!!) baked into the samples. The result is musically unusuable, live. (In a recording you could compensate, but it’s difficult due to the huge variation in latency.)
Just for reference, back in the early 2000’s I played with constant 20ms latency and managed it but didn’t like it. Were I a tighter musician I probably couldn’t have tolerated it. Latencies under 10ms are fine for most folks, but people expect under 5 ms these days. Zynthian on my Pi4 has only a little more than that, as far as I can tell (way good enough for me.) The latency I’m reporting above is in addition to any latency in the Zynthian system, Linux audio, and hardware. So, it’s really quite bad.
I can fix it and I’d be happy to, but I can’t find the source for the samples.
Please advise.
BTW, I’m the creator of the stereo Rhodes sampleset that’s included with Zynthian. I plan to make a few fixes to that as well, but haven’t figured out how open-source samplesets are pulled into Zynthian.
PS: I’m having a blast playing with Zynthian. What a totally cool project!
I don’t know why my screenshot didn’t appear. Yes, that’s one of the files. And thanks for the kind words!
BTW, using sfz sample offset can cause clicks, even if you pick a zero crossing, so I always trim the start and then fade in the first msec. My tool for creating samplesets does this automatically during the sample chopping process.
Ah, I see. I don’t think there is a repository for these. I think it is manually included in the OS image (Index of /files/soundfonts/sfz/Bass), so I think the current way would be messaging @jofemodo for manually including them I think.
Seems like a great tool you have there! I solve the click with the offset parameter by limiting the ampeg_attack to a minimum of 0.001, so an artificial zero crossing if you want.
DeepBass is part of the “NBO” library, which was maintained and released on the LinuxMusicians forum by the user j_e_f_f_g. In the library’s “contents” description, it is explicitly listed as “Deep stereo fender precision sound.”
In the “NBO version 2” thread, you can see that deepbass.zip used to be one of the older standalone packs and was later marked as obsolete, replaced by the complete nbo_2.zip bundle.
Also, the GitHub repository is described as a fork intended for SFZ fixes, and it points back to the original source that hosts the WAV files. The original WAV samples can be found here: Index of /sounds/sfz
Just for the sake of completeness: In fact there is a connection in the zynthian repository to the factory soundfont library:
But it seem to only beeing used to add one file to the otherwise static content which comes with the image. If it would be synced via any github repository, this would certainly be the place.
Thanks. But wouldn’t it be better for zynthian to pull from repos than to duplicate them? Or perhaps I misunderstood. Apparently the build process does pull samples from … somewhere. Where would I find the scripts that do that during the build process?
I have no idea, but I suspect it doesn’t pull from anywhere other than a pre curated set which you can visit at the OS image link above.
Many of the scripts might even not be at github elsewhere at all. And if so it might be worth to think about duplicating for further Zynthian specific integration, compatibility with the available engines instead of sforzando and the controller integration scripts.
Maybe, If the developers here have some spare energy at all besides integrating zynbleton, we could discuss it in an extra space?
