Continuing the discussion from Time for the Buster RC-3 SD image:
I understand your point of view. Convincing the market to move in a different direction is certainly far more suited for people with more bravery and patience than me at the moment
For me, testing only makes sense from a target audience perspective (letâs say, a non technical talent musician using the Zynthian as a musical pocket knife). Letâs say such user just bought a roomy and fast USB disk on the market to store recordings and/or a plethora of custom sound fonts and the disk happens to be formatted as exfat. Reformatting is not really desirable or even possible for this user. The disk may be shared for other purposes and files, etc.
In this case there exits a workaround, but itâs nowhere close to the end-user nor practical:
- plugin usb disk
- From another device able to run ssh connected to the Zynthian:
ssh -lroot zynthian.local
mount -t exfat /dev/sda1 /media/usb0/
exit
(so essentially manualy mounting via an external device).
Technically this works, but is convoluted enough not to be workable in a lot of situations. Certainly not in a live situation, where youâll most likely will want to use the device to store a recording.
I wrongly assumed that it would be possible to improve on this, given how close to working it already is.
To solve my own problem, Iâm considering to chuck that single mount line into some script that will get run at each boot: if the disk is there, a mount will be attempted or else silently fail. Obviously, just tailored to my setup, and Iâll surely regret the customisation one day.
Whatâs the recommended way to approach this?
A bit of googling suggests some inspiration levering systemd which is used smartly on the zynthian:
Could something like this work/help and not interfere with normal automatic mounting?
Anyway, just an idea. Probably a quick hack on my local image is enough for my own use case.
I really need to stay away from the technical stuff as Iâm really more here to produce some sound and I really should treat the Zynthian as the Meta-Synth it isâŚ
Thanks for all the effort youâre putting into all of this!
I have had absolutely great fun with the Zynthian so far, I just have an inclination to want to make it easier to lower the friction for new users
