Hi. Have been using Zynthian for a bit, and have re-discovered ZynAdSubFX (which I tried back in 2008!). Now I have it on my PC for sound programming and want to move my patches (.xmz files) to my Zynthian for perfomance… how is this done?
hi,
i remember a webconf section (presets)… but perhaps i 'm wrong…i tried but it does not work. (@jofemodo, it’s just temporary or there is an issue? i don’t see existing presets )
instead you could use sftp (filezilla) to put xmz inside /zynthian/zynthian-my-data/presets/zynaddsubfx/XMZ … then you will find them inside presets page on zynthian.
uhm…i don’t know…time ago i just deleted and regenerated zynthian directory with normal setup…
should be everything back in order. To me everything works fine. I find MY/ folder inside zynthian preset page.
By design. Just create a symbolic link in the preset folder. Maybe the name has to be the file extension…not sure anymore, wether the UI is checking it as well.
But you are right, it doesn’t work anymore. @jofemodo,
the preset folder needs a strict format.
The parent has to be the extension of the files like lv2.
you only have a depth of 2.
1 level file extension, 2 the name of the symbolic link.
Hence
it mustn’t be
zynaddsubfx/xlz
but xlz/zynaddsubfx
same for puredata., which can’t work at all.
Maybe we need a second preset folder additionally to your format.
IMHO, first level should be the engine. Users shouldn’t need to know the extension used by every engine. Some engines have different types of presets (like ZynAddSubFX) and in such a case, a second level is needed for the different types/extensions.
But things are more complex yet … jejeje! Some presets are simple files, but some others are folders, like LV2 or PD patches.
So … we need a flexible format for preset folders. It depends of the engine …
Proposal:
Let’s do the webconf tool calls the zyngine classes (here we are getting closer of the core API approach )
Currently, each zyngine class implements functions for listing bank and presets. This is half the task.
We would need to add functions for deleting/renaming banks and presets, getting preset info and finally, creating a preset from a “bundle” (uploading presets).
In such a way, the webconf tool don’t need to worry about the implementation details of preset folders for every engine. Additionally, we can easily implement some kind of “preset info” feature, etc.
Finally, following this path we are getting closer to the core API approach.
I like the idea that the engine provides the information.
Hence we need a liblo based API? Is it possible to implement osc server with liblo as well? Not only clients?
Maybe you could create the OSC Server skeleton and I can help when we have a common picture.
When the OSC API is available, I can change the webconf implementation
I mean calling directly to the class methods, importing zyngine into webconf tool.
It’s a middle step before the OSC API. It’s already done in some places of webconf tool, like the pianoteq tab.
XMZ files are not fully supported by Zynthian-UI and currently it’s not a priority. I strongly recommend to use XIZ (instrument) files instead XMZ (session) files. If you really need to use XMZ files, please, tell me the reason. Perhaps you convince to me for improving the XMZ integration … or i could give you some tip for getting what you want without using XMZ files
