Well, with Zynthian, I’ve discovered a whole new universe of possibilities, and now I want to put it into action for live performances. Until now, I’ve had various keyboards, and during live performances, I’ve developed some habits that are hard to let go of
. Specifically, I’m looking for a way to create a snapshot that would allow me to use the M-Audio Oxygen 61 Pro MIDI keyboard with Zynthian as if I were using an electric piano, and to switch instruments in a similar way. I’d use that keyboard for intros and improvisations on stage as a secondary keyboard. I’ve read the manuals (as much as I can understand as a fresh Zynthianer), but I just can’t figure out how to customize things my way.
Here’s what I’m trying to achieve, for example: In the mixer, we have Chain 1 VirtualJV Piano, Chain 2 VirtualJV Piano EP, Chain 3 VirtualJV Rhodes, Chain 4 Fluidsynth Bright Piano…
On the M-Audio Oxygen61 Pro MIDI controller, I have 2 rows of 8 pads each. The top row of pads would be used to select instrument groups, Pad 1 – Pianos, Pad 2 Guitars, Pad 3 Sax’s, Pad 4 Strings/Pads, etc. When I press Pad 1 on the top row, the bottom row would have Pad 1 Chain 1(Instriment1), Pad 2 Chain 2(Instrument2), Pad 3 Chain 3(instrument3) - according to selected group, and so on…
I know that for the top row of pads, I could set them to MIDI channel 16 and use them to call snapshots, and use the bottom row of pads to call ZS3. The problem is that the snapshot loads slowly, even though the engine doesn’t change in the chain (Chain 1, 2, 3 is always VirtualJV, and Chain 4 is Fluidsynth).
I’d appreciate some help; I have no idea how to organize the grouping of instruments so I can switch them quickly.
I’m using Zynthian Vangelis, RPi5 8GB, Apacer microSDHC (until my NVMe arrives).
Thank you all for your help and advice.
