Hi, I’m new on the forum and i try to connect a normal monitor on HDMI but the xserver doesn’t recognize the monitor.
On start the PI show some log but after zynthian start it desapear.
I’d like to test if the MOD-UI could be fine for playing also in a GIG situation.
This is my log
Nov 24 12:26:42 zynthian systemd[1]: zynthian.service: Main process exited, code=exited, status=1/FAILURE
Nov 24 12:26:42 zynthian systemd[1]: zynthian.service: Failed with result ‘exit-code’.
Nov 24 12:26:48 zynthian systemd[1]: zynthian.service: Service RestartSec=5s expired, scheduling restart.
Nov 24 12:26:48 zynthian systemd[1]: zynthian.service: Scheduled restart job, restart counter is at 15.
Nov 24 12:26:48 zynthian systemd[1]: Stopped Zynthian User Interface.
Nov 24 12:26:48 zynthian systemd[1]: Started Zynthian User Interface.
Nov 24 12:26:48 zynthian startx[1335]: X.Org X Server 1.20.4
Nov 24 12:26:48 zynthian startx[1335]: X Protocol Version 11, Revision 0
Nov 24 12:26:48 zynthian startx[1335]: Build Operating System: Linux 4.15.0-99-generic armv8l Raspbian
Nov 24 12:26:48 zynthian startx[1335]: Current Operating System: Linux zynthian 4.19.118-v7l+ #1311 SMP Mon Apr 27 14:26:42 BST 2020 armv7l
Nov 24 12:26:48 zynthian startx[1335]: Kernel command line: coherent_pool=1M 8250.nr_uarts=1 cma=64M snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_headphones=1 bcm2708_fb.fbwidth=640 bcm2708_fb.fbheight=480 bcm2708_fb.fbswap=1 smsc95xx.macaddr=DC:A6:32:99:50:A7 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 dwc_otg.lpm_enable=0 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
Nov 24 12:26:48 zynthian startx[1335]: Build Date: 27 August 2020 08:51:48AM
Nov 24 12:26:48 zynthian startx[1335]: xorg-server 2:1.20.4-1+rpt2+deb10u1 (https://www.debian.org/support)
Nov 24 12:26:48 zynthian startx[1335]: Current version of pixman: 0.36.0
Nov 24 12:26:48 zynthian startx[1335]: Before reporting problems, check http://wiki.x.org
Nov 24 12:26:48 zynthian startx[1335]: to make sure that you have the latest version.
Nov 24 12:26:48 zynthian startx[1335]: Markers: (–) probed, (**) from config file, (==) default setting,
Nov 24 12:26:48 zynthian startx[1335]: (++) from command line, (!!) notice, (II) informational,
Nov 24 12:26:48 zynthian startx[1335]: (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
Nov 24 12:26:48 zynthian startx[1335]: (==) Log file: “/var/log/Xorg.0.log”, Time: Tue Nov 24 12:26:48 2020
Nov 24 12:26:48 zynthian startx[1335]: (==) Using config directory: “/etc/X11/xorg.conf.d”
Nov 24 12:26:48 zynthian startx[1335]: (==) Using system config directory “/usr/share/X11/xorg.conf.d”
Nov 24 12:26:48 zynthian startx[1335]: (EE)
Nov 24 12:26:48 zynthian startx[1335]: Fatal server error:
Nov 24 12:26:48 zynthian startx[1335]: (EE) no screens found(EE)
Nov 24 12:26:48 zynthian startx[1335]: Please consult the The X.Org Foundation support
Nov 24 12:26:48 zynthian startx[1335]: at http://wiki.x.org
Nov 24 12:26:48 zynthian startx[1335]: for help.
Nov 24 12:26:48 zynthian startx[1335]: (EE) Please also check the log file at “/var/log/Xorg.0.log” for additional information.
Nov 24 12:26:48 zynthian startx[1335]: (EE) Server terminated with error (1). Closing log file.
Nov 24 12:27:03 zynthian startx[1335]: xinit: giving up
Nov 24 12:27:03 zynthian startx[1335]: xinit: unable to connect to X server: Connection refused
Nov 24 12:27:03 zynthian startx[1335]: xinit: server error
Nov 24 12:27:03 zynthian systemd[1]: zynthian.service: Main process exited, code=exited, status=1/FAILURE
Nov 24 12:27:03 zynthian systemd[1]: zynthian.service: Failed with result ‘exit-code’.
