This might be amazing and exactly what I was looking for, but let me check first…
My soundcard has an XLR input and a 1/4" jack… So basically 2 mono inputs… Can I have a mono input / mono output layer that plays on both speakers now?
If so… big love. If not so… Also big love but with an added look of expectancy!
I have a pre-amped piezo on one channel which I want to add a little reverb to, and a humbucker that I want to increase the gain on and provide a little compression and then I want to provide individual level controls & pan to he stereo output pairs . . .
Can that be done and if so how does one set it up?
@wyleu I would have thought adding chorus FX chain and selecting input 1 then adding gain FX chain, adding the compressor to this chain and selecting input 2 would work? Are you asking about the subsequent stereo imaging? There is output routing so you could probably deroute the outputs from system:playback and into a subsequeng gain layer???
@jofemodo When I select “Audio Capture” I am presented with an empty screen:
He he. I was listening to your audio clip whilst looking at the Audacity screenshot and got confused when the audio stopped before the play cursor reached the end. . It’s been a hard day. I need beer… It may all start to make sense… or simply matter less .
I am really liking these developments. This tiny box is becoming a flexible workhorse. I see permanent audio inputs on the horizon (as opposed to the temporary USB interface I occasionally plug in).
If you create an audio FX layer with a mono effect, e.g. C* AutoFilter, you are only given the option of Mono from capture_1 or Mono from capture_2. You are not offered mono from both which is a valid workflow, e.g. you have a stereo source which you want to mono. I suggest for mono effects you are also offered “Mono from capture_1 and capture2” similar to “Stereo from capture_1 and capture_2” that you are offered for a stereo effect.
Ein? What branch are you testing on? It’s on master and it says nothing like “mono from” …
With the current implementation you have all the possibilities, except swapping stereo channels.
er… maybe you can - I can’t!!! I can route Left output to left and right output to right but don’t see how to route both outputs to left or both outputs to right.
