Hello, I have a pi400 just sitting here doing nothing but occasionally be used to play emulator games and play videos. Is there anything that I should be wary of if I attempt to install ZynthianOS on it?
I have a simple USB MIDI controller and a USB audio device, both class compliant. Utilizing a small 1080p HDMI monitor (and a mouse, obv) would this be an easy plug and play situation?
Hi @manysounds - a warm zynthian welcome to the forum.
The RPi400 has been discussed a few times (search the forum for references), for example here is a topic that includes links to tutorials. It is not an officially supported platform for zynthian but some users have had some success. I have a RPi 400 but have not tried running zynthian on it.
I have zynthian running on a PI 400.
What can you tell me about your experience with that?
It’s not any different than other PIs. Installation was the same, no changes needed.
@Hans_JB I am having trouble getting it to boot at all. Did you use Belana Etcher? Windows or Mac? Initial boot wait time?
I had issues with everything else that was not raspberry pi imager on windows. Once i used it i was good. I would suggest raspberry pi imager and you have to wait maybe about a minute or two the first time for everything to work itself out.
Keep in mind and i hope you know that because this is not the official zynthian hardware, you will get an error and have to log on to zynthian to update configuration.
