Yah thats a bummer. I don’t know if it makes you feel any better but mine was only working slightly better, like I said the left channel was pretty awful and the midi still doesn’t work so I spent a lot of time monkeying around with it.
I think we bought maybe similar timeframe as I’ve only had it a few days, may have a bad batch. I need to write an email to @jofemodo asking for some help troubleshooting.
It sounds good now and I got a usb midi interface working well. Pianoteq stage is now letting me play killer sounds (rhodes and the steingraeber) without a pc in the loop and I’m super happy with this device.
Just needs some polish and love that we can give it as a community.
Yeah, I can’t wait to get it going. I may not be the most linux savvy user, but I really want to experiment and put the good word of the project out there.
It seems that there is some problem with the Ribbon Bus cable or the AllInOne circuit. Could you test the Ribbon Cable with a multimeter? Also, the extra 40 pin connector soldered on the hifiberry could be the cause of failure. Could you test this too?
I will replace the broken parts, so don’t worry, but you have to wait until July 18th because i’m on holidays, camping with my family on the mountains.
I tested the ribbon cable and the hifiberry, both seem to be OK.
But when I was running a continuity test on the AllInOne pins, I’ve found that those two have some resistance between them (I do not know if this is normal and yes, I’m being careful to not touch the two 5V pins):
Don’t worry, i think i’ve your address, if you didn’t move recently …
Please, when you receive the new circuit, send me the broken one as an “ordinary post”. It should cost you almost nothing and i would like to investigate what the problem is …
The package was shipped 2 weeks ago as a “standard post”. Canada is far away and postal service is slow in spain, specially in summer, but , so you should receive it very soon, i hope
Please, send me everything and i will search for the problem and solve it. Try to maintain the original packaging if possible …
For lower shipping costs, try to send the package as a standard certified “postal card” (under 2 Kg) using your “national” post service. Of course, i will pay the costs if it’s my fault …
I stumbled upon this thread trying to debug my newly built zynthian v2 kit.
It looks that I have a problem similar to victorlucky:
Error screen on boot
“aplay -l” returns “no soundcards found”
the soundcard (snd_rpi_hifiberry_dacplus) gets detected only when i unplug the ribbon cable from the soundcard.
Can’t access webconf (it gets stuck at login page) [This is only a problem in Firefox apparently]
Found that in dmesg:
root@zynthian:/# dmesg | grep pcm512
[ 2.435988] pcm512x 1-004d: Failed to reset device: -121
[ 2.436340] snd-rpi-hifiberry-dacplus soc:sound: ASoC: CODEC DAI pcm512x-hifi not registered - will retry
[ 2.439639] pcm512x: probe of 1-004d failed with error -121
[ 2.539259] snd-rpi-hifiberry-dacplus soc:sound: ASoC: CODEC DAI pcm512x-hifi not registered - will retry
[ 2.550431] snd-rpi-hifiberry-dacplus soc:sound: ASoC: CODEC DAI pcm512x-hifi not registered - will retry
[ 2.973439] snd-rpi-hifiberry-dacplus soc:sound: ASoC: CODEC DAI pcm512x-hifi not registered - will retry
[ 2.979522] snd-rpi-hifiberry-dacplus soc:sound: ASoC: CODEC DAI pcm512x-hifi not registered - will retry
