Hi all !
I tested my Zynthian box a bit further this morning to isolate the source of the bug. I suspect a faulty ribbon cable, as the problem appears even when i leave the ribbon cable hanging there, only connected to the Raspberry+HifiBerry block (disconnected from the AllInOne board and the screen).
I did a continuity test on the pin headers when the cable is connected and found (probably faulty) shorts between a few pins (red lines on image below).
Could anybody confirm if it is a cable problem ? Maybe i should have opened a new thread for that…
Thanks !
edit: I just tested the ribbon cable disconnected from everything else and there is indeed a short between wires 3, 4 and 5 (starting from the red wire). Should I send the faulty ribbon cable back to Zynthian headquarters ?
