Here’s a report on 3 different makers of low latency purpose built Bluetooth Transmitter-Receiver pairs, running proprietary protocols not limited by Apple defined waits in the BT MIDI standard.
Hi @gonzoB ,
my conclusions in this are are very close to your summary, so I preordered new WIDI things from CME. When they arrive I will share experience.
P.S. I´m fun your projects, specialy the last midi-Bone, wind controler like trombone is crazy.
@catherder , I use the BLE for one-direction live performance/practice so the timing is not an issue. When I tried sending back to the instrument from the RPi I needed to insert “dummy” timing codes (just sequential ones), but I didn’t check for latency under those conditions. Thanks for the heads-up.
@ToFF , Yeah, the midi-Bone is a bit of fun. I’m still debugging it, and learning to play. I’m so slow compared to sax-like instruments. I look forward to your review of the WIDI stuff when it arrives.
Gonzo
Hi @gonzoB , I had a look at your projects website. Really nice. I especialy appreciate your midi wind controller.
Hi to all,
First impression from CME WIDI things:
- Zynthian1 plugged with WIDI Bud Pro wia USB port
- Wind Controler Akai EWI USB with WIDI Uhost (powered by small power USB bank) sticked by silver tape.
- Behringer FCB 1010 pedal midi controler with WIDI Master
Configured and setting to one group by WIDI aplication on Android smart phone.
Results: Yes all workings without problems.
But more tests is need, specially in stability of connections, long time connection and others…
Last thing (also on fig.) - Genki Wave ring is not possible connect to WIDI aplication (version 1.4.4) , I must write to CME about this.
Nice work!
Is there any configuration in zynthian required with the widi bud?
I use host to connect various akai wired controllers to PC.
I have some bt pad banks and mpk esque mini key/ pads I would like to use with zynthian if possible.
The one pads/ knob bank will not play well with some windows apps or android for that matter, depending on the app. so work arounds with loopmidi and midiberry were required so I am wondering if something similar may be possible/ necessary in zynthian. Both units have transport controls as well if that matters.
long story short has there been any progress on native bt in zynthian or a process write up/ walkthrough for us less cmd line folks, for native or dongle bt integration?
This would be huge for me, my enjoyment of this pastime almost depends on the ability to turn on and get devices linked up as quickly as possible(bt is a joy in this regard)
I apprecieate all your efforts to satisfy my goals and ineptitude. ![]()
Yes - BLE MIDI will be implemented in the next stable release. We have a proof of concept running in dev which works fairly well but needs some polish.
Supercool!
I am really beginning to believe Zynthian is what I’ve been waiting for.
I tend to obsess a bit with things and so I am now searching the forums for Pi4b hacks and Pi5 mods to existing v5 hardware (which I think is REALLY COOL btw)
Primarily because I have a terrible propensity for tools that do it all. My father years ago told me that sometimes the tool that does everything doesn’t always do anything well.
For me zynthian may be the exception. I invisage all the capabilities that Zynthian has with the ability (possibly) to also be a linux environment, and possibly an android host as well. That, to me is practically nirvana.
Really wish I had learned to code, to electrical engineer, and was a much better musician.
Too many curiousities to focus on one unfortunately.
No is plug-and-play.
With widi devices from CME you can create Create Bluetooth MIDI groups - 4 widi ble to one master, which can be connected to Zynthian. Or use auto pairing. In my case Widi Bud Pro connected to Zynthian and paired with Re.corder from Artinoise.
Setting of Widi Bud Pro or other widi thing from CME are made by aplication in smart phone.
Awesome!
Thank you so much. I am operating from the weeds as I don’t have a zynthian yet, in case it wasn’t apparent. I have a pi3 somewhere I may break it out and take a stab at it.
On top of that my linux experience is extremely limited as well. I had an ubuntu dual boot with win7 years ago that broke and I didn’t know how to fix it.
I want to learn, just not sure I am patient enough.
I really appreciate everyone’s answers to my likely ignorant questions.
My Linux knowledge is also not very great. Still, I built a Zynthian from scratch.
If you want, I can discuss the possible connection of your controllers to zynthian.
Awesome!
Replying by email or would totally
your comment.
I will def reach out when I get one running. I’m doing some pre purchase research on v5 hardware in these forums etc. I am feeling like the support is awesome and that the evolved boards will be supported and kits to upgrade made available if necessary.
I get the gist that 4b may be able already(not certain).
I think the mods that are suggested for pi5 I can probably perform myself. Its only by a very loose grasp on my impulses that I haven’t bought one.
I do try and find the answers myself in the forums but some things I just don’t have enough knowledge to sort out yet. For example I am aware that pi can load several OS but I’m not sure if the V5 board interferes with running linux or others. Or if we would have the capability to run an NVME(?) drive and have a multiboot scenario inside the v5 hardware. If I cant it may not be a deal breaker, but how cool would that be? It should via USB if it cant via the hat interface right?
To run a modern ver. of Android would be a game changer as well.
Or could Zynthian host Reaper? Or host more VST via WINE or however its being done. That would be awesome, or some of these other pi synths I have heard of (that arent already inside).
Bt was a big one but I am pretty satisfied that it will work out.
So many questions but I am looking forward to the experience.
Thanks for the reply and offer of assistance.
Hi @UnkleSkunky
As is, Zynthian run on a SD card, so if you switch with another one with, let’s say, RaspiOS, you will have a working system with an integrated 5inch display. All the switches and encoders will not work unless you configure them and elaborate a software to use them efficiently.
This would need a slightly redesign of the main board if the NVMe drive is connected to it or enough room between the PI5 and the control board for placing an adapter board. (I do not own a v5, so I can’t tell)
I’ve managed to get selectable bootable OSes on another ARM SBC equiped with an NVMe drive. All OSes are Armbian variants and the system use an EFI partition with Grub to load the system. But it’s quiet complicated to achieve that ATM.
see here: Free Android 13 OS now available in Raspberry Pi Imager
As is: no
Find it + a SDcard + HDMI display + USB mouse and you’re ready to go for trying Zynthian ![]()
Before RBPi4, Zynthian was running on a Pi3.
And if you get into troubles, you know where to ask: just open a new thread ![]()
Actually you can run Reaper on a Zynthian:
You may not want to of course. I simply installed the Linux armv7l - 11MB version then run it from the VNC desktop. I didn’t do anything useful with it which might mean delving into audio / MIDI routing but it seems to run okay.
Def will when I can. Right now its a kodi box I don’t even use.
I really appreciate the answers and knowledge of all. I think this is what really makes this a great device. Ongoing and future support, modability and a voracious community. I would like to see this device dominate the competition and the form factor already does that imo. A head unit that can evolve is killer, I hope it really takes off, perhaps with the right to repair stuff we hear about will spur some of that.
thanks everybody
Very cool!
If I am following the workflow at all, one would then map various controls and routing from within Zynthian? Like new track, transport, routing? Or does it need to be fully manipulated within VNC? Would it be similar to how other engines integrate?
I’m not getting this to work. My setup is similar. I’ve got a Zynthian V5 and a WIDI UHost plugged into the USB ports. I can see the device when I do lsusb, but its not showing up in the Capture MIDI from... screen.
I’ve successfully used the UHost on a computer running Ubuntu.
Hi @ralmond! Welcome to the Zynthianland at an exciting time. We are nearing completion of our next release, called Oram which has substantial changes at its core.
Please let us know what version of Zynthian software you are running. BLE MIDI is very much a work in progress but we aspire to having something working before we release Oram. (If not, then shortly afterwards.)
Weird, it should work. I described the first experience in December 2021. I connected WIDI BUD PRO to Zynthian with oram OS and it recognized it without any problems. That is, only after I had to find the right position on the USB hub. So I think of trying a USB hub that is powered to make sure that there is enough power. Oh and my Zynthian runs on a Raspberry Pi 400. The Widi Bud Pro is simply a USB MIDI device that uses BLE and is controlled by itself and not by the Zynthian (Raspbery Pi)
EDIT: You have CME WIDI Uhost, that must be powered. I’m going to try it…
EDIT 2: WIDI Uhost reports to Zynthian OS oram in both cases (powered from dedicated USB port / no connection to this port)
I’m running zynthian 5.10.103-v7l+
I’m having a similar problem with my AKAI EWI-usb, connected through a cable. (An earlier test with an AKAI LPK 25 keyboard seemed to be working, but now is not.)
Both the WIDI UHost and the AKAI EWI show up when I do
amidi -l. -
In the
jack_lspoutput I see thea2jbridge entries, but not entries for the other capture devices.
