I get some notes stock and cc 123 does not work often
Here is my setup
4 channels with a instrument per channel
A push button on a teensy to change channel
A push button as cc123 ( all notes off ) for current select Channel
The only working way to stop stock notes is to reset the interface from admin menu.
Is there a way to assign a cc# to the reset interface option.?
Or a midi command to stop stock notes ?
HI Balam!
Try sending CC120 (better than CC123) to Master Channel.
A hardware panic button is a great idea.
On later kits with the four S1-S4 buttons they can be configured to send all-off, indeed by default a long press of any does this.
No! Change the action to, “UI Action Release” and the short / bold / long options appear.
Gosh, seems like a hidden easter egg ![]()
