I noticed that in most presets of MOD-UI only the TTL-midiport is connected. Is this right and can I, without connecting remote (browser:8888) change this?
Cheers,
Kees
Cheers,
Kees
Hi @Keeze101!
When loading a pedalboard, the zynthian engine will try to connect (if it’s not connected!) the USB midiports to the same input-plugin that the TTY midiport is connected to.
Tell me if it’s not working for you …
Not working: Nekobi, Noize Mak3r, OBXD, DX10, Dexed and more, some do like Rhodes vintage or SynthV1
Also often the interface gets stuck on MOD-UI and I have to reboot (or restart Zynthian)
I also noticed that MOD-Host often peek to 100% CPU…
Are you using the last software version (multilayer)?
as fas as I know, yes, but right now I broke everything by accidentally update via the menu. How about an extra confirmation…
Now I get
root@zynthian:/zynthian/zynthian-ui# git checkout mod
zyngine/zynthian_engine_fluidsynth.py: needs merge
error: you need to resolve your current index first
Please advise… ![]()
Edit: back online with reset merge and force to branche mod…
I think the best solution is re-clone the repository:
cd /zynthian
rm -rf zynthian-ui
git clone -b multilayer https://github.com/zynthian/zynthian-ui.git
Remember to make a copy of the config file or other modified files before!
And avoid to update from the menu until i fix the problems with this …
Hi @Keeze101!
I’ve fixed a bug in the MOD-UI engine and now the MIDI-USB devices should be auto-connected as i explained above.
Update and try it …
Works! Tnx again
Cheers,
Kees
