Hi guys,
You have no idea how I was excited to see you guys pulled it off!!!
I was looking for this solution for a LONG time… I tried to use an iPad with some apps on it, looked for a sound module or even considered replacing my entire keyboard to a new one just to add sounds…
Here is some background…
I own a Yamaha P-121. All I’m looking for is an extension for sounds/effects for the keyboard (mainly live performance, layering two sounds is more than enough). It is important the sound from Pi to be routed back to the keyboard and use the keyboards’ speaker for the new sound (minimum latency is a must obviously).
Basically, I’d like to download SF2 sounds, and pick the right sound using the AMAZING Zynthian!
My keyboard supports Midi over USB, so I’m not sure if I need the extension card or not…
I’m really excited to get started, but I saw there is a shortage of kits so I need to order some HW separately.
Can you guys advice if this list will do?
Pi4 – will 4GB memory be enough?
SD card – will 32GB be enough?
Screen – either Zynscreen1.5 or any HDMI screen I guess.
Controller set - can it be connected to the Pi4 or do i need the special Zyncsreen1.5?
Many thanks!!
Asaf.
